Tire pressure with 5th wheel?
+ Reply to Thread
Results 1 to 2 of 2
Thread: Tire pressure with 5th wheel?
  1. #1
    Junior Member tvman is on a distinguished road.
    Join Date
    Oct 2005
    Location
    saskatchewan
    Posts
    86
    Liked
    0 times
    Rep Power
    8
    Default Tire pressure with 5th wheel?
    I recently purchased a 5th wheel that has a hitch weight of approx. 1100lbs. I normally run 35psi but with the added weight i'm wondering what i should bump the rear tires up to? Thanks.
  2. Remove Advertisements
    Toyota Tundra Forum
    Advertisements
  3. #2
    Moderator tomhole has disabled reputation
    Join Date
    Aug 2005
    Location
    Loveland, OH
    Age
    47
    Posts
    1,129
    Liked
    4 times
    Images
    25
    Rep Power
    3480
    Default Re: Tire pressure with 5th wheel?
    Are they OEM tires? If yes, air them to the max pressure listed on the side of the tire. Should be 44 psi, but check to make sure. And that's cold pressure. And when you can, upgrade the tires to LT rated tires.
Posting Permissions
  • You may not post replies
  • You may not edit your posts
