Originally Posted by tomhole
If you truely have 2,000 lbs on the hitch, that exceeds the capability of your WDH. There isn't a WDH made that can handle more than 1500 lbs hitch weight. This is way too much hitch weight for any truck and you need to re-consider how you load the trailer.
Tom
That's not the problem and I disagree. I have 13,000 miles on this truck, 90% of it towing with that 2000lbs on the hitch. No stress fractures or bending anywhere. At first I was surprised when I had it weighed but after thousands of miles of real world testing it will not be a problem. It tows fine when it's loaded full with water and no bikes on the back. The bumpy problem occurred when I emptied the water and added bikes to the back, no doubt taking quite a bit of weight off the hitch. I think I might have too much weight in the back of the trailer and not enough on the hitch.
2008 Blue Streak Metallic Double Cab 4x4 Limited 5.7L
2009 Outback 310BHS Sydney Edition 10,060lbs 35'10"
Prodigy, Retrax, Equal-i-zer, Load Lifter 5000
