Go Back   Tundra Solutions Forum > Technical & Vehicle Assistance Forums > Towing
Old 01-18-2004, 03:10 PM
gnb gnb is offline
2002 Toyota Sequoia
Last Online: 10-05-2009 04:47 PM
gnb is on a distinguished road.
gnb's Photo Albums
Default Trailer Hitch Question - Sequoia
Just installed a Hidden Hitch # 87780 onto my 2002 Sequoia.
After installation, noticed the hitch receiver box was slightly off plumb/slanted a few degrees. It is visible - more importantly, the offset will be magnified when my tall bike rack is installed.
Removed the hitch and carefully checked the hitch frame and receiver box- the frame appears bubble level. The problem appears to be the hitch receiver box was welded to the frame several degrees off square/plumb - thus the problem.
Pretty sure etrailer.com will be good about returning/exchanging the hitch for another.
Anyone else have this problem? Should I insist on a new hitch - or is it common for trailer hitches to not be manufactured to exacting standards??
Just want to make sure that I have a legitimate gripe before going thru the pain of sending this one back and waiting on another replacement.
Thanks - Nate
Old 01-18-2004, 04:11 PM
RockyMtnRay's Avatar
2003 Toyota Tundra
RockyMtnRay's Photo Albums
Thanks - Nate
The four receiver hitches I've had on various vehicles over the past 10 years have all been perfectly aligned...leastwise any misalignment wasn't visible to my fairly critical eye. I strongly recommend sending it back...if you ever choose to tow with your Sequoia and use a WDH (weight distributing hitch), the misalignment will play havoc with getting the tension correct on the WDH load bars.
Old 01-18-2004, 04:18 PM
gnb gnb is offline
2002 Toyota Sequoia
gnb's Photo Albums
Thanks- My thoughts exactly, but just wanted someones else's input.
I will call etrailer.com Monday and see test their customer service.
NAte
