Go Back   Tundra Solutions Forum > Technical & Vehicle Assistance Forums > Towing
Old 07-21-2005, 05:38 PM
Last Online: 11-13-2006 05:31 PM
pmw2tua is on a distinguished road.
pmw2tua's Photo Albums
Default Junking Magnaflow cat back for new tow requirements
I just bought a boat and after reading the increasing low end torque problems associated with an after market larger diameter cat back exhaust system, I want to replace the magnaflow 3" exhaust. I was thinking about going with JBA headers with either a gibson 2-1/2" cat back (since the old stock sytem is long gone), or a JBA 2-1/2" cat back system. The headers I have pretty much decided on, but I am having trouble picking between the gibson or the JBA exhaust. Any preferences between the two? Any experiences? Will this set up work well towing?
Thanks for any input?
Oh ya- 2001 Tundra TRD Excab 4X4
Old 07-21-2005, 05:51 PM
Dealer : McGeorge Toyota
2004 Toyota Tundra
Last Online: 06-04-2008 08:56 PM
Xtrema is on a distinguished road.
Xtrema's Photo Albums
Perhaps you can just rev the engine to develop enough torque and maintain the 3 inch system? I have been learning to adjust my expectations on torque vs. rpm as I transition from American to Toyota truck.
Old 07-23-2005, 10:57 PM
RockyMtnRay's Avatar
2003 Toyota Tundra
RockyMtnRay's Photo Albums
Default How much continuous noise can you tolerate?
Both the Gibson and JBA will probably be roughly equal for peak torque, though I (and several others) have found the peak torque RPM with a Gibson seems to be lower than the published numbers for JBA's Evol catback...and reaching peak torque at a lower RPM is better. Specifically, JBA's published numbers for the combo of their headers and exhaust show a peak torque around 3800 RPM (400 RPM higher than stock); with JBA headers and a Gibson muffler installed in the stock exhaust pipe, my peak torque is around 3200 RPM (200 RPM below stock) and I get noticeable torque onset as low as 2500 RPM. My headers/muffler combo has essentially made my truck perform more like a turbo diesel than a typical gas powered truck...so it's really great for towing.
The JBA system uses a traditional design glasspack muffler; the Gibson muffler has a pair of parallel perforated pipes (one on the inlet side, one on the outlet side). The Gibson's design flows very freely yet leads to it becoming increasingly quieter the more you open the the throttle (and wide throttle openings are common in towing); the JBA will become increasingly louder the more you open the throttle.
So it boils down to how much noise and drone you can stand for extended periods. I personally have no tolerance for sustained noise because I find it very fatiguing after an hour or so. Therefore I chose a Gibson because it provides excellent torque at low RPM for towing but no added noise.
Ray
Old 07-25-2005, 07:51 PM
Dealer : Longo Toyota
Last Online: Yesterday 09:25 PM
2000LtdKen is on a distinguished road.
2000LtdKen's Photo Albums
Default Go with RockyMtnRay on this....
pmw2tua,
I followed RockyMtnRay's advice on my truck (2000 Ltd 4x4) because I tow also. I put on the JBA Headers and had a Gibson Muffler welded into my stock exhaust and my truck runs beautifully. Got a nice torquey feel down at low RPM's where you can feel it. I towed my small trailer with quads and motorcycles on it and you can tell the difference in towing power. I can't wait until later this year to tow my big trailer to see what that is like.
Also on the noise thing. I work with a guy that put the Magnaflow's on his truck. It was annoying riding around. Too much sound. When I put the Gibson on my truck it is in between stock and a Magnaflow and does get quieter the faster you go. Around town it rumbles really nicely at idle and low rpm.
Ken
Old 07-25-2005, 08:42 PM
cleanb13's Avatar
Dealer : Boch Toyota South
Last Online: 11-06-2009 05:44 PM
Images: 20
cleanb13 is on a distinguished road.
cleanb13's Photo Albums
I was in the same boat that you're in now. I tow snowmobiles and I had a 2 1/2" Gibson w/o headers. I lost all my low end torque so I took off the Gibson and bought a Spintech muffler, welded it to the stock pipes and got my torque back. (I also took off the K&N cold air kit too) I got tired of the drone at 2k rpms so I cut the spintech off and bought a Magnaflow muffler and I couldn't be happier now. No drone, nice sound and got my torque back. I also installed the JBA headers which made a big difference too.
2001 Tundra TRD Access Cab 4x4, SAW/Camburg coilovers, TC diff drop kit, Wheeler's Offroad AAL and Bilstein 5100's, LT265/75R16 BFG AT KO on Wheeler's black alloys, True Flow intake tube and filter with a modded air box, JBA titanium coated headers, Magnaflow 11226 muffler with stainless steel pipes and resonator removed, Skidrow front skidplate with custom made aluminum side shields, extended rear diff breather hose, Hawk LTS brake pads, Wheelers stainless brake hose kit, Helweig swaybar, Downey Offroad front swaybar link kit and cv joint boots,TRD "posi" 3rd member, debadged, backseat-power outlet-map lamp-taillight mod, Optima red top, TRD mirror covers painted flat black, Viair 300P air compressor, blacked out mouldings, bumpers and grille emblem
Old 07-31-2005, 11:57 PM
Big_Al1's Avatar
veteran member
Dealer : Lake Charles Toyota
2005 Toyota Tundra,
2008 Toyota Sienna XLE
Last Online: Today 08:08 AM
Images: 16
Big_Al1 will become famous soon enough.
Send a message via Yahoo to Big_Al1 Big_Al1's Photo Albums My eBay
Default magflow
what are you doing with old exhaust
Old 03-11-2008, 10:35 PM
Tundra Guy's Avatar
Dealer : Avondale Toyota Scion
2006 Toyota Tundra,
2001 Toyota 4Runner SE with Moon Roof
Last Online: 05-18-2009 11:05 AM
Tundra Guy is on a distinguished road.
Send a message via ICQ to Tundra Guy Send a message via AIM to Tundra Guy Tundra Guy's Photo Albums
Default Re: Junking Magnaflow cat back for new tow requirements
Which model of Magnaflow did you go with? Thanks.
"Modern computers allow mankind to create and propagate errors at a rate of millions of times per second. We can now screw things up faster than the human mind could ever possibly comprehend!!!!"
-- Jimmy the Tundra Guy
Old 03-13-2008, 03:42 AM
Tundra Guy's Avatar
2006 Toyota Tundra,
Sorry. "Which SPINTECH muffler did you go with...???" <not which Magnaflow> - obviously not enough coffee!
Old 03-13-2008, 12:25 PM
Dealer : Lagrange Toyota
Last Online: 11-02-2008 07:33 AM
Images: 3
Kevo is on a distinguished road.
Kevo's Photo Albums
I've had no problems with my custom Magnaflow setup. 2.5" piping with 14" Magnaflow muffler...it yanks my boat around wherever I want it, sounds damn good too!
Boat is a 2006 Tahoe Q6 (around 21ft.)
2006 Tundra Double-Cab X-SP 4WD
2.5" piping w/ Magnaflow (clip in gallery) - OBX Pedals - 20% Tint - DEBADGED!
Pioneer Z1 w/backup CAM & ipod - Painted Brake Calipers - ATE Slotted Rotors + Pads
2.5 Daystar w/ AAL - 275/55/20 Toyo A/T
Fifth Wheel Towing & Hitch Questions/Help/Info yay Towing 300 07-22-2009 11:41 PM
hmm.....cat back systems dktundra_01 Engine & Drivetrain 11 06-20-2007 09:51 AM
CAt back exhaust TRD meangean Engine & Drivetrain 8 12-03-2004 03:35 AM
Anyone tried 2000-2004 cat back on '05 tundra? JeffD Engine & Drivetrain 6 10-27-2004 10:14 AM
How difficult to install a TRD (or similair) Cat Back exhaust? Plamar 1Gen-Sequoia 5 07-25-2004 01:33 AM
