Old 07-28-2005, 02:00 AM
Dealer : Lethbridge Toyota
Last Online: 11-19-2009 01:38 PM
thumper400 is on a distinguished road.
thumper400's Photo Albums
Default Weight Distributing Hitch
Never used one. I'm getting an 18ft Toyhauler and pulling with my 05 Tundra DC. What's a good one to get and where?
Thanks
Old 07-28-2005, 08:35 AM
Dealer : Dick Milham Toyota Scion
2005 Toyota Tundra
Last Online: 07-14-2009 08:12 AM
chrispitude is on a distinguished road.
chrispitude's Photo Albums
Hi Thumper,
After doing some forum searches, it seemed like the Equal-i-zer was a good weight-distributing and anti-sway hitch. You can see the product page at
http://www.equalizerhitch.com
I got mine from
http://www.rvwholesalers.com/
They had the best price of all the online vendors I checked. You'll want to order the hitch balls from them too. This hitch uses hitch balls that you will not find at your local hardware store. It requires hitch balls with a 2 1/4" long by 1 1/4" diameter threaded shank.
And now the fun part - for a 1 1/4" diameter shank, you need to torque the 1 7/8" nut down to 450ft-lbs. I took it to a truck shop, and they could not get their socket on it. I called Equal-i-zer and it turns out that they manufacture a special thin-wall 3/4" drive socket for this purpose. Their dealers have this socket, but this doesn't help me since I ordered online. Equal-i-zer sells the socket for $25 plus $6 shipping, so I ended up ordering one so I could swap between the 2" and 2 5/16" balls myself. If you are only ordering one ball, you might be able to ask RV Wholesalers to pre-install this for you. I also needed a 1/2"-to-3/4" drive adapter, and a 1 1/8" socket and wrench for the hitch head nuts/bolts.
- Chris
2005 Tundra V8 4x4 regular cab, Phantom Gray, Line-X, Jeraco cap, 245/75-16 Goodyear Wrangler SilentArmors, 245-75R16 Firestone Winterforce snows in winter - nickname: "Gaspig"
Old 07-28-2005, 11:42 AM
HotRod8's Avatar
Lifetime Member
Dealer : Stampede Lexus Toyota
2003 Toyota Tundra,
1996 Toyota Corolla DX Plus
Last Online: 11-19-2009 10:49 PM
HotRod8 is on a distinguished road.
HotRod8's Photo Albums
I bought a regular (not thin wall) socket of the correct size; it was about 1/2" too long. I cut it down with a hack-saw, works like a charm.
Old 07-29-2005, 07:19 AM
2005 Toyota Tundra
Hi HotRod,
That would have been nice to know. Why was the socket too long? Was it binding at the bottom of the recess?
- Chris
Old 07-31-2005, 06:18 PM
HotRod8's Avatar
Lifetime Member
2003 Toyota Tundra,
Sorry it took so long for me to reply, I couldn't figure out how to explain this. I ended up taking some photos of the socket and hitch. I have included a description of the issue in this photo:
http://www.tundrasolutions.com/photo...0/ppuser/11636
I also have a few other photos in my gallery of the socket and hitch.
Old 07-31-2005, 07:06 PM
2005 Toyota Tundra
Great pics, HotRod! How many washers did you end up using between the shank and the hitch head? The manual says five is a good starting point, but that tilts the head down quite a lot.
My first of use will be for a rental trailer, so I'll be doing all this measuring and fine-tuning out in the rental store parking lot.
- Chris
Old 07-31-2005, 08:19 PM
HotRod8's Avatar
Lifetime Member
2003 Toyota Tundra,
I used 5 washers. I initially had 4 when I originally set up the hitch head, before I actually got my trailer. I found that I didn't get enough weight transfer to the front wheels so I added the 5th washer.
Old 08-21-2005, 03:25 PM
Dealer : Courtesy Toyota
2003 Toyota Tundra
Last Online: 09-06-2009 04:08 PM
ericb is on a distinguished road.
ericb's Photo Albums
Thanks for the info, Chrispitude! I saved well over $200 versus buying from my RV dealer by ordering my Equil-i-zer hitch from RVWholesalers.com. Plus I got the right tools for the installation from your directions.
Eric
Originally Posted by chrispitude
Hi Thumper,
I got mine from
- Chris
2003 Tundra Access Cab SR5 V8 4X4
RAPS, C.R. Lawrence Slider Rear Window from Yipes!, Hellwig Rear Anti-sway Bar, ASA TRS alloys, 265/70-16 Firestone Destination AT tires, debadged doors, ARE MX series cap, WeatherTech front floor mats, Scanguage II gauge & code scanner
Receiver? H2O_MAN Towing 1 03-11-2005 07:55 AM
'05 Sequoia Towing ? tuckernotis Towing 8 01-12-2005 07:15 PM
Too much to pull? ChuckBennett Towing 22 01-12-2005 07:06 PM
Tundra for Towing? steve_peq Towing 10 10-11-2004 10:18 AM
TBDW Can I tow trailer with 780# hitch weight? Tundratow Towing 3 08-10-2003 07:45 PM
