Old 05-25-2005, 08:27 AM
HockeyFreak's Avatar
Dealer : Leith Toyota
Last Online: 04-27-2009 08:06 AM
HockeyFreak is on a distinguished road.
Send a message via MSN to HockeyFreak HockeyFreak's Photo Albums
Default Bought a Travel Trailer!!
Wuu Hoo, my wife and I are very excited as we just bought our 1st travel trailer!! We got a Flagstaff (made by Forest River) 26BHSS. It is 26' long and weighs 4300 lbs empty and 6300 lbs GVWR. So, the tundra will do an excellent job towing it! We will be camping in it at the Coke-Cola 600 this weekend, then we are heading to Myrtle Beach the next weekend (for the SouthEast Meet!)
"If your not obsessing about something, you're probably not into it enough." - Chris Thile
2001 Tundra Limited *SOLD*
2005 Ford Excursion Limited PSD
1996 Ford F-250...Runnin' on Veggie Oil
1946 John Deere A
MODS: Hellwig, Custom Duals w/ Flowmaster 40 Series and Dr. Gas X-pipe, Daystar Bushings, Cornfed 2" Front Spacers, TRD AAL, K&N FIPK, 16x8 Weld Outbacks, 285/75R16 Yokohama Geolandar's, Access Cover, BedRug, Putco Bed Rails, PP Bull Bar, WeatherFlectors, Prodigy Brake Controller, Brown Bread Sound Deadener, '05 Taillights, AMSOIL ATF
Shawn
Southeast Region Forum
Old 05-25-2005, 08:46 AM
warrior's Avatar
Here for the long haul...
Dealer : Peterson Toyota
2001 Toyota Tundra,
2005 Toyota Corolla
Last Online: 01-23-2009 07:38 AM
warrior is on a distinguished road.
warrior's Photo Albums
Thumbs up Congrats!!
Congrats on the trailor purchase. We to bought our 1st trailor this past Saturday. It's only a 19' but it is just 1 kid and the wife and I (oh, almost forgot our two city rats-mini Dachshunds). It's an older one but it is in great shape. Going to get the Tundra wired this weekend and get some new shoes on the trailor this weekend as well. Can't wait to go camping now after many many years of camping via tent..........
Old 05-25-2005, 09:04 AM
RockyMtnRay's Avatar
2003 Toyota Tundra
RockyMtnRay's Photo Albums
Default Congrats! Be sure to use a properly adjusted WDH with high performance sway control
Congrats! Be sure to use a quality WDH (with at least 1000 lb spring bars) that has high performance cam type sway control. With a relatively long 26 foot trailer (relative to your Tundra's wheelbase), you will need every bit of sway control you can get.
When adjusting the WDH, before hooking up the trailer, measure the distance from the top of the wheel arches over the front and the rear wheels to the ground and write these numbers down. After hooking up the trailer, measure those same front and rear arch-to-ground distances again and adjust the WDH spring bars (by dropping links) until the change in arch-to-ground distance (squat) is the same on the front as it is on the rear. If the rear squats more (typical), you simply haven't adjusted the WDH tight enough. This is probably the most mis-understood part of using a WDH...way too many people buy a WDH but don't snug the spring bars tight enough (a drop of 5 to 6 links is normally needed) and then try to fight remaining sag with truck suspension changes. As has been preached many times before, do not try to counter trailer induced rear sag/nose high front with changes to the truck's suspension...trailer induced sag must be countered by the springs in the WDH!
Tip: After the trailer is hooked to the truck...and the ball latch closed but before you hook up the WDH spring bars...use the tongue jack on the trailer to lift the trailer tongue with truck attached to slightly above the truck's unladen hitch height. Then hook up the spring bars...if the tongue/hitch are together lifted high enough, the spring bars can be easily deflected enough to get a 5 or 6 link drop. Otherwise, it's very difficult to deflect the bars enough to get a sufficient number of links dropped. Once the spring bars are attached, then raise the tongue jack. An electric tongue jack greatly speeds this process, BTW.
Ray
Old 05-25-2005, 11:48 AM
No problem Ray!! We are getting a Reese Straight-line WD hitch (w/1200lb bars) with the Dual-cam sway control installed and adjusted by the RV dealer on Friday. Safety is the 1st priority.
http://www.reese-hitches.com/straight_line_hitch_wd.htm
1946 John Deere A
Shawn
Old 05-25-2005, 01:16 PM
anmrivera's Avatar
Dealer : Performance Toyota Of Lavista
2003 Toyota Tundra,
2005 Toyota Sienna
Last Online: 09-01-2009 08:41 AM
anmrivera is on a distinguished road.
anmrivera's Photo Albums
Pics, Pics, Pics! I like to see pics of our trucks being used as trucks! LOL
2003 Tundra 4x4 Access cab V-8, SR5, Silver Sky Metallic, TRD Off-Road package, Tow package, LSD, cold weather prep. package, Running boards, Convienence Package, Line-X bedliner, debadged, 4 window visors, Blue Cyber Eyes, $5 rs3200 upgrade , Fog light mod.
2005 Sienna LE 8 PAX, White, Full Curtain airbags, Tow prep package, VSC, Rear Disk brakes, rear audio, aftermarket entertainment center(will be bought soon)
I'm a proud Toyota Bigot!!!
Midwesterners checkout the midwest forum!Click here
Old 05-25-2005, 01:48 PM
I'll have pics for you on Monday or Tuesday!
1946 John Deere A
Shawn
Old 05-25-2005, 08:25 PM
TundrastruckDave's Avatar
Dealer : Greenville Toyota
Last Online: 11-22-2009 10:16 PM
26'?!
ALL that room for just two folks and a dog?! Hmmm... ya' know... a good friend would invite his buddy and his wife (just east of him) to stay with he and his wife (considering all that room of course) at the next Myrtle Beach Meet!
Mods to Date:
Mods to Come:
265/75/16 BFG A/T's,
Possible Mods:
Old 05-25-2005, 08:46 PM
2003 Toyota Tundra
Default Good choice!
Excellent! That's exactly the kind of hitch you should be using.
Just be sure to properly tighten those spring bars to get equal squat on the front and rear suspension of the truck. As I mentioned above, this is the part that so often is not done right, in part because very high levels of effort are necessary to cinch those spring bars up if you don't use the tongue jack to pre-lift the tongue and truck.
Ray
Old 05-26-2005, 07:41 AM
So Dave....which do you want..the couch or the table converted to a bed??? Dave, seriously y'all are welcome to swing by and hang out Saturday night!!
We are very excited!
1946 John Deere A
Shawn
Old 05-26-2005, 09:11 AM
Soooo... is this an invitation to stay or just to "hang out"?!
Mods to Date:
Mods to Come:
Possible Mods:
Old 05-26-2005, 11:39 AM
If you can get the dog off the couch!!!!
1946 John Deere A
Shawn
Old 05-26-2005, 09:34 PM
shawnocaster's Avatar
Dealer : Denny Hecker's Toyota
Last Online: 02-01-2006 10:15 PM
shawnocaster is on a distinguished road.
Send a message via Yahoo to shawnocaster shawnocaster's Photo Albums
I am sooo jealous! We are still tenting but mostly because we end up towing our ATV's with. I want to get the camper with the drop down back door. The last 6-10 feet are for ATV's. Someday! I've seen a few of them out there.
2001 Tundra V8 SR5 Access Cab, 4X4, TRD Off Road, Debadged, Westin nerf bars, push bar, & tailight covers, Leer XL 100 topper, Lund bug deflector, Ventshade window visors
Aero Turbine 3030 muffler w 3" inlet/outlet pipe and 3040 tip
Old 05-27-2005, 12:29 AM
anmrivera's Avatar
2003 Toyota Tundra,
2005 Toyota Sienna
HAte to be the bearer of bad news but most of those are too heavy for our trucks!
Old 05-27-2005, 09:43 AM
sequoiasoon's Avatar
Dealer : Competition Toyota Scion of Middle Island
2003 Toyota Sequoia,
- Other - 93 Corolla TOTALLED!
Last Online: 11-03-2009 08:17 AM
Images: 8
sequoiasoon is on a distinguished road.
sequoiasoon's Photo Albums
Weekend warrior has their "lite" models that check in at about 4,000 lbs to 5,000 lbs (of course unloaded) http://www.a1warriortrailers.com/fk_.../6fk-specs.htm
Old 05-28-2005, 12:35 AM
Thanks for the link on the trailers. I had not seen that manufacturer before.
'05 Sequoia Towing ? tuckernotis Towing 8 01-12-2005 07:15 PM
Tundra for Towing? steve_peq Towing 10 10-11-2004 10:18 AM
Travel trailer towing ?????? Stlmatt Towing 2 07-13-2004 08:01 AM
Travel Trailer weight questions wlafed Towing 8 07-12-2004 01:15 AM
Renting a Travel Trailer - Questions Brian M Towing 20 06-01-2004 12:26 PM
