Old 06-19-2005, 03:55 PM
Dealer : Moose Jaw Toyota
2003 Toyota Tundra White Regular Cab,
1995 Toyota Tercel 1994 base tercel,
2009 Toyota Matrix Pontiac Vibe
Last Online: 10-20-2009 03:43 PM
file014 may have some regrets.
file014's Photo Albums
Default Tow questions for '03 V6 regcab
I have the regular cab 2003 V6 Tundra work truck. It came with factory hitch and 4 pin trailer light wiring. I am thinking of towing a Uhaul closed trailer about 1000 miles. I am thinking I need to get a brake controller installed, since the trailer would probably weigh 2500-3000 lbs with furniture loaded. Is this something I could do myself or should I pay for the install? I wanna make sure it is done right and I wont have a lot of time to work on it though.
Thanks,
file014
Old 06-19-2005, 05:10 PM
Buzzard's Avatar
Dealer : Gulf Coast Toyota
2006 Toyota 4Runner
Last Online: 11-25-2008 05:44 PM
Buzzard is on a distinguished road.
Buzzard's Photo Albums
Smile
Thanks,
file014
I put one of them in (about 30 + years ago). Been to long to remember the details but I dont remember it being that hard. I had to do it myself ---Didnt have the cash to pay anybody ----Buzz
Old 06-19-2005, 07:53 PM
Dealer : Toyota of Greensburg
2005 Toyota Tundra
Last Online: 11-08-2009 07:50 AM
cookiemech is on a distinguished road.
cookiemech's Photo Albums
I thought that all of the U-Haul trailers that required brakes had surge brakes (so no controller needed). Installing a controller in that situation wouldn't help anyway, since there would be no place to plug it in.
Generally speaking, brakes aren't required on any trailer with 3000 lb. GTW or less.
Old 06-19-2005, 10:31 PM
RockyMtnRay's Avatar
2003 Toyota Tundra
RockyMtnRay's Photo Albums
Default UHaul trailers have surge, not electrical brakes
That is correct. UHaul knows that few, if any, of the folks who will rent their trailers have a brake controller so they equip all their trailers with surge brakes.
A brake controller is therefore not needed to tow a UHaul trailer.
Generally speaking, maybe. Specfically speaking about towing with a Tundra (all models, all years), trailer brakes are a virtual necessity anytime the trailer weight is over 1000 lbs (not 3000 lbs). Toyota specifies 1000 lbs as the maximum trailer that should towed without trailer brakes in the owners manual for a very good reason...the truck's brakes are barely adequate to stop the truck itself, much less the weight of a trailer. If you look through the hundreds of posts in the Brake forum, you'll likely be amazed at how many people have overheated/warped their truck's brakes in just normal, non-towing driving...and how many people wear out their front brake pads in less than 10,000 miles. The problem is that Toyota basically equipped the Tundra with Tacoma brakes (along with other Tacoma parts like the suspension pieces, axles, differentials, etc.).
Ray
Old 06-20-2005, 02:15 PM
KLS's Avatar
KLS KLS is offline
KLS's Photo Albums
Depends on both state law and the tow vehicle. Washington has a 3000# trailer brake requirement, California 1500# requirement, Tundra 1000#. For a Tundra, I would not exceed the trucks GVWR, 6000# combined truck and trailer weight, without trailer brakes. If I had the truck heavily loaded, I'd want brakes on any trailer I pulled.
Ken
You get what you inspect
Not what you expect.
Gibson exhaust system
Hellwig Rear Antisway Bar
Old 06-20-2005, 03:50 PM
lelandstanford's Avatar
2005 Toyota Tacoma
Last Online: Yesterday 04:57 PM
lelandstanford is on a distinguished road.
lelandstanford's Photo Albums
I rented a pop-up RV trailer once. It's a Starcraft weight about 1500# and has not brakes of any kind.
2005 Tacoma AC 2WD 2.7L 5M
Fifth Wheel Towing & Hitch Questions/Help/Info yay Towing 300 07-22-2009 11:41 PM
Alot of supercharger questions PWNDLOL Engine & Drivetrain 2 06-25-2005 02:22 AM
TACOMA:Anyone Tow with an 05 Tacoma? j4x4ar3 Towing 18 06-09-2005 05:21 PM
Interior fit & trim questions (Sequoia) LSUMBA Interior & Exterior 6 01-28-2005 10:10 AM
newb question about tow hitch and ball dfinn Towing 7 04-30-2004 03:58 PM
