I have an 05 SC with the new V6 engine. I tow a cargo trailer, 900lbs plus about 3-400 lbs of equipment in it. It travels good now but I am wondering if all the mods you are doing with the JBA headers and gibson exhaust would also work with my setup. According to the specs on this engine, I am getting my max torque at 4000 rpm. Most of my travel is in the city so I am doing alot of stop and go so more low end power would be great. Thanks for any input.
Rick
__________________ My first Tundra, Reg. Cab, 4.0 V6, 2wd, White. Ziebart spray in bed liner and rustproofing. Vent Visors. Red Hellwig sway bar. Many mods to come.
Rick
JBA doesn't yet offer headers for the '05 V6 Tundra; they may in the future since they did make them for the 3.4V6 on earlier models.
I have no idea whether or not a Gibson exhaust will help the low end torque on the V6 if you don't have headers. I suspect the effect, if any, will be rather small. But if you want to be the first to experiment with this mod, please let us know what you find out.
__________________ Ray
Thunder Gray Metallic
2002 REGULAR CAB - LONG BED - 4WD - V8 - SR5
TRD / Kazuma LSD made by EATON
Bilstein HD shocks
Michelin 8 ply E series radials
JBA headers
Hellwig rear bar
Line-X over the rail
2005 tail lights
OEM Door Sill protectors
TRD Off-Road front coil springs
Color matched LEER Hi-Top cap
Wet Okole Sport Seat Covers
Tinted Windows
OEM Rubber Bed Mat
OEM All-Weather mats
OEM Towing Package with Remote Transmission Cooler
According to the specs, my new V6 has the same HP rating as the earlier V8's but lower torque rating. I would like to have gotten the V8 but they did not have one at the dealer and I needed something right away.
Rick
My 05 tacoma with 4L V6 almost doesn't notice my 2000lb empty trailer. I only notice it when I put my 92 toyota/fullsize chevy hybrid 4x4 on too. Then it still tows better than my GMC fullsize I just traded for the taco.
The Tundra does a great job towing the little trailer I have, just yesterday I needed to get onto a busy state road and saw a small opening and took off and I was truly impressed with the power I had right up to 60mph. My last tank full was used mostly towing this trailer and I got 16.5 mpg. Now that my front end vibration problem has been taken care of I look forward to some good cruising with it. As Ray suggested, I may still go for the gibson muffler now and when JBA comes out with a header for my engine I will still get that as well.
Rick
jba Does Have Headers For Your 4.0l 2005 V6, Believe Me They Are Sitting In My Garage!! :d Im Not A Forum Troll, And This Is No Lie. Part # 2035sjs. Im Putting Mine In On Friday I Will Let You Know How They Work Out...
Happy to see you found them. Good Luck with your headers, they are a CARB approved quality product.
Larry
Some people should not be allowed access to tools without books!!!
How much did you pay for them and let me know how they are to install and run. Are you gonna run a dyno test to see how they work out.
Rick
