Old 05-25-2005, 08:49 AM
Last Online: 09-01-2005 03:48 PM
Pitbull is on a distinguished road.
Pitbull's Photo Albums
Default 4th Generation 4runner towing experiences/stories
Who has towed what/where with the new 4runner? What size trailer and what was your experience. Planning on moving a few thousand miles away and will be taking several pets and other stuff I don't want a mover to touch. What did you do to prepare your 4runner?
Thanks
Springfield Missouri
2004 4runner Sport V-8 4x4
2003 350Z
Old 07-12-2005, 05:54 PM
04DSGTUNDRA's Avatar
Dealer : Toyota of Glendora
2006 Toyota Tundra AC Limited 4WD
Last Online: 10-22-2009 02:29 AM
04DSGTUNDRA is on a distinguished road.
04DSGTUNDRA's Photo Albums
I helped family move with our v8 4-runner. Towed a 14 ft. open trailer, loaded it up pretty good, plus loaded the inside of the 4runner. Towed pretty nice, i'm sure you wont have a problem, word of advice, dont follow to closely, as it takes longer to stop...... good luck!!!
2006 Black Limited 4WD TRD Tundra
Present.
2004 Phantom Gray Limited TRD Tundra
RIP.
Old 07-12-2005, 11:53 PM
RockyMtnRay's Avatar
2003 Toyota Tundra
RockyMtnRay's Photo Albums
Default Make sure the trailer has brakes
Thanks
Keep the total trailer weight under about 5000 lbs, the trailer length under about 20 feet, and be sure the trailer has some kind of brakes...surge work just fine for a one time trip. Towing a trailer that weighs over about 1000 lbs without trailer brakes is like playing Russian Roulette...your stopping distances get so long that even with a lot of prudent driving, there's a very good chance some idiot will pull in front of you then slam on their brakes, and you'll smash into them. And you'll immediately be "at fault". UHaul trailers have surge brakes...if you don't/won't use a UHaul, make sure the trailer has some kind of good brakes.
Ray
Old 08-03-2005, 01:35 AM
Last Online: 10-09-2005 11:41 PM
khaug is on a distinguished road.
khaug's Photo Albums
Thanks
Excellent advice from Ray! I've towed a car on an open trailer (~4,000#) for 10,000 miles with our '03 Limited. It's an excellent tow vehicle. Be sure you descend grades in a lower gear that lets you avoid using the brakes. Load the trailer so it has 10% or so of the weight on the tongue (i.e., 4,000 total trailer = 400# tongue weight).
Expect ~14 mpg, depending on trailer weight and aerodynamics. Don't worry about stuff like tranny or coolant temp - Toyota takes care of that for you. Take it easy - don't push. Leave at least twice the usual distance between you and the car ahead. Make wide turns. 65 mph is a good cruising speed.
Good luck!
-Karl
Fifth Wheel Towing & Hitch Questions/Help/Info yay Towing 300 07-22-2009 11:41 PM
rock sliders for 4th gen 4Runner? paulphilly 4Runner 6 01-18-2005 01:44 PM
4th generation vibration at certain rpm's? Pitbull 4Runner 6 06-18-2004 08:21 PM
Towing a 4x4 (bad clutch on 4runner) file014 Towing 3 04-12-2004 01:30 AM
4th generation 4runner is the exhaust system stainless steel? Pitbull 4Runner 0 04-07-2004 04:17 PM
