Just wanted to pass this info along as a heads up.
My mom's "boyfriend" (who is in his 70's) recently called me and said that his turn signal indicators were doing strange things. Apparently, whenver he stepped on the brakes, the turn signal indicators on his dash would start flashing (as if the hazard lights were on). He had also been blowing turn signal bulbs recently. He wondered if I knew what the problem could be.
After stewing on it for a while, I remembered that he had a trailer light converter kit and wiring installed to tow a tent trailer. I told him that I bet it was something in that kit that was causing the problem.
He brought his van over (a GM mini van, I know, I know
) and I jacked it up and slid underneath with the creaper. I could not believe my eyes when I saw what U-Haul had done.
The wires were all crimped using those crappy blue crimps (the kind that press over the wire(s) to make contact so there is no slicing involved).
The converter module utself was "hanging" by the wires and wasn't mounted or secured to anything.
None of the wires were wrapped in any protective shielding, and were routed VERY poorly laying across sharp edges in several places. I found at least 3 spots were the insulation had been cut by the edges and the bare wire was grounding.
One of the wires was laying on top of his exhaust. Of course the insulation had melted off and this wire was gronding as well.
We re-routed wiring, re-spliced several connections, wrapped the wire in wire loom, and secured everything up and out of the way. VIOLA! No more problems!
Anyway, after seeing this install, I would NEVER take my vehicle to U-Haul for any electrical work. Just thought I would pass this info along.
Ken
