Old 08-27-2009, 10:09 PM
Dealer : Gene Messer Toyota
2008 Toyota Tundra 5.7L Ltd. crewmx
Last Online: 11-03-2009 07:17 PM
Images: 5
harper223 is on a distinguished road.
harper223's Photo Albums
Default Is this a good combo ?
I have an 08 crewmax 5.7L TRD and am pulling an 09 Jayco Jayflight 32 BHDS weighing in at 9300lbs fully loaded. I was wondering what you guys thought of this combo to improve the ride/stability while pulling (I also have 10ply mich tires, and that made a very big difference too):
1) 1500lb helper springs
2) 1 1/8" diameter rear sway bar
3) Firestone airbags
Will all 3 together make a huge difference? Anything to be taken out/not worth it? Im also switching hitches. I have a Reese DC setup but after tweaking it over and over, I'm sick to death of the friction design. Got my eye on something like the Hensley.
Old 08-27-2009, 10:18 PM
Images: 5
Default Re: Is this a good combo ?
Forgot to mention a couple of things:
Hitch weight for the TT: 1000lbs
I keep the rear tires inflated to 70-75 psi and the fronts are at 65psi while towing
The truck tends to "bob" up and down when going over rougher roads along with the TT. This obviously goes away on smooth roads.
Old 08-27-2009, 10:35 PM
TundraBay's Avatar
Dealer : Wayne Toyota
2007 Toyota Tundra,
Last Online: 11-16-2009 10:10 PM
TundraBay is the One. TundraBay is the One. TundraBay is the One. TundraBay is the One. TundraBay is the One. TundraBay is the One. TundraBay is the One. TundraBay is the One. TundraBay is the One. TundraBay is the One. TundraBay is the One.
TundraBay's Photo Albums
You're within the ratings if you don't throw too much in the bed of the truck. As far as that goes, some weight in the truck rather than in the trailer should increase the stability if you are currently experiencing undesirable sway. A few PSI less in the tires may give you a bit better ride, a bit more "forgiving" of the bumps. I don't think you need springs AND air bags. Either one is good. Make your choice. I like the bags for the adjustability you get with them and the better ride when loaded. I haven't sprung for the TRD sway bar yet but I have to.
Otherwise, looks good.
[Tundra Bay]
Proud Member CBTMA
Radiant Red
Old 08-28-2009, 04:33 PM
cwit's Avatar
Dealer : New Country Toyota
2007 Toyota Tundra,
2006 Toyota Camry-Solara black moon roof
Last Online: Today 01:43 PM
Images: 3
cwit is on a distinguished road.
cwit's Photo Albums My eBay
I think your over safe, this is a good thing. I think your air bags will override your overload springs, but if you blow a bags you still have the springs. About 25 lbs in the air bags and 60 to 65 in rear tires 50 to 55 in front. see you on the road, let's go camping.
Charlie & Linda
Old 08-29-2009, 12:25 PM
Tankerhank's Avatar
Just Call Me Hank
2007 Toyota Tundra Salsa Red DCLB 5.7,
2002 Toyota 4Runner Limited, Silver
Last Online: Today 08:20 PM
Images: 45
Tankerhank is a name known to all. Tankerhank is a name known to all. Tankerhank is a name known to all. Tankerhank is a name known to all. Tankerhank is a name known to all. Tankerhank is a name known to all. Tankerhank is a name known to all.
Tankerhank's Photo Albums
I went the Hellwig spring route (EZ 990), once I had they adjusted to what I wanted with the 5'er I forget them forever, empty that have zero effect on my daily ride. Springs or airbags either will help stabilze the truck.
EZ-990
- Medium Loads
- 2000 lbs. Level Load Capacity
- Mounts Under Factory Axle U-Bolt Plates
- Fully Adjustable
- Heavy Duty Hardware
I have to agree with the other on the tire pressure, I think you are high, I run about 60 psi when hauling.
I believe that bouncing you described is called porpoising, being I have a 5'er I don't have experience with that, seems I read a properly adjusted WD hitch helps fix that also.
Hank
2007 Tundra SR5 DC LB 5.7, Underseat storage, Sonar, Backup Camera, Prodigy brake contoller, Reese 16k 5'er hitch, Towing Mirrors, Michelin LT AT2 275/65R18/E, Hellwig Helper Springs 2,000 lbs, 7/75 Platinum Warranty from Handy Toyota.
Future mods:
Stebel 300hz Horn
Fog Lights
2000 Tundra (bought 9/9/99)
JBA Headers
Gone but not forgotten~
Old 08-29-2009, 11:12 PM
Images: 5
I was informed that the load range psi for these tires was from 40 low, to 80 being the highest. I will try around 60 and see what that does. I run them around town at 45psi.
Old 08-29-2009, 11:39 PM
Tankerhank's Avatar
Just Call Me Hank
Images: 45
When I had the tires put on at Discount they told me the minimum was 45 psi, I have not read anything, but I don't know a difference in ride whether I have them at 60 psi or 45 psi .
Hank
Future mods:
Stebel 300hz Horn
Fog Lights
JBA Headers
