Old 07-12-2005, 01:55 AM
Dealer : Lethbridge Toyota
Last Online: 11-19-2009 01:38 PM
thumper400 is on a distinguished road.
thumper400's Photo Albums
Default Help with brake controller
I just bought an 05 DC and saw the wiring harness in the glove box. I plan on getting a small toyhauler and want to wire it up for brakes. I've never had a trailer that needed a brake controller. What do I do? Does it plug in under the dash somewhere then I have to run longer wires to the back? I'm kind of clueless with this subject? Help!!
Old 07-12-2005, 09:18 AM
sprj8008's Avatar
Toy Junkie
Dealer : High River Toyota
2002 Toyota 4Runner,
2003 Toyota Sequoia
Last Online: 11-07-2009 01:21 AM
sprj8008 is on a distinguished road.
sprj8008's Photo Albums
Your brake control will wire into the harness. Then you plug in the harness connector. That's it. The wires already exist between the kick panel and the hitch.
Jason.
Jason
2002 4runner SR5 leather.
Old 07-12-2005, 11:20 AM
Herbicidal's Avatar
Just a Herbicidal maniac.
2001 Toyota Tundra,
2008 Toyota Yaris Sedan 'S' Flint Mica,
2009 Toyota Corolla 'S' Barcelona Red
Last Online: 11-20-2009 01:17 PM
Images: 150
Herbicidal's Photo Albums
Do yourself a favor and get the Prodigy brake controller. You should be able to find it for @ $100 or less. You can also get a wiring harness specific to your '05 that should allow you to just plug in. The wiring harness can be bought from Tekonsha. Here's a link: http://www.tekonsha.com/prodig.html
Hope this helps.
Old 07-12-2005, 12:36 PM
KLS's Avatar
KLS KLS is offline
KLS's Photo Albums
Here's another vote for the Tekonsha Prodigy or identical Drawtite IntellaBrake Ultra.
I prefer the Jordan Controller but it is a bit more work to install.
Ken
You get what you inspect
Not what you expect.
Gibson exhaust system
Hellwig Rear Antisway Bar
Old 07-12-2005, 03:21 PM
j4x4ar3's Avatar
Dealer : Tracy Toyota
2005 Toyota Tacoma
Last Online: 10-19-2009 10:49 PM
j4x4ar3 is on a distinguished road.
j4x4ar3's Photo Albums
And one more vote for the Prodigy. I have an 05 and I got the vehicle specific harness from e-trailer.com plugs right in. I ended up mounting it in the little cubby hole in the center column of my automatic DC. Ran the wire up behind the dash and plug right into the factory wiring. Looks very clean and works like a charm. I have a 5000# travel trailer and with the Prodigy both the truck and trailer stop smoothly in tandum. No bumping, jerking or bouncing. Best investment ever made.
Tacoma V6 Auto 4x4 Double Cab 128"
White
TRD Off-Road
TRD CAT Back Exhaust, Bed Mat, Husky Floor Mats, Wildcat Flash Nerf Bars, Prodigy Brake Controller, In Dash cell phone mount, Cargo Bars w/Thule Ski & Bike Attachments, Toyo Open Country A/T Tires (Stock Size)
26' Travel Trailer GVWR 6000# with 800# WD hitch.
Old 07-12-2005, 04:40 PM
Dealer : Toyota Scion of Tri-Cities
2001 Toyota Tundra Stellar blue,
2007 Toyota Tundra slate DC 5.7 4WD Ltd
Last Online: 10-21-2008 07:03 PM
StellarTundra is on a distinguished road.
StellarTundra's Photo Albums
I just bought the Odyssey from Valley Industries, because I found it locally for $100, whereas the Prodigy was $145. It appears to work just like the Prodigy, plus I won't be able to destroy it by hooking it up backwards. I haven't used it yet, and my truck seems to brake the trailer fine without it so there probably won't be much noticeable effect, but I thought I'd mention that there does appear to be a copycat on the market now.
Blues,
Dave
Old 07-12-2005, 05:04 PM
Herbicidal's Avatar
2001 Toyota Tundra,
Images: 150
One more thing, Camping World (if you have a store near you) will price match internet ad's providing you print it out and bring it to the store. Include the cost of shipping with the internet ad. You do not have to be a member of Camping World to get the discount. I did this last week and saved $45 over their in store price. I walked out of there feeling like I stole it.
Old 07-12-2005, 09:43 PM
Hope this helps.
I looked for the wiring harness on that website and they only list up to an 03. Is that the best price for the prodigy? I also read on etrailer.com that it requires to put in a seperate circuit braker for this piece. Is this true?
Old 07-12-2005, 09:47 PM
KLS's Avatar
KLS KLS is offline
KLS's Photo Albums
rvwholesalers.com is $99.
Every brake controller needs power. It comes off the + terminal in the fuse panel, through an auto-reset circuit breaker, and to the controller. Depending on the controller, you'll need #12 wire and a 20 amp breaker or #10 wire and a 30 amp breaker. Or there might be a spot for a fuse already in your fuse panel...check. Use the fuse size recommended by the controller maker.
Ken
Old 07-21-2005, 05:35 PM
Dealer : Burt Toyota
2003 Toyota Tundra
Last Online: 04-24-2006 07:21 PM
denverbikeguy is on a distinguished road.
denverbikeguy's Photo Albums
Ken
One more vote for the prodigy, I have it and love it.
As for power ... mine draws from the factory connector. I did not need anything other than a harness and the controller, I actually spent more time mounting it than I did with the electrical. It is really a plug and play thing if you have the factory tow package.
Old 07-22-2005, 01:56 AM
Unfortunately my truck is an '01, so while I got the factory tow package, I didn't get the plug & play features. Tonight I ran my charge line, this weekend I need to install my brake controller, do a front brake job on the truck, and shop like mad to outfit my new trailer appropriately. Anyone with an "older" Tundra want to tell me what was an easy/difficult place to pop through the firewall? I took a cursory glance up under the dash above the brake pedal tonight, and I'm assuming the clip above the "piston" mechanism is where I'll find two wires, one of which will be "cold" except when the brake is depressed.
I'm getting close enough to my vacation that I'm considering not messing with stuff anymore so I don't screw something up that I don't have time to fix. I know my truck brakes itself & my (2800 lb) trailer well enough without a controller, so should I hold off lest I hit something bad trying to punch a hole in the firewall or fry something trying to tap into one of the wires on the brake pedal?
Blues,
Dave
Installing a Brake Controller dwagner825 Towing 6 05-28-2009 02:38 AM
Brake Controller Wiring JANDA Towing 7 03-22-2007 12:54 PM
DJ's trailer brake controller wiring instructions nhparrot Audio & Stereo 1 07-03-2006 12:28 AM
05 Tundra brake controller wiring rovic Towing 4 03-26-2005 09:34 PM
INFO: Trailer Brake Controller nhparrot Electrical & Computer Systems 0 08-12-2002 07:09 PM
