Tacoma - convert 4 flat to 7 round trailer wiring
+ Reply to Thread
Results 1 to 3 of 3
Thread: Tacoma - convert 4 flat to 7 round trailer wiring
  1. #1
    Lurking Member grice is on a distinguished road.
    Join Date
    Aug 2002
    Location
    Colorado Springs, CO
    Age
    48
    Posts
    46
    Liked
    0 times
    Rep Power
    11
    Default Tacoma - convert 4 flat to 7 round trailer wiring
    My 99 Toyota Tacoma is my secondary tow vehicle for a small Pop-Up camper. My truck currently has the 4 flat wiring (which I did myself), and I want to convert it to the 7 way round plug for my current pop-up.
    There are simple plug converters out there (from 4 to 7 round), but I obviously would not get the benefit of having the brake controller lead, backup light lead, and the hot lead running back to the trailer.
    Now (finally) my question: what's the best approach to convert over from the 4 flat to the 7 round? Should I buy the simply plug converter, then run my additional leads (brake, backup, hot) back to the plug? How difficult is it to find the brake electrical line that I need to tap into? I'm comfortable running my own hot lead back, but don't know anything about tapping into the brake feed.
    TIA!
  2. Remove Advertisements
    Toyota Tundra Forum
    Advertisements
  3. #2
    Assistant Administrator nhparrot is a pinnacle in their own mind. nhparrot is a pinnacle in their own mind. nhparrot is a pinnacle in their own mind. nhparrot is a pinnacle in their own mind. nhparrot is a pinnacle in their own mind. nhparrot is a pinnacle in their own mind. nhparrot is a pinnacle in their own mind. nhparrot is a pinnacle in their own mind. nhparrot is a pinnacle in their own mind. nhparrot is a pinnacle in their own mind. nhparrot is a pinnacle in their own mind. nhparrot's Avatar
    Join Date
    Sep 2000
    Location
    New Hampshire
    Age
    60
    Posts
    6,438
    Liked
    11 times
    Rep Power
    1671
    see
    http://www.tundrasolutions.com/forum...ad.php?t=14391
    DJ's trailer brake controller wiring instructions
    INFO: How The Wiring on your Trailer Should Work
    Basically, you can cut of the 4 pin flat, connect the 4 wires from it to the correct location on a 7-way. That gives you right turn, left turn, tail lights and ground. You tap into the rear light assembly for the reverse lead. You run a wire along the undercarriage and up into the cab to connect to your barke controller for electric trailer brakes. You run a second wire along the undercarriage into the engine bay and connect it to the +12v positive post on the battery with 30 amp cycling/auto-reset circuit breaker (Ideally there’d be a solenoid so it’s only powered when truck is running) for your aux power/bat charge line.
    ~Glenn
    Yes I am a pirate!
    "To err is human. To arrr is pirate."
  4. #3
    Join Date
    Aug 2002
    Location
    Age
    48
    Posts
    46
    Liked
    0 times
    Rep Power
    11
    Thread Starter
    Glenn - appreciate the reply & info!
Posting Permissions
  • You may not post replies
  • You may not edit your posts
