08 CM Towing 2010 Cougar 5er
+ Reply to Thread
Results 1 to 9 of 9
Thread: 08 CM Towing 2010 Cougar 5er
  1. #1
    Rookie crash77 is on a distinguished road. crash77's Avatar
    Join Date
    Mar 2010
    Location
    Fort McMurray
    Posts
    8
    Liked
    0 times
    Images
    1
    Rep Power
    0
    Default 08 CM Towing 2010 Cougar 5er
    I have a 2008 CM with a TRUXX 3in lift and level kit on it (3" lift in the front 1" lift on the rear). I have firestone airbags for the suspension and a pullrite 12k superglide hitch. I will be pulling a 2010 Keystone Xlite 27sab 5th wheel. I am picking this trailer up and I want to be sure I don't have any issues. Will I have enough clearance between the truck box and the bottom of the trailer? Can the king pin on the trailer be adjusted down easily to give me more clearance if possible?
  2. Remove Advertisements
    Toyota Tundra Forum
    Advertisements
  3. #2
    Junior Member jdubh has a brilliant future. jdubh has a brilliant future. jdubh has a brilliant future. jdubh has a brilliant future. jdubh has a brilliant future. jdubh has a brilliant future. jdubh has a brilliant future. jdubh has a brilliant future. jdubh has a brilliant future. jdubh has a brilliant future. jdubh has a brilliant future. jdubh's Avatar
    Join Date
    Dec 2007
    Location
    Powell
    Posts
    408
    Liked
    2 times
    Images
    19
    Rep Power
    61
    Default Re: 08 CM Towing 2010 Cougar 5er
    On most 5ers you can adjust the hitch down a bit. If that doesn't give you enough clearance have the dealer flip the axles on the 5er. Test it before you buy, make it a condition of the sale, they'll flip for free.
    2008 Blue Streak Metallic Double Cab 4x4 Limited 5.7L
    2009 Outback 310BHS Sydney Edition 10,060lbs 35'10"
    Prodigy, Retrax, Equal-i-zer, Load Lifter 5000
  4. #3
    Don't argue with an insomniac. Frankenstein wants you off his porch. Frankenstein wants you off his porch. Frankenstein wants you off his porch. Frankenstein wants you off his porch. Frankenstein wants you off his porch. Frankenstein wants you off his porch. Frankenstein wants you off his porch. Frankenstein wants you off his porch. Frankenstein wants you off his porch. Frankenstein wants you off his porch. Frankenstein wants you off his porch. Frankenstein's Avatar
    Join Date
    Nov 2007
    Location
    Northwestern Ontario
    Posts
    5,567
    Liked
    8 times
    Rep Power
    29896
    I don't have any lift, but I've got good space between the front of the fifth wheel and the side rails of my truck. I did drop the pin on the front of the trailer one set of holes to allow me to have a bit more articulation.
    [Frankenstein's Monster]
    Proud Member CBTMA
    Radiant Red
    Cold Weather Pkg and Block Heater. Brushed SS Stepboards, TS Sticker
    Tires: BFG All Terrain T/A KO LT265 65 R 18, Diamondback SE Tonneau Cover.
    Curt Front Receiver, custom 8" extension, & Warn 8000lb receiver mount winch back or front,
    Tekonsha Prodigy Brake Controller DSP 16,000 lb 5th wheel hitch Firestone Ride Rite 2445 Air Bags & TRD Rear Sway Bar (Best, Cheapest Mod!)
  5. #4
    Veteran Member music is almost part of the TundraSolutions family. music is almost part of the TundraSolutions family. music is almost part of the TundraSolutions family. music is almost part of the TundraSolutions family. music is almost part of the TundraSolutions family. music is almost part of the TundraSolutions family. music is almost part of the TundraSolutions family. music is almost part of the TundraSolutions family. music is almost part of the TundraSolutions family. music is almost part of the TundraSolutions family. music is almost part of the TundraSolutions family.
    Join Date
    Apr 2008
    Location
    TN
    Posts
    705
    Liked
    14 times
    Rep Power
    5767
    FW on a CrewMax?
  6. #5
    Join Date
    Mar 2010
    Location
    Fort McMurray
    Posts
    8
    Liked
    0 times
    Images
    1
    Rep Power
    0
    Thread Starter
    You can pull a FW with a CM as long as you have a slider hitch. After alot of reading the pullrite 12k seems to be the most recommended.
  7. #6
    Supercharged Member Only Toyota for me has a brilliant future. Only Toyota for me has a brilliant future. Only Toyota for me has a brilliant future. Only Toyota for me has a brilliant future. Only Toyota for me has a brilliant future. Only Toyota for me has a brilliant future. Only Toyota for me has a brilliant future. Only Toyota for me has a brilliant future. Only Toyota for me has a brilliant future. Only Toyota for me has a brilliant future. Only Toyota for me has a brilliant future. Only Toyota for me's Avatar
    Join Date
    Nov 2006
    Location
    Pleasant Grove, UT
    Posts
    2,223
    Liked
    0 times
    Images
    50
    Rep Power
    59
    Quote Originally Posted by Frankenstein View Post
    I did the same with my 5er, and it's helped me to acheive about 7" clearance to the rails.
    I think the OP might have a problem getting his setup level, because the truck is lifted.
  8. #7
    Supporter cwit has disabled reputation cwit's Avatar
    Join Date
    May 2007
    Location
    keeseville ny
    Posts
    1,331
    Liked
    8 times
    Images
    3
    Rep Power
    911
    I started with 6ins. clearance that should put him on 3ins. Not going to make it. Most 5ers set nose high on a stock Tundra. You might want them to set up hitch for you. I had my dealer set hitch in camper and hook camper in hitch before hole's were drilled in truck for hitch.
    Charlie & Linda
  9. #8
    Junior Member crewmax buddy is a glorious beacon of light. crewmax buddy is a glorious beacon of light. crewmax buddy is a glorious beacon of light. crewmax buddy is a glorious beacon of light. crewmax buddy is a glorious beacon of light. crewmax buddy is a glorious beacon of light. crewmax buddy is a glorious beacon of light. crewmax buddy is a glorious beacon of light. crewmax buddy is a glorious beacon of light. crewmax buddy is a glorious beacon of light. crewmax buddy is a glorious beacon of light.
    Join Date
    Dec 2009
    Location
    santee
    Posts
    316
    Liked
    1 times
    Images
    4
    Rep Power
    211
    they also make a 3" lift kit for the 12k super glide. i put it on my crewmax and i got tons of clearance. and i also have a 3" lift on my truck with 305/60/18 and mine sits ok. a little high in the front no big deal. dont flip the axles unless you have to makes it very top heavy.
  10. #9
    Moderator tomhole has disabled reputation
    Join Date
    Aug 2005
    Location
    Loveland, OH
    Age
    47
    Posts
    1,129
    Liked
    4 times
    Images
    25
    Rep Power
    3480
    But if you tow the 5er with the nose high, you'll load the rear axle more than the front. This can lead to tire failure.
Posting Permissions
  • You may not post replies
  • You may not edit your posts
