Old 05-23-2005, 01:04 AM
Dealer : Modesto Toyota World
2003 Toyota Sequoia
Last Online: 04-18-2008 02:56 PM
kericks is on a distinguished road.
Send a message via Yahoo to kericks kericks's Photo Albums
Default OEM Bridgestone Dueler HTs and Towing Heavy Trailer
Hello;
I have an '03 SR5 4x4 Seq. w/ OEM P265/65 R17 tires w/ about 40k on them.
I just bought a 27' Jayco Lite Travel Trailer, Dry weight around 5200.
The Seq. was purchased with a tow package.
How adequate are the Dueler HT's going to be for handling such a heavy trailer? How adequate is the Seq. for this type of duty?
I know, it's too late to ask this question, but is this the wrong vehicle for the job? Do I need to trade the wife's beloved Seq for an '05 Tundra Quad Cab (we have 4 kids), or dare say, an '05 F150 (they are rated to tow 9000)
Help!
Do I need to put LT tires on this Seq?
Kevin
2003 Sequoia, SR5 4x4.
No mods.
Love it.
Old 05-23-2005, 12:56 PM
KLS's Avatar
KLS KLS is offline
KLS's Photo Albums
The tires are not the biggest point of the problem. That is just a lot of trailer for a Sequoia no matter how equipped...and more than I'd like to tow behind any Tundra.
Start here...
-inflate all the tires to the max shown on the sidewall. If you need tires, you could consider LT265/70-17 Load Range E tires for more stability, but not 80 psi on the stock wheels, maybe max of 50.
-Consider upgrading to Bilstein HD shocks.
-Use a superior sway damping hitch, either "Equal-i-zer" brand or a weight distributing hitch with the Drawtite/Reese/Hidden Hitch #26000 dual cam kit.
-Use a superior brake controller...Brakesmart, Jordan (my favorite), or Tekonsha Prodigy.
-Don't tow in overdrive.
Good luck.
Ken
You get what you inspect
Not what you expect.
Gibson exhaust system
Hellwig Rear Antisway Bar
Old 05-23-2005, 06:52 PM
RockyMtnRay's Avatar
2003 Toyota Tundra
RockyMtnRay's Photo Albums
Originally Posted by kericks
Hello;
Help!
Kevin
No mods.
Love it.
I agree with everything that Ken (KLS) said above. Your challenge is not the Seq's rear tires so much as the length of the trailer relative to the wheelbase of your Sequioia...a factor that can lead to uncontrollable sway. That's why Ken emphasized and I'll re-emphasize the importance of top-notch sway control on a weight distibuting hitch. Your trailer will have a tongue weight around 800 lbs when fully loaded but if you use a WDH with 1000 lb spring bars (and properly adjust those bars each time you hookup), only about a third of that tongue weight (or roughly 300 lbs) will be on the Sequioa's rear tires/rear suspension. The tires should easily be able handle an extra 300 lbs on the rear axle (150 lbs per tire).
When you do decide to replace the tires, consider getting an "LT" (light truck) series tire as those typically have stiffer sidewalls than "P" series tires you currently have. Stiffer sidewalls are more resistant to trailer induced sway of the tow vehicle's rear end. An excellent LT tire for towing is the Michelin LTX M/S in the 265/75R16 size...low rolling resistance, incredible tread life (70 to 90K miles is normal), excellent sidewall strength, and quite good traction. I'm extremely happy how well the Michelin LTXs I have work for towing as well as for general driving.
P.S. Your Sequoia is actually about as good for towing this trailer as the Tundra double cab because it has an equal GCWR (gross combined weight rating) but probably weighs less. The Tundra DC's biggest advantage is it has a longer wheelbase (better sway control).
Ray
Old 05-23-2005, 08:56 PM
Dealer : Lipton Toyota Scion
2004 Toyota Tundra
Last Online: 11-18-2009 03:21 PM
tuesdayd is on a distinguished road.
tuesdayd's Photo Albums
When my friend and I were researching to buy our trucks, we found that his Sequoia was more than 200 lbs heavier than my DC. Both are '04 4x2's. Not sure about 4x4's or the myriad of other configurations, but that's probably a good rule of thumb. And I'd imagine that most of that extra weight is going directly to the rear end since that's where the additional roof, extra glass and third row seat is.
2004 Salsa Red Pearl DC Limited 4x2
Toyota Mods:
Accessory Meter / Leather / LSD / Moonroof / Tow Package / Rear DVD System / Challenger Step Boards / Carpet Mats / Toyoguard
My Mods:
Debadged / Line-X / Window Tint to Match Rears / Hellwig Anti-Sway Bar / ORW Steering Rack Bushings / RAPS / VSE Subwoofer / Pop&Lock Power Tailgate Lock / Unichip / JBA's / Gibson Exhaust
Old 05-23-2005, 11:46 PM
2003 Toyota Sequoia
Default First Tow Home
OK; First trip home w/ the new trailer, and I must say, I am impressed!
Granted, no mountain passes were traversed, but the 35 miles or so towing the trailer home from the dealer I must say was awesome. I think the Seq. must be a bit tougher than it's refined looks would let on! Decent acceleration, stable in the corners, not a hint of sway, not even when blasted by passing semi's.
I don't doubt that I need to look seriously into some heavy-duty shocks, and some LTX Michellin tires, but for the upcoming holiday weekend, I think we will be fine.
Thank you for all of your advice!
Kevin
Old 05-24-2005, 01:39 AM
anmrivera's Avatar
Dealer : Performance Toyota Of Lavista
2003 Toyota Tundra,
2005 Toyota Sienna
Last Online: 09-01-2009 08:41 AM
anmrivera is on a distinguished road.
anmrivera's Photo Albums
I got 4 also and that is the reason I got my AC and not the DC. The DC does not have the front bench.
2003 Tundra 4x4 Access cab V-8, SR5, Silver Sky Metallic, TRD Off-Road package, Tow package, LSD, cold weather prep. package, Running boards, Convienence Package, Line-X bedliner, debadged, 4 window visors, Blue Cyber Eyes, $5 rs3200 upgrade , Fog light mod.
2005 Sienna LE 8 PAX, White, Full Curtain airbags, Tow prep package, VSC, Rear Disk brakes, rear audio, aftermarket entertainment center(will be bought soon)
I'm a proud Toyota Bigot!!!
Midwesterners checkout the midwest forum!Click here
Old 05-24-2005, 07:39 AM
2003 Toyota Sequoia
Oh, I didn't think about that! Does everyone fit comfortably in the AC?
R/
Kevin
