I am looking at purchasing Timbren suspension rubber pads for my 2007 tundra Crew Max.
I just bought a 33 ft. toy hauler and when I hooked it up, the back end felt it!
Anyone have any experience in using the Timbren kit?
I have my 2007 RCSB 4X4 set up with the Timbren springs. I am very well satisfied with them. I pull a KZ 24 Sportster, 6400 lb dry, 4 wheeler, pull behind mower, 110 gallons of water and 20 gallons of gas, plus all the other stuff you pack in. With an equalizer brand weight distribution hitch, properly adjusted, the truck sets level. I did have to call Timbren for spacers to obtain the correct unloaded spacing. They shipped them out at no charge and I had them in 3 or 4 days. They work great when hauling firewood, lumber, etc. You don’t know there installed when you are not loaded. What I like best is not fooling with an air source as I have done in the past with air shocks on other vehicles.
How much sag are you experiencing? You will some if you are loading a lot on the tongue.
I don't know why you would be carrying loads of firewood as suggested.
they work great while pulling or a big load in the box.i took ours off,because of the infamous bed bounce issue.the are too close to the upper frame and hit a good bump and they hit the timbren rubber.about sent us to the doctor for whiplash.haha.
