Old 01-11-2005, 11:54 AM
Last Online: 05-16-2006 09:10 PM
tuckernotis is on a distinguished road.
tuckernotis's Photo Albums
Default '05 Seq Towing ?
I own an '04 4Runner Limited and we love it. My husband needs to replace his '00 Expedition since it is about 3' shorter now (T-boned on NY's Eve). I'm trying to talk him into getting the '05 Seq but he is concerned about the towing capacity. It is much lower than the Exp. We have a 22' boat that weighs in around 5000# with fuel. No hills to climb (SE Louisiana) and no other heavy towing anticipated. I think that Toyota tends to low ball their towing rating while the US makers inflate them. The smaller engine than the Exp (5.4l) and the lower towing capacity make it a tough sell. But ... he wants to lease it through our company and the residual value on the Seq is much better than the Exp. While the Seq is more $$$ MSRP and the invoice price not as low as the Exp., the residual value calculator nearly makes up the difference.
Anyway, does anyone have experience towing with the 05 Seq?
Old 01-11-2005, 12:37 PM
ab's Avatar
ab ab is offline
2006 Toyota Tundra DC 4x4 Ltd,
2003 Toyota Sequoia 4x4 Ltd,
- Other - 87 MR2 T-Top,
2005 Toyota Tundra Long bed,
2000 Toyota Tundra AC 4x4 Ltd,
2007 Toyota Tacoma Sport
Last Online: 11-16-2009 03:23 PM
Images: 5
ab is on a distinguished road.
ab's Photo Albums
We tow a 5000lbs travel trailer regularly several thousand miles at a time (BC to Calif.) with our 03 Seq. and it handles it great. You don't really know its back there unless you are going up very steep long mountain passes. Even then it still pulls fine. A boat will pull even easier because it is much more aerodynamic.
Old 01-11-2005, 12:53 PM
Dealer : Toyota West
2006 Toyota 4Runner
Last Online: 06-27-2007 04:04 PM
pacjr is on a distinguished road.
pacjr's Photo Albums
I tow a rinker 232 cuddy on a steel trailer (6,300 pounds) and the Sequoia towes great around central ohio (flat), but does leave a little room for improvement in the hill on the way down south.
2005 QX56
2004 Black Tundra Double Cab
2002 232 Rinker Cuddy (my toy) for sale
2005 Ebbtide 2600 CBR
Old 01-11-2005, 01:04 PM
czechm8's Avatar
Dealer : Jay Wolfe Toytota
2005 Toyota Sequoia,
- Other - Acura TL
Last Online: Today 01:37 AM
czechm8 is on a distinguished road.
czechm8's Photo Albums
I don't think you would have any trouble at all. Make sure you use trailer brakes on a load of that size and consider a weight distributing hitch to compensate for the tongue weight (all with safety in mind).
I have towed a smaller boat for hunting and I hardly knew it was there. I never had to take the tranny out of overdrive. The '05 has many drive-train improvements over previous models. The biggest being the 5 speed transmission. Don't let the engine displacement numbers fool you. The 4.7 V8 is a very capable motor. If you didn't know it, you would probably think the Toyota motor is as big as the Ford's if you drove them both.
Be careful though! If you get a Sequoia you will not want to go back to Ford.
05 Sequoia 4x4 Ltd. Phantom Grey Pearl, Weld 20" wheels on Toyo tires, MagnaFlow cat-back, Amsoil fluids, custom 15" overhead DVD system, Eclipse NAV system w/camera, Sirius tuner. Hybrid Audio Technologies drivers and DLS coaxials, TRU B-2110 and H-1 amps, 13" eD sub, iPod hookup. SilverStar Ultra lamps.
Old 01-11-2005, 01:27 PM
Dealer : Toyota of Naperville
2001 Toyota Sequoia
Last Online: 10-27-2009 09:16 AM
Heaterswa is on a distinguished road.
Heaterswa's Photo Albums
I think your husband will be satsified with the Sequoia's towing capability. I am, we pull a 5000lb'ish travel trailer. On the flats, look out this rig cruises. On the uphill climbs, it will work the engine, but then it seems this engine really enjoys it too. The 05 has been upgraded with engine and transmission so I think your boat will find a happy home behind this Toyota.
Take one for a test drive and hook it up, have him find out himself.
-Bryan
Old 01-11-2005, 03:36 PM
KLS's Avatar
KLS KLS is offline
KLS's Photo Albums
I think all manufacturers inflate their Tow Rating claims. 7200 is too much for a Tundra to tow safely and reliably...I don't know the Sequoia rating.
Anyway, be sure the boat trailer has working surge brakes, and I'd get an "Equal-i-zer" brand hitch for that rig. It combines weight distributing and sway damping, and is surge-brake friendly.
http://www.equalizerhitch.com/boat.html
RVWholesalers has them for $400.
Ken
You get what you inspect
Not what you expect.
Gibson exhaust system
Hellwig Rear Antisway Bar
Old 01-11-2005, 04:30 PM
Dealer : Toyota of West County
2005 Toyota Sequoia
Last Online: 06-28-2009 12:41 AM
Steve97TT is on a distinguished road.
Steve97TT's Photo Albums
Default Equal-i-zer
This towing thread has made me curious about weight distributing anti-sway hitches...
Just to be sure I really understand the Equal-i-zer hitch...
Does the Equal-i-zer hitch plug right into the Sequoia hitch receiver or does it require one to replace all or part of the factory hitch receiver? Does anything on the Equal-i-zer have to be fit to a particular vehicle or is it easy to swap from one vehicle to another?
So how imperative is it that one go with a weight distibuting anti-sway hitch if towing 5k lbs?
I realize that the conservative answer is to install the Equal-i-zer but it is $400. (Of course I'd gladly spend $400 if it is needed.)
Background -
I might occasionally tow a 3500lb sports car (very, very low center of gravity) on a 1300 lb aluminum dual axle flatbed trailer (link to the trailer). The trailer has electric brakes (for which I already have a Tekonsha Prodigy brake controller) I have never noticed *any* sway when towing the setup with a Chevy Duramax 2500HD (3/4 ton) diesel pickup with a weight carrying hitch and I've towed the setup for about 7000 miles through varied conditions in the midwest. (I have noticed some slight bounce on one particular section of uneven road.)
Thanks,
Steve
Steve
2005 Sequoia Limited
2008 Camry Hybrid
1997 Supra Turbo
Old 01-11-2005, 10:11 PM
RockyMtnRay's Avatar
2003 Toyota Tundra
RockyMtnRay's Photo Albums
Default You really do need a WDH for a 5k trailer
Like all WDH it plugs into the existing hitch receiver. Nothing is done to the installed receiver.
Again, like all WDH, it's readily swappable between tow vehicles. A WDH does require mounting "lift brackets" on the trailer tongue so it's a little harder to swap WDHs between trailers. However even that is possible if additional lift brackets are purchased/mounted on all trailers to be towed.
Not imperative assuming that the tongue weight is about 10% of the total trailer weight but it is an extremely good idea. Here's why:
When you attach a heavy trailer to the back of a tow vehicle, the rear of the tow vehicle sags but the cause isn't as simple as it looks. Specifically 3 things happen to the tow vehicle:
1. The tongue weight (e.g. about 500 lbs for a 5K trailer) is loaded onto the rear suspension. This is the intuitive action and the only one that most people ever consider. By itself, a 500 lb load on the rear suspension should drop it by about a inch.
2. The tongue weight is being applied well behind the axle. Through a teeter-totter like leverage with the rear axle as pivot, that tongue weight causes an unweighting or lifting of the front of the tow vehicle. The amount of unweighting is the ratio between rear overhang (distance from axle to hitch) and the wheelbase. I can't find a number for the rear overhang of a Sequoia but will use 4 feet as a reasonable number. The ratio between that and the 118 inch (10 feet) wheelbase is .40 which means that about .40 times 500 lbs or 200 lbs is being removed from the front of Sequoia. That unweighting of the front end causes it to rise about an inch; it also reduces the amount of braking and steering effort the front tires can produce.
3. Finally, the weight that comes off the front does not disappear into space; rather it's applied to the back suspension...further causing the rear to go down by about an extra half inch. So now your rear suspension has 700 lbs on it (500 lb tongue weight and 200 lb from unweighting the front suspension)
In combination these actions cause a distinct rearward squat...but only part of it is because the rear is pushed down and part is because the front is being lifted up.
You could fight the perceived squat by lifting the rear...but that still doesn't solve the problem of too much weight on the rear and not enough weight on the front.
By comparison, a properly adjusted WDH uses spring bars to apply about a third of the tongue weight to the front suspension, a third to the rear, and remaining third to the trailer's tires. Net result is the front and rear are only loaded with about 170 lbs each so the Sequoia squats equally front and rear but the amount of squat is pretty minimal because neither the front nor the rear loadings is very large. And you have more weight (instead of less) on the front so front tire traction for steering and braking is actually increased instead of reduced. The front suspension, being nicely loaded, also doesn't bounce around as it will when it's been unweighted. And the rear suspension is just nicely loaded instead of having to carry a rather large 700 lbs. A real win-win situation and well worth the $400 cost to get it.
Background -
Thanks,
Steve
Sway occurs when the center of mass of the trailer is close to or behind the trailer's axles. A very front loaded trailer will be very sway resistant but it will put a huge load on the back of the tow vehicle. If the trailer is a bit sway prone...and the tow vehicle front suspension is sufficiently unweighted, then sway becomes very noticeable and very hard to control. The Chevy 2500HD has a very large weight in the front...and has a much longer wheelbase than the Sequoia so it does keep its front tires well planted and the ratio of tow vehicle weight to trailer weight is much higher than with the Sequoia. Nonetheless, the "slight bounce" you experienced is a classic sign that the trailer was sufficiently unweighting the Chevy's front end that its suspension was no longer acting normally. If you had used a WDH with the Chevy, you would have never experienced any noticable amount of bounce...the front would felt very "planted" at all times.
Hope this helps explain why you really do need a WDH when towing a 5K trailer with your Sequoia. Depending on where the trailer's center of mass is relative to its axle(s), you may not even need to use a sway control device as long as you get that tongue weight properly distributed so that a goodly amount of weight is being put on (not taken off) your Sequoia's front tires.
As a case in point, the TrailManor travel trailer I tow has a very high tongue weight (~700 lbs) relative to its total weight (~3800 lbs). That's an indicator that the center of mass is well ahead of the trailer axle (very front loaded) and consequently it is an extremely sway resistant trailer. It's so inherently sway resistant that the TrailManor company recomends that sway control not be used when towing because it will mask improper loading of the trailer.
Ray
Old 01-12-2005, 07:15 PM
Dealer : Frontier Toyota
2003 Toyota Sequoia
Last Online: 05-31-2009 11:19 PM
dgracer is on a distinguished road.
dgracer's Photo Albums
I can offer a little before and after comparison with my 03 SR5 w/17" wheel package towing a 3650lb 26' Aerolite TT before and after the WDH was installed. I reluctantly pulled it home with a standard receiver after I bought it and was surprised that it didnt feel as bad as I thought it might in terms of bounce and sway. 55 mph produced some oscillations on the freeway but manageable.
I still felt that a trailer this size over the highway on a windy day should have a WDH so I bought and installed unit myself (though camping world happily torqued all the bolts and ball for me). It made a noticeable difference in how stable the whole rig felt that I think it was worth doing. Even around town. Far less bouce and a "lighter" feel to the trailer.
I do also have a 19' boat that only weighs about 2500' that does not have, nor require in my opinion, this WDH setup.
