Question I have all the weights but ...
+ Reply to Thread
Results 1 to 5 of 5
Thread: I have all the weights but ...
  1. #1
    Lurking Member awellis3 is on a distinguished road. awellis3's Avatar
    Join Date
    Jan 2010
    Location
    Richmond, Virginia
    Age
    67
    Posts
    31
    Liked
    0 times
    Rep Power
    4
    Default I have all the weights but ...
    I went to my buddy's house and we took his TV and weighed it (tare weight). We then hooked up his trailer and towed it back to the scales. We weighed the truck first (truck on scales, TT on ground) with WD hitch tensioned. Then we released the hitch bars and weighed the truck. We drove the TT onto the scales and weighed the whole set up.
    Results: Trailer = 5,300lbs. (A thousand more than the sticker, but we all know the factory scales are crooked)
    Truck w/WD hitch tensioned weighed 690lbs. more than truck alone.
    BUT truck carrying total tongue weight (WD hitch tension released) weighed 1,280lbs. more! That's 24% tongue weight for the trailer.
    So questions: Is the 1,280lbs. figure the tongue weight or is the 690lbs. figure?
    I'm confuzzed,
    Teach
  2. Remove Advertisements
    Toyota Tundra Forum
    Advertisements
  3. #2
    Moderator tomhole has disabled reputation
    Join Date
    Aug 2005
    Location
    Loveland, OH
    Age
    47
    Posts
    1,129
    Liked
    4 times
    Images
    25
    Rep Power
    3480
    Default Re: I have all the weights but ...
    Teach,
    The numbers do not make sense. No way a WDH transfers 690 lbs to the trailer. It sounds like you did everything correctly, though.
    Only thing I can think of is a mis-accounting. Was the truck on one pad or two? (did you get one weight or two weights: one for the front axle and one for the front axle)
    My trailer had a measured hitch weight of 680 lbs on a hitch scale. If I ran my truck across the scales without a WDH, the rear axle weight would go up by more than 1,000 lbs. But, my front axle weight would be reduced by 320 lbs, so it all added up correctly.
    Just throwing out some guesses.
    Tom
  4. #3
    Veteran Member nomadic is more than famous, they're infamous. nomadic is more than famous, they're infamous. nomadic is more than famous, they're infamous. nomadic is more than famous, they're infamous. nomadic is more than famous, they're infamous. nomadic is more than famous, they're infamous. nomadic is more than famous, they're infamous. nomadic is more than famous, they're infamous. nomadic is more than famous, they're infamous. nomadic is more than famous, they're infamous. nomadic is more than famous, they're infamous. nomadic's Avatar
    Join Date
    Apr 2009
    Location
    Spring Hill
    Posts
    513
    Liked
    0 times
    Images
    18
    Rep Power
    2860
    i have no idea... but i'll through in my 2 cents... was the truck and trailer level to each other. if the truck has to go up a ramp to get on the scale could that mess it up?
    2008 DCLB work truck, diamond plate running boards , Firestone air bags
    95 civic HB b18c1 “built” toy
    I’m in your town or will be soon
  5. #4
    Join Date
    Jan 2010
    Location
    Richmond, Virginia
    Age
    67
    Posts
    31
    Liked
    0 times
    Rep Power
    4
    Thread Starter
    Quote Originally Posted by tomhole View Post
    Teach,
    Tom
    Bingo! Of, course, how stupid of me. The front end UN-loaded when the rear squatted. Doh!
    Thanks you, thank you, thank you! Come to Richmond and I'll by you a beer at O'Toole's.
    Teach
  6. #5
    Don't argue with an insomniac. Frankenstein wants you off his porch. Frankenstein wants you off his porch. Frankenstein wants you off his porch. Frankenstein wants you off his porch. Frankenstein wants you off his porch. Frankenstein wants you off his porch. Frankenstein wants you off his porch. Frankenstein wants you off his porch. Frankenstein wants you off his porch. Frankenstein wants you off his porch. Frankenstein wants you off his porch. Frankenstein's Avatar
    Join Date
    Nov 2007
    Location
    Northwestern Ontario
    Posts
    5,567
    Liked
    8 times
    Rep Power
    29896
    According to my understanding, the tongue weight is the weight BEFORE you tension up the weight distribution.
    That being the case, I'd try to move about 100 lbs from in front of the axles to behind the axles of the trailer, to get the un-tensioned tongue weight to 1,000 lbs.
    [Frankenstein's Monster]
    Proud Member CBTMA
    Radiant Red
    Cold Weather Pkg and Block Heater. Brushed SS Stepboards, TS Sticker
    Tires: BFG All Terrain T/A KO LT265 65 R 18, Diamondback SE Tonneau Cover.
    Curt Front Receiver, custom 8" extension, & Warn 8000lb receiver mount winch back or front,
    Tekonsha Prodigy Brake Controller DSP 16,000 lb 5th wheel hitch Firestone Ride Rite 2445 Air Bags & TRD Rear Sway Bar (Best, Cheapest Mod!)
Posting Permissions
  • You may not post replies
  • You may not edit your posts
