Old 09-13-2009, 03:19 PM
bwieweck's Avatar
Last Online: 09-24-2009 08:32 PM
bwieweck is on a distinguished road.
bwieweck's Photo Albums
Default Tongue wieght??
Question from a newbie.
Just bought a 2010 tundra 4x4 with the TRD off road package. I built a custom tent trailer so I can haul my RZR on it. The trailer weighs 2500 pounds dry and about 2800 with all my gear and water on board. The tongue weight is 780 pounds.
The question is, do I need to install air bags on the rear springs (I did this on my old truck, a 07 gmc sierra). I heard that a wieght dist. hitch is not good for off road travel. I also haul around 500 pounds of gear in the bed of the truck.
Any advise would be great!
Thanks,
BW
Old 09-13-2009, 03:54 PM
cwit's Avatar
Dealer : New Country Toyota
2007 Toyota Tundra,
2006 Toyota Camry-Solara black moon roof
Last Online: Today 04:17 PM
Images: 3
cwit is a glorious beacon of light. cwit is a glorious beacon of light. cwit is a glorious beacon of light. cwit is a glorious beacon of light. cwit is a glorious beacon of light. cwit is a glorious beacon of light. cwit is a glorious beacon of light.
cwit's Photo Albums My eBay
Default Re: Tongue wieght??
1280 lbs on the rear I would if it were me and I agree I would not offroad with a wdh.
Charlie & Linda
Old 09-13-2009, 04:10 PM
bwieweck's Avatar
Thanks for the reply.
Do you have air bags?
What brand and are they available for the 2010's?
Thanks,
BW
Old 09-13-2009, 04:34 PM
stumpm2's Avatar
Dealer : Ressler Toyota
Last Online: 01-05-2010 06:52 PM
stumpm2 is on a distinguished road.
stumpm2's Photo Albums
I tow a 21' toy hauler with a similar tongue weight, maybe slightly more with two large four wheelers. I run a wd hitch and ride rite air bags (firestone). The air bags make the whole rig tow a lot better, the trailer doesn't rock the truck up and down with every bump. If you plan on towing at highway speeds, I would recommend the wd hitch with the air bags and then you can unhook and remove the equilizer bars when you get off road. I highly recommend the air bags though, especially if your load weight varies a lot like mine does depending on if I have four wheelers loaded or not.
2007 4x4 DC with 5.7L, Linex Bed Liner, Wet Okole Seat Covers, Husky Floor Liners, and Zoomers exhaust.
Old 09-14-2009, 05:52 AM
cwit's Avatar
2007 Toyota Tundra,
Images: 3
Yes I have Firestone 5000 air bags and think they are great.
Charlie & Linda
Old 09-14-2009, 10:12 AM
2008 Toyota Tundra DCLB
Last Online: Today 09:46 AM
Images: 17
nomadic is the One. nomadic is the One. nomadic is the One. nomadic is the One. nomadic is the One. nomadic is the One. nomadic is the One. nomadic is the One. nomadic is the One. nomadic is the One. nomadic is the One.
nomadic's Photo Albums
Definitely get the airbags, for me they made the truck way better towing or not. I never off road and probably never will, well I have gone up and down roads like Pikes Peak. I would be concerned though about the suspension travel in the rear of the truck when towing a trailer off road. Looking at the picture of your set-up, it looks like under the wrong conditions your trailer could hit or get high sided, at least air bags can be inflated and raise the truck in the rear about 1 ½ inch.
2008 DCLB work truck, diamond plate running boards , Firestone air bags
95 civic HB b18c1 “built” toy
I’m in your town or will be soon…
Old 09-14-2009, 10:31 AM
Frankenstein's Avatar
Dealer : Wayne Toyota
2007 Toyota Tundra,
Last Online: Today 10:41 AM
Frankenstein is more than famous, they're infamous. Frankenstein is more than famous, they're infamous. Frankenstein is more than famous, they're infamous. Frankenstein is more than famous, they're infamous. Frankenstein is more than famous, they're infamous. Frankenstein is more than famous, they're infamous. Frankenstein is more than famous, they're infamous. Frankenstein is more than famous, they're infamous. Frankenstein is more than famous, they're infamous. Frankenstein is more than famous, they're infamous. Frankenstein is more than famous, they're infamous.
Frankenstein's Photo Albums
I don't fully understand your setup and weights. That RZR must weigh in at about 1,000 lbs on it's own, and since it's ahead of the trailer axles, it's pretty much all on the tongue, is it not? If you add the trailer tongue weight to that, and 500 lbs in the bed of the truck, you must be in the 2,500 lb payload department. Which is probably do-able, but you clearly would need air bags for that, 10 ply tires, brake controller for the trailer.
[Frankenstein's Monster]
Proud Member CBTMA
Radiant Red
Old 09-16-2009, 10:44 AM
Dealer : Copeland Toyota
Last Online: Yesterday 11:22 AM
Images: 7
1jeep will become famous soon enough.
1jeep's Photo Albums
First off nice setup, years ago i had thought about doing the same.
As others have mentioned i would change out the tires to at least "C" rated LT's, add some air bags and a WD Hitch setup. I wouldnt plan on any serious off roading, but with air bags you could disconnect the spring bars of the hitch when you get to the trail. Seriously i doubt that trailer would be much fun to drag around off road.
old 2007 Tundra DC 8' bed 5.7 4x4
new 2008 ford f350 oil burner
Old 09-18-2009, 06:51 AM
Moderator
Dealer : Performance Toyota
2008 Toyota Tundra Slate SR5 4x4,
2005 Toyota Sienna XLE
Last Online: Today 04:49 AM
Images: 23
tomhole will become famous soon enough.
tomhole's Photo Albums
1jeep makes a good point with the airbags and offroad. I have the wireless controller in the cab for my airbags. When I back my trailer into the driveway, I have to disconnect the WDH and deflate the bags so I don't drag the back end. Once the trailer tires clear the initial bumb and incline, I have to air the bags up to 75 psi so the trailer jack on the tongue doesn't drag on the driveway. Without the bags, I would scrape the all the stabilizer jacks off. Used the same technique when we went camping at an unlevel site.
Propbably won't work so well without the in cab controller for the airbags.
Tom
Old 09-18-2009, 02:30 PM
2007 Toyota Tundra,
Tom
That's an excellent rationale for my next upgrade maybe? You could also air up to 100 PSI, drop the stands, deflate and then unhook when the truck drops down.
Proud Member CBTMA
Radiant Red
Old 09-18-2009, 03:24 PM
mxsjw's Avatar
Jedi Ninja in Training
Dealer : Toyota of Puyallup
- Other - 2003 VW Passat,
Images: 10
mxsjw is the One. mxsjw is the One. mxsjw is the One. mxsjw is the One. mxsjw is the One. mxsjw is the One. mxsjw is the One. mxsjw is the One. mxsjw is the One. mxsjw is the One. mxsjw is the One.
mxsjw's Photo Albums
Since airbags are not well suited to heavy offroad use, you could do like I did and checkout Super Springs.
I have em, love em, and rail offroad.
SuperSprings Self-Adjusting Suspension Stabilizers
Beer please!
Old 09-18-2009, 04:28 PM
bwieweck's Avatar
Thanks for all the input. I have Firestone airbags on the way.
I towed this same set-up with my 2007 Sierra and it pulled really nice (except the truck was a DOG) with the air bags.
BW
