Tundra Towing Capacity - Page 3
+ Reply to Thread
Page 3 of 3 FirstFirst 123
Results 31 to 42 of 42
Like Tree1Likes
Thread: Tundra Towing Capacity
  1. #31
    Rookie Buxfvr's Avatar
    Join Date
    Feb 2011
    Location
    virginia
    Posts
    13
    Liked
    0 times
    Rep Power
    0
    Default Re: Tundra Towing Capacity
    I have a 2006 v8 double cab, i have pulled half a single wide trailer up a steep grade in a rocky sandy woods trail for my brother in 4 low with the front tires almost lifting of the ground, the frame bump stops hit hard on flat surface driving at low speed, had to haul 5 miles , and it was 15ft wide . hard on vehicle but she will do it with no problem. 2-15/16 ball on receiver, I have pics i will post later
  2. Remove Advertisements
    Toyota Tundra Forum
    Advertisements
  3. #32
    Beer Me ZapcoTundra's Avatar
    Join Date
    Feb 2008
    Location
    Central California
    Age
    27
    Posts
    1,676
    Liked
    419 times
    Images
    57
    Rep Power
    32770
    i have fit 4 55gal drums of 15/40 and 3 1/4 drums of 85/140 with a few cases of oil, it was pretty much on the bumpstops, drove 60 miles up hill, she loved every second of it....
    a 55gal drum is about 450lbs and a 1/4 drum is about 150lbs case of 15/40 was 50 lbs. that was a fair amount of weight in the bed lol.
    Jason
    It's paid off and and starts when i turn the key
    If You seek advice, then LISTEN with your EARS not your MOUTH.....
  4. #33
    Join Date
    Feb 2011
    Location
    virginia
    Posts
    13
    Liked
    0 times
    Rep Power
    0
    I can imagine most of us at one time or another have dropped a whole front loader scoop of gravel in the bed, thats pretty much well over a half ton, truck on bump stops definetely . lol
  5. #34
    Join Date
    Feb 2011
    Location
    Citrus Heights
    Posts
    36
    Liked
    0 times
    Rep Power
    47
    Make that 2 scoops for me :/
  6. #35
    Join Date
    Feb 2011
    Location
    Florida
    Posts
    6
    Liked
    0 times
    Rep Power
    0
    My wife and I are looking into getting a 21' travel trailer but before I do so, would something like that be too much to tow for our 2001 V6 Tundra SR5? Says on the bumper 5000lbs which is repeated on the tow hitch. Just want to be sure before we jump in and buy a trailer.
    What we do in life, echoes for eternity.
  7. #36
    Lurking Member davidjc's Avatar
    Join Date
    Sep 2008
    Location
    Natchitoches, LA
    Posts
    28
    Liked
    2 times
    Images
    2
    Rep Power
    991
    Two main things to consider. The towing capacity of your Tundra and the weight on the tongue, or hitch. It appears that your towing capacity is between 4900 and 5200 pounds, depending on bed length and options.
    Check it here. http://www.trailerlife.com/images/do...owingguide.pdf.
    There are plenty of super-lite trailers out there.
    2008 Limited Double Cab
    Salsa Red Pearl 5.7L,
    Air Lift 5000 Air Bags w/
    Wireless Air Remote
    Rockwood 8282WS 5th Wheel, 7700 lbs Dry Weight
    Revolution Pin Box
  8. #37
    Join Date
    Feb 2011
    Location
    Florida
    Posts
    6
    Liked
    0 times
    Rep Power
    0
    Quote Originally Posted by davidjc View Post
    Thanks for that link David!
  9. #38
    Join Date
    Nov 2012
    Location
    Cumming GA
    Posts
    1
    Liked
    0 times
    Rep Power
    0
    2006 Tundra with 4.7 V8 2wd, double cab. Want to pull a 34 ft coachman, weight 6800 lbs. Any advise
  10. #39
    The Friendly Dragon by the Sea Puffnstuff's Avatar
    Join Date
    Sep 2006
    Location
    Jacksonville
    Age
    51
    Posts
    2,876
    Liked
    183 times
    Images
    45
    Rep Power
    16219
    Supposed to be rated at 6800lbs according to the brochure.
    Attached Files Attached Files
    RIP 2006 Tundra DC with: Eclipse AVN5500 Navigation System, Kicker IX500.4 driving infinity kappa 60.9cs door speakers, Kenwood KAC-X20 driving an infinity kappa 100.9w sub in sound ordnance bass bunker, UWS Black Deep Toolbox, Nasta SS Nerf Bars, Rugged Liner Bed Liner, AVS chrome bug shield, EGR in channel vent visors, Ballistic Enigma 20x9 wheels & Nitto nt420 285/50R20 tires, Hellwig 7697 & 7700 sway bars, Stinger SPP2150 Battery, Big 3 wire upgrade with 1/0 Raptor, Rancho RS5000 struts/shocks, Dynomax VT 17956 muffler, EBC Slotted Sport Rotors & Yellowstuff Kevlar pads, Russell SS brake lines, Cheetah GPS Mirror
  11. #40
    Supporter UPbuilder's Avatar
    Join Date
    Feb 2012
    Location
    U.P. of Michigan
    Posts
    932
    Liked
    763 times
    Rep Power
    55896
    Quote Originally Posted by Gdad View Post
    6800 lbs dry or loaded? Even loaded that's quite a tug. If it's a one time shot and not too far you could do it but it won't be fun. If that's dry weight then probably not.
    2003 Tundra SR5 TRD AC, Bilstein 5100's top notch, diff drop, ES steering rack bushings, Wheelers single leaf AAL's, Pacesetter longtube headers, stock cats, Magnaflow 12586's (No CEL's!).
    http://thebrakedoctor.com
    http://uptrailerandhitch.com
  12. #41
    Join Date
    Sep 2012
    Location
    Cumming, GA
    Posts
    1
    Liked
    0 times
    Rep Power
    0
    the coachman weight is loaded, not dry weight.
  13. #42
    Join Date
    Jul 2008
    Location
    Tucson
    Posts
    15
    Liked
    7 times
    Rep Power
    0
    I have an 03 stepside 4.7 V8. I have towed a travel trailer, with a quad in the bed, and a dirt bike on the front hitch. Got it on the scales and it weighed 12,700lbs. I've towed several times from Tucson to Yuma sand dunes and back.
    The truck pulled well, mileage wasn't great, but didn't overheat or seem to lack any power.
Quick Reply Quick Reply
Register Now
Your postal zip code.
Where you live.
Log-in
Human Verification
  1. Towing Capacity?
    By thompme in forum Towing
    Last Post: 11-19-2008, 01:47 PM
  2. Towing Capacity
    By shorberg in forum Towing
    Last Post: 10-11-2007, 02:41 PM
  3. Tundra Towing what would you add?
    By h7009 in forum Towing
    Last Post: 12-13-2004, 07:49 PM
  4. Towing Package 2003 Tundra Access Cab
    By misterdf in forum Towing
    Last Post: 07-20-2004, 11:26 AM
  5. Question about stock Tundra Foglights..Help!
    By nhparrot in forum Electrical & Computer Systems
    Last Post: 03-28-2002, 10:13 AM
Posting Permissions
  • You may post new threads
  • You may post replies
  • You may not edit your posts
