Old 09-15-2005, 01:31 PM
Last Online: 01-28-2007 01:00 AM
Sandy is on a distinguished road.
Sandy's Photo Albums
Default A/T Fluid Temperature Warning Light
I just bought my first Tundra -- a 2001 AC TRD 4x4. Will not use it offroad but will be using it to tow a boat & trailer weighing 5,000#. Had been thinking about adding a Transmn Fluid Temp Gauge, but see that the vehicle has an A/T Fluid Temperature Warning Light. Does anyone know at what temp this "idiot light" comes on?
Sandy
Old 09-19-2005, 09:34 AM
Herbicidal's Avatar
Just a Herbicidal maniac.
2001 Toyota Tundra,
2008 Toyota Yaris Sedan 'S' Flint Mica,
2009 Toyota Corolla 'S' Barcelona Red
Last Online: Yesterday 11:21 PM
Images: 150
Herbicidal's Photo Albums
Sandy
I believe it is 275 degrees (I once asked a Toyota service rep., about 3 years ago). I have a tranny temp gauge and a larger aftermarket cooler. I've seen the tranny temp gauge peg at 250 while towing our travel trailer (5,600 lbs camping weight) up the Grapevine (I-5 south) in So. Cal and the "idiot light" did not come on. The other part, I believe, is that the temperature would have to be at 275 for several minutes, perhaps 5, before it came on. So a 'spike' into the 275 degree range would not trigger it.
Old 09-19-2005, 09:38 AM
nhparrot's Avatar
Dealer : Rockingham Toyota
1997 Toyota Camry,
2000 Toyota Avalon
Last Online: 11-24-2009 08:35 PM
nhparrot's Photo Albums
Sandy
230 degrees
~Glenn
Grinding while switching from 2wd to 4wd harkeyjt Engine & Drivetrain 11 08-06-2004 06:05 PM
'01 Tundra Brake Warning Light Inspection nhparrot Knowledgebase Archive 0 10-23-2003 09:32 AM
Transmission temperature warning light bearsfolks Engine & Drivetrain 6 12-24-2002 01:52 PM
