Old 10-20-2009, 08:03 AM
Dealer : Lou Fusz Toytota
2001 Toyota Tundra,
1995 Toyota Previa LE/SC All-Trac,
- Other - 1994 Land Cruiser
Last Online: Yesterday 08:12 PM
AVService is on a distinguished road.
AVService's Photo Albums
Default New Towing Issue...Input Please
I have an 01 Long Bed V6 basic working Tundra and I love it.
I tow small Fiberglass Trailers as they are very light and durable and seem to be a good match for the Tundra.
I keep upgrading though and now I am up to a 17' Casita unit that of course weighs in as the heaviest one I have yet had.
The tounge weight has gone up considerably with this one and the trailer wants to pull the rear end of the Tundra down.
I put on an inverted tube and ball to level it out some but it still is a little too much for the rear of the truck.
I think I am on the edge of needing a WDH and really do not want to go there if not needed.
I have the stock shocks and wonder if I can augment my capacity or achieve easier level towing by going with some better/heavier duty shocks?
I also would look at Airbags but I am not thinking it is my first step?
Any Thoughts?
I have also been looking for V8 Tundra longbeds as another option but they are not too easy to find.
Thanks
Ed
Old 10-20-2009, 08:36 AM
2005 Toyota Sienna
Last Online: Yesterday 10:46 PM
music is on a distinguished road.
music's Photo Albums
Default Re: New Towing Issue...Input Please
You either need supplemental springs (air bags, overload spring, etc.) or a WDH system. For a ball-mount trailer, the WDH system is preferred, since it redistributes the weight. Shocks are dampening devices, not "load carrying".
Old 10-20-2009, 10:05 AM
JD and Beastlet's Avatar
2005 Toyota Sequoia Limited 4x4
Last Online: 11-20-2009 10:12 AM
JD and Beastlet is on a distinguished road.
JD and Beastlet's Photo Albums
Remember too that your rear axle is essentially the fulcrum of a big lever... the more tongue weight applied, the less weight on the front suspension. Airbags or stiffer springs may help level the truck but will neither lighten the load on your rear suspension nor increase the load on your front suspension... to do that you need WDH.
2008 Starcraft ST 2700BH behind 2005 Toyota Sequoia Limited 4x4.
Linked by ProPride 3P 1400, stopped by Prodigy, guided by Garmin nüvi 760.
2006 Fleetwood Sun Valley - sold March 2009 / 2006 Dodge Caravan - traded April 2008
Old 10-20-2009, 08:41 PM
2008 Toyota Tundra DCLB
Last Online: Yesterday 07:27 PM
Images: 16
nomadic is on a distinguished road.
nomadic's Photo Albums
i would say WDH i don't know much about 1g but you have to many pounds on there. i would say between air bags and WDH you might be able to do the WDH for less going used. i find a WDH makes the trailer tow better, and if you do not have a sway bar it is a good time to get one. i looked up the Casita TR they are very nice looking.
2008 DCLB work truck, diamond plate running boards , Firestone air bags
95 civic HB b18c1 “built” toy
I’m in your town or will be soon…
Old 10-23-2009, 09:28 AM
Last Online: 11-11-2009 10:03 PM
lswartz is on a distinguished road.
lswartz's Photo Albums
To much tongue weight is a problem unless you use a WDH. I have a WDH (Reese) but don't use the bars as my front bumper only rises 1 inch. Better yet, weigh your boat & also weigh just the tongue weight & check with you truck specs.
Old 10-25-2009, 10:25 AM
2001 Toyota Tundra,
Thanks for the replies so far.
I am somewhat confused though as my Tounge weight does not seem over the top from the spec?
Anyway,I stumbled across a used 01 reg cab with under 50k and a V8 and 4wd and traded in my beloved v6 this week.
Hoping the extra stoutness of the new truck helps my towing?
Also is it conceivable to anyone here that my mpg may increase with the bigger motor having to work less hard?
Many have suggested this can happen.
Thanks
Ed
Old 10-25-2009, 11:16 AM
Tankerhank's Avatar
Just Call Me Hank
2007 Toyota Tundra Salsa Red DCLB 5.7,
2002 Toyota 4Runner Limited, Silver
Last Online: Yesterday 01:41 PM
Images: 45
Tankerhank is a name known to all. Tankerhank is a name known to all. Tankerhank is a name known to all. Tankerhank is a name known to all. Tankerhank is a name known to all. Tankerhank is a name known to all. Tankerhank is a name known to all.
Tankerhank's Photo Albums
I pulled with my '00 Tundra 4.7 V8 for years, I also added over-load springs to keep the truck on the level. Check out Hellwig springs, for a couple hundred bucks you can fix your leveling issue.
As for gas mileage, it was never great with the 4.7.
Hank
2007 Tundra SR5 DC LB 5.7, Underseat storage, Sonar, Backup Camera, Prodigy brake contoller, Reese 16k 5'er hitch, Towing Mirrors, Michelin LT AT2 275/65R18/E, Hellwig Helper Springs 2,000 lbs, 7/75 Platinum Warranty from Handy Toyota.
Future mods:
Stebel 300hz Horn
Fog Lights
2000 Tundra (bought 9/9/99)
JBA Headers
Gone but not forgotten~
