Old 10-21-2009, 09:29 PM
Last Online: 11-11-2009 10:03 PM
lswartz is on a distinguished road.
lswartz's Photo Albums
Default What does Tow Haul do? 2010 Tundra 5.7l
I know this is dumb but I don't feel any changes with tow haul turned on vs. off when towing a 5,200 travel trailer. The light comes on the dash but that is all I notice. I had a Ford Club Wagon with a V10 & it switched off the 4th gear which was really an overdrive. I only have just over 1,000 miles on it & one trip with the travel trailer. The Tundra tows like a dream.
I just found this answer;
QUOTE=LeeinAZ;885256]It might have a lower tow capacity because you don't have the Tow Package. The TP comes with a trans cooler, a trans temp gauge, and the Tow/Haul switch for the trans, which changes the shift points in the transmission. How much weight do you plan on towing??[/QUOTE]
Thanks.
Old 10-22-2009, 08:29 PM
Moderator
Dealer : Performance Toyota
2008 Toyota Tundra Slate SR5 4x4,
2005 Toyota Sienna XLE
Last Online: Yesterday 07:07 AM
Images: 23
tomhole's Photo Albums
Default Re: What does Tow Haul do? 2010 Tundra 5.7l
Tow / Haul allows for wide open throttle shifting which is nice when towing. Give it a try. Accelerate with your foot on the floor with and without tow / haul.
Tom
Old 10-23-2009, 09:13 AM
Thanks Tom, I will (without a travel trailer on back 1st).
I just never needed that much power (with travel trailer) in the hills of western MD. Maybe the hills of the Blue Ridge Parkway would be a better test. Going from a tow vehicle that would pull 8,000 to 10,300 has been a bigger jump than it sounds.
Old 10-23-2009, 06:49 PM
Moderator
Images: 23
Western MD? Have you been to Racky Gap State Park? MY favorite campground. Just magnificent.
I've pulled my 6,000 lbs trailer through those hills with my 2005 and now my 2008. Big difference. The 2005 worked hard, the 2008 just works. I haven't found tow/haul to be requirement at these weights. I think you are right in that 8k-10k might see more of a benefit.
Tom
Old 10-23-2009, 07:57 PM
We were close but near Thurmont & stayed in Cunningham Falls state park. Most know the area as Camp David. Rocky Gap is super too, but it has been a while since we have stayed there. That is a good long drive for you from the greater Cincinnati area.
Old 10-24-2009, 02:06 PM
jdubh's Avatar
Dealer : Bert Wolfe Toyota
2008 Toyota Tacoma,
2008 Toyota Tundra Limited 4x4 DC BlueS,
- Other - 2005 Accord EX-L
Last Online: Today 01:40 AM
Images: 10
jdubh will become famous soon enough.
jdubh's Photo Albums
It also will start engine braking when you are on a hill and you just tap the brakes once with tow/haul engaged. If you do the same without it on, then the truck just brakes and doesn't downshift. I took on the mountains around the blue ridge parkway yesterday and it was no problem staying at 65mph. I took on a private road with a 21% grade too...going up was easy...going down I had to put it in 4low and first.
2008 Blue Streak Metallic Double Cab 4x4 Limited 5.7L
2009 Outback 310BHS Sydney Edition 10,060lbs 35'10"
Prodigy, Retrax, Equal-i-zer, Load Lifter 5000
Old 10-25-2009, 02:19 PM
Thanks much, that is good info to know.
Old 10-25-2009, 05:23 PM
Dealer : Toyota South
2006 Toyota Sienna Limited,
- Other - 1993 Toyota MR2,
2008 Toyota Tundra DC
Last Online: Today 12:05 AM
MTeator is on a distinguished road.
MTeator's Photo Albums
My truck does the engine braking on hills when you tap the brake with or without tow/haul on and even without a trailer.
The only difference I've seen with tow/haul is it doesn't upshift as readily, such if you lift while accelerating it'll hold the gear.
~Michael
2008 Toyota Tundra 5.7 2WD - Toy Hauler / 2006 Toyota Sienna Limited - Kid Hauler / 1993 Toyota MR2 - Autocross Car
Mods: Tekonsha P3; Tow Mirrors; TRD Wheels; TPMS Pipe Bomb
Old 10-25-2009, 06:44 PM
2008 Toyota Tundra DCLB
Last Online: Yesterday 07:27 PM
Images: 16
nomadic is on a distinguished road.
nomadic's Photo Albums
i have a 2008 and it's the same for me
2008 DCLB work truck, diamond plate running boards , Firestone air bags
95 civic HB b18c1 “built” toy
I’m in your town or will be soon…
