Just wanted to get an opinion from the towing experts here. I am in the process of retiring and moving to Tennessee from Louisiana. I was going to rent a U-Haul truck but the price is so high I thought I would just rent the largest trailer they have and see if that will get everything up there in 1 trip although it may take 2 in which case I would probably be better off with the truck. But with that said. I intend to rent the following trailer:
Capacity
Volume: up to 396 cu. ft.
Max load: 2,600 lbs.
Gross vehicle weight: 4,400 lbs. max
Empty weight: 1,800 lbs.
Dimensions
Inside dimensions: 11'7" x 6' x 5'5" (LxWxH)
Door opening: 5'0" x 4'10" (WxH)
It is a 6 x 12 foot tandem axle. My 2wd Tundra with towing package is rated at 7200 pounds. Of course I know that the real world tow weight is no where near that. Am I ok to tow this trailer loaded with my class 3, transmission cooler, etc. towing package without any special equipment. U-Haul does not recommend a weight distribution hitch with their trailers. Can you all advise if this will be safe. I have had my truck for 3 years since new and have never towed with it. Also while U-Haul recommends a maximum tow speed of 45 mph I think I will get run over doing that. I was thinking of about 60 with overdrive off. Does this sound good.
Thanks
Sammy
2003 TRD Stepside 2WD LSD, 275 Revos, 1 inch Daystar spacer up front, TRD AALs in the back, 1.5 inch Wheeladapter.com wheel adapters, Truxedo tonneau cover, Rhino Lining, Self-Dimming Mirror w/Compass & Temperature, RS3200 Alarm Upgrade, Stant 11506 Locking Gas Cap, Hellwig Anti-Sway Bar, Magnaflow 12586 on the way
I did exactly this on a 500 miles trip. My truck is 2003 SR5 AC 2WD V8. It pulled it just fine without breathing hard. Very stable, smooth and no problem braking.
I figure I had about 3200 lbs including the trailer. I went over two 4000 passes and the rest was flat Central California freeway.
The only and critical thing with U-Haul is you make your reservation with your credit card etc. and there is NO guantee the trailer will be there to pick up.
They DO NOT relocate trailers. If someone doesn't bring one back on time so that you can use it U-Haul just says "tough luck". I had to make a 100 mile rond trip to get the trailer.
Oh I forgot. My truck has the factory towing package. (trans cooler, hitch and wiring)
I thought I could cruise in 4th gear (OD) but most of the time I stayed in 3rd and traveled at 60 MPH.
Hope this helps.
Good luck - George60
LACK OF PLANNING ON YOUR PART ----------------
DOES NOT CONSTITUTE AN EMERGENCY ON MY PART !!
I just finished towing the same trailer from Raleigh, NC to South Florida. I had it loaded pretty full; guessing about 2000 lbs of stuff. It was a two tank trip so I decided to do one tank with OD on, and one tank with it off. With OD on, I got 14.5 mpg, and it only downshifted a few times going over the steepest of the hills I encountered in NC. The second tank had OD off, and I got 14 mpg; it never downshifted, but by this time I was in flatlands.
I kept the cruise control on about 67-68 mph. I did the same speed going up so I could do a with/without mileage comparison. Going up I got about 20 mpg. The trailer has surge brakes, and they must have worked pretty well cuz I couldn't feel much of a braking difference - but some. When accelerating I could definitely feel it. The truck was pretty slow, but once up to speed, it pulled the trailer easily. And it still had a good amount of passing power when I needed it.
Overall, I was very pleased with the way the truck handled it.
__________________ 2004 Salsa Red Pearl DC Limited 4x2
Toyota Mods:
Accessory Meter / Leather / LSD / Moonroof / Tow Package / Rear DVD System / Challenger Step Boards / Carpet Mats / Toyoguard
My Mods:
Debadged / Line-X / Window Tint to Match Rears / Hellwig Anti-Sway Bar / ORW Steering Rack Bushings / RAPS / VSE Subwoofer / Pop&Lock Power Tailgate Lock / Unichip / JBA's / Gibson Exhaust
In reference to brakes it is like tuesdayd said it has an automatic hydraulic surge brake whatever that is. I have to assume that does not require anything special on my vehicle. Anyway thanks for all the replys, it looks like I will be fine with this set up.
Thanks
Sammy
