Old 07-28-2005, 08:56 PM
2005 Toyota Tundra
Last Online: 04-01-2007 03:45 PM
skater911 is on a distinguished road.
skater911's Photo Albums
Default Custom exhaust or stock Exhuast for Tundra.
I have a 2005 Tundra V8 Sr5 with TRD off road package and the TRD limited slip diff. I was thinking about adding an exhaust for maybe a little bit of a performance boost, but mainly for sound. Here's the deal, I will in the future be towing a sandrail and a couple of quads probably no more than 4000 lbs. I have seen the threads about cat back systems being detrimental to torque. That is the one thing I refuse to give up. I spoke to a local shop who advise the best route is to go 3 inch pipe for the intermidieate pipe to the muffler (he advised on flowmaster) then 2.5 for the tail pipe. He said that going back down to the 2.5 will regain any torque the 3 would have lost, thuis creating more back pressure. Should I go with this or just stay with my stock exhaust?
Thanks again.
Also do intakes hurt your torque curve???
Old 07-28-2005, 10:44 PM
RockyMtnRay's Avatar
2003 Toyota Tundra
RockyMtnRay's Photo Albums
Default Your muffler shop guy is totally and completely full of crap!
Thanks again.
Your muffler shop guy so full of ignorant crap that I would run as fast as I could as far as I could from that shop.
First of all, you don't want any backpressure ever...it's evil and kills performance. Second, oversized pipes (and 3 inch pipes are definitely oversized) actually produce more backpressure than the stock 2 3/8 inch pipe below about 3500 RPM. Even 2 1/2 inch pipe is too big for this engine, particularly at low to mid RPM and produces more back pressure than the stock pipe. Finally, a Flowmaster is the worst possible muffler you could ever choose for towing if you want to keep your low to mid range torque and your hearing. Even a 40 series FlowRestrictor muffler has barely a third of the flow of a decent muffler like a Dynomax...and the 50 and 70 series (particularly the Delta series) are even worse. And compounding the problem, a FlowRestrictor makes so much noise that your hearing (and brain) will be numb and fatigued after just a couple of hours of towing.
The reason that any exhaust over 2 3/8 hurts low/mid performance...and produces more backpressure than stock...is that it allows too much expansion and cooling of the exhaust gas. The expanded/cooled exhaust gas acts like a huge plug inside the exhaust system...and creates increased backpressure. Allowing the gas to first expand/cool inside a 3 inch pipe and then constricting it back to a 2 1/2 inch pipe is even worse.
If you're not ready to do this correctly (i.e. install headers first), then at least install a decently flowing muffler in the stock tailpipe. If you want a noticeable sound, use a Magnaflow or possibly a Dynomax. If you want quiet, use a Gibson. But whatever you do, don't be so stupid as to install a noisy, restrictive FlowRestrictor in the hopes you will improve your towing performance.
And in any case, keep in mind that you don't own some domestic truck that was severely underengineered and has lots of easy to grab performance increases. As been said here many times before, Toyota's engineers have gotten all the "low hanging fruit" from a performance perspective. You will be extremely hard pressed to get any performance gains from an aftermarket exhaust until you remove the real "plug" in the exhaust system which is the stock manifold. In most cases, you will actually hurt your performance by going to an aftermarket exhaust unless you first replace the manifold with headers.
As for intakes, yes, most (particularly AEM and K&N) do hurt the torque curve below about 3000 RPM. There's very little dyno data for RPMs under 3000 but there are several reports here at TS from very credible members and they've universally reported loss of low to mid range torque, particularly for towing, on trucks with K&N intakes. The one possible exception to this loss of low end torque is the Volant intake; there are some indications that it actually helps low end torque.
Ray
Old 07-28-2005, 11:35 PM
2005 Toyota Tundra
Awesome info, thanks alot I was hoping you would see this post, I saw a lot of earlier posts you did.
I guess it is back to the drawing board.
Old 07-29-2005, 05:33 AM
07 firecrew's Avatar
Dealer : Cowboy Toyota and Scion
2007 Toyota Tundra superwhite crewmax
Last Online: 04-25-2009 07:46 PM
07 firecrew is on a distinguished road.
07 firecrew's Photo Albums
Wink exhaust
sorry to but in guys, but i installed the magnaflow(5x11x22) stainless, i think it's a #13586. i can tell you from experience, the 2.5 pipe, will out perform the factory system, everywhere. take it to the bank.
2007 SR5 crewmax Texas Edition 4x2
light gray leather interior
xm radio, bed liner
fog lights
swaybar
woodgrain interior
carriageworks grille
corsa exhaust
ARE LSll cover
chrome accent covers
Old 07-29-2005, 08:49 AM
2005 Toyota Tundra
What about your low end, how much did you lose?
Old 07-29-2005, 09:04 AM
H2O_MAN's Avatar
Obama lies ~ the economy dies
Dealer : Heyward Allen Toyota Scion
2002 Toyota Tundra 4WD long bed V8 SR5
H2O_MAN is a superior contributor. H2O_MAN is a superior contributor. H2O_MAN is a superior contributor. H2O_MAN is a superior contributor. H2O_MAN is a superior contributor. H2O_MAN is a superior contributor. H2O_MAN is a superior contributor. H2O_MAN is a superior contributor. H2O_MAN is a superior contributor.
H2O_MAN's Photo Albums
Following Ray's advise I have installed my JBA headers and will put at least 500 miles on the truck to let the ECU adjust.
I will then weld in a Gibson Superflow muffler and be done with my exhaust mods.
Sidebar:
I purchased the Gibson 788500S muffler and found
it was a little to long (24" body vs. 22" stock body length) --
This would require unwanted extra cutting to weld in place.
Stylinconcepts.com is letting me exchange the muffler
for the next smaller one (p/n 788200S with a 19" body).
The 788200S should weld into place easily
Old T100 items for sale
Thunder Gray Metallic
2002 REGULAR CAB - LONG BED - 4WD - V8 - SR5
TRD / Kazuma LSD made by EATON
Bilstein HD shocks
Michelin 8 ply E series radials
JBA headers
Hellwig rear bar
Line-X over the rail
2005 tail lights
OEM Door Sill protectors
TRD Off-Road front coil springs
Color matched LEER Hi-Top cap
Wet Okole Sport Seat Covers
Tinted Windows
OEM Rubber Bed Mat
OEM All-Weather mats
OEM Towing Package with Remote Transmission Cooler
Old 07-29-2005, 11:52 AM
dsrtrcr01's Avatar
2005 Toyota Tundra Doublecab TRD 2wd,
2001 Toyota Celica 17" Rims, TRD Bumper,
1995 Toyota Truck Pre Runner
Last Online: 11-20-2009 07:27 PM
Images: 11
dsrtrcr01 has blessed us with their presence. dsrtrcr01 has blessed us with their presence. dsrtrcr01 has blessed us with their presence. dsrtrcr01 has blessed us with their presence.
dsrtrcr01's Photo Albums
Default Hey there Neighbor
Thanks again.
I live in Esco as well. I took mine to Precision mufflers right off the 78. It is in San Marcos. I had a muffler welded in place of the stock one for I think around $60 (Not including the muffler price)???? It is off the rancho santa fe exit on the right side of the freeway when you are going west bound. It is a small hole in the wall shop but the guy does good work and knows alot about exhausts.
'05 Tundra DC TRD 2 WHL: The TOW truck, Spectra Mica Blue, with Kenwood H/U, Kenwood Amp and crossover. Infinity 6010cs, 10" Rockford SUB, 6 disc CD Changer mounted in Center console, SWI-X to retain steering wheel controls, 7" TV with DVD. Tinted Windows, Three chamber Flowmaster, Painted front chrome strip
Old 07-29-2005, 12:08 PM
Jordansrealm's Avatar
Dealer : Toyota of Huntington Beach
2005 Toyota Tundra,
Last Online: 11-18-2009 12:31 PM
Jordansrealm is on a distinguished road.
Send a message via AIM to Jordansrealm Send a message via Yahoo to Jordansrealm Jordansrealm's Photo Albums
I have your truck and currently I am running the JBA Headers and 2.5" Exhaust. I love it and it sounds awesome. The power band is now much smoother and much quicker. Dont get caught up in low-end loss with exhaust systems like everyone seems to. Adding an exhaust ONLY to your truck isnt going to hurt your system and even if you lose lets say a few pounds of torque the power, flow, and sound you gain are more than worth it. If you are ever in Orange County let me know and I will give you a ride.
Jordan
2007 Toyota Tundra 5.7L v8 4wd TRD Limited
Old 07-29-2005, 03:57 PM
ThomasE's Avatar
Dealer : Piercey Toyota Scion
Last Online: Today 06:31 PM
ThomasE is on a distinguished road.
ThomasE's Photo Albums
It would be best for your situation to cut out your stock mufflfer and weld in a new one. I did that after I already installed the JBA headers. With the headers I immediately felt more power. After I added a Magnaflow (2.5" in/out) keeping stock piping, it sounded a lot nicer. But I can't say I fell any gain. At the same time, I'm sure I didn't lose any torque either.
TRUCK: 2001 2WD V8 AC MODS: JBA headers! Magnaflow muffler, TRD 4x4 coils & shocks, Wheeler's AAL's, Truxedo bed cover, Bridgestone Dueler AT LT265/75/16, Surepull hitch, Drawtite convertor box, MAPP nerf bars, Toyota bed mat
Old 07-29-2005, 08:40 PM
2005 Toyota Tundra
Thanks for all the replies, I appreciate all the info. I will let you guys know what I end up doing.
Old 07-30-2005, 06:06 PM
Dealer : Rainbow Toyota - North Battleford
2005 Toyota Tundra
Last Online: 09-27-2009 11:14 PM
Burl is on a distinguished road.
Burl's Photo Albums
Why or how does the TRD dual system work when other duals don't?
Old 07-30-2005, 10:56 PM
2003 Toyota Tundra
Default It doesn't
It doesn't...the TRD duals suffer from the same loss of low to mid range torque as all the other "systems" that use dual 2.5 inch pipe from the muffler back. There have been several credible TS members who have tried the TRD duals and then gotten rid of them because of unacceptable low end torque loss.
Some muffler back dual exhausts (TRD is one) do improve top end horsepower (3500 RPM and higher) plus, to some people, they sound and look better than the stock exhaust.
The only dual exhausts that don't hurt low end torque are those custom systems that use a true dual pipe all the way from the cats back...and that's only if small (not larger than 2 1/4 inch or 2 inch) pipe is used as well as having an H- or X- crossover right behind the cats. A properly designed and crafted custom system like this with stainless pipe, a Dr Gas X-crossover, and quality stainless mufflers (Borla, Magnaflow) will typically run $800 or higher. And even then, the low end torque is not any better than you can get by simply replacing the muffler in the stock single exhaust with a good flowing aftermarket muffler (Magnaflow, Dynomax, Gibson).
Ray
Old 08-01-2005, 02:15 PM
PagalDesi4Life's Avatar
2001 Toyota Sequoia
Last Online: Today 10:11 PM
Images: 2
PagalDesi4Life is on a distinguished road.
Send a message via AIM to PagalDesi4Life PagalDesi4Life's Photo Albums
When I went to a muffler shop to see if it was possible to install cutouts on my Sequoia, he said he didn't reccomend it since its only used for racing and that the car wouldn't have enough backpressure which is needed to run the v8.
RockyMtnRay, are you saying that no backpressure is good when towing or just in general driving?
2001 Toyota Sequoia SR5
Vroom VroomParty Starter
Old 08-01-2005, 06:13 PM
dsrtrcr01's Avatar
Images: 11
Default For which vehicles
Is this just for the Tundra? I know that the older Toyotas, late 80's early 90's run a whole lot better and have more low end with back pressure. Also the smog does not work with no back pressure on these older trucks. I had an 84 with open pipe 2.5 inch all the way. Once I put in a spintech and dropped the size to 2.25 after the muffler it had much more grunt on take off.
Old 08-01-2005, 08:37 PM
Dealer : McGeorge Toyota
2004 Toyota Tundra
Last Online: 06-04-2008 08:56 PM
Xtrema is on a distinguished road.
Xtrema's Photo Albums
Default Me Like Backpressure
One thing we all should remember is that backpressure is something that the engine designers consider when specifying the intake and exhaust valve overlap. It is not backpressure that is bad. It is removing backpressure when the engine designer wants it. The exhaust valve is normally coming to its closed position as the intake valve is opening. (Even in DOHC engines there can be valve overlap.) The fresh air / fuel charge displaces the residual burned inert exhaust gas. When backpressure is reduced, some of the fresh air / fuel charge leaves the cylinder and goes out the tailpipe, right before the exhaust valve closes. So, your engine has less air / fuel to burn, and creates less cylinder pressure and torque to move your hot rod. Sounds crazy, perhaps, but it can and does happen. Perhaps you can hear my deep baritone voice of experience?
Other elements of gas flow dynamics include the resonance of the pipes. Diameter, changes in diameter (i.e. mufflers), location of mufflers relative to the previous diameter change, all have an impact on flow and flow resistance. This is more commonly seen on intake manifolds, such as those cars with two runners per cylinder for different rpm ranges.
The Toyota VVT-i cam adjustment attempts to maximize torque by changing the cam timing with respect to engine speed. The flow rate and when the flow reaches the cylinder are very important to maximizing torque.
K&n Gen Ii Intake Kit nhparrot Engine & Drivetrain 2 07-06-2006 11:19 PM
fixing stock exhaust manifold cracks rover67 Engine & Drivetrain 18 08-15-2003 08:20 AM
Custom exhuast fatcat0331 Engine & Drivetrain 8 10-16-2002 01:03 AM
stock speaker info nhparrot Audio & Stereo 0 03-28-2002 02:13 PM
Question about stock Tundra Foglights..Help! nhparrot Electrical & Computer Systems 0 03-28-2002 01:13 PM
