Tundra Help
+ Reply to Thread
Results 1 to 3 of 3
Thread: Tundra Help
  1. #1
    Join Date
    May 2002
    0 times
    Rep Power
    DefaultTundra Help
    I have a 2001 Tundra w/extended cab, V/8. I am interested in a “Coachman Spirit of america 24RBQ ” TT. It weighs in at 4500# dry (according to factory specs.) with all factory options. My wife and I will put in all the normal stuff for traveling. I am wondering if my Tundra will safely pull this amount of weight with a WD hitch and etc. zztinker
  2. Remove Advertisements
    Toyota Tundra Forum
  3. #2
    Veteran Member shall36's Avatar
    Join Date
    Jul 2003
    Orlando, FL
    5 times
    Rep Power
    DefaultRe: Tundra Help
    There are a lot of good threads on this.
    Not sure what you mean by "safely"....you might mean what load is safe for the truck (so you don't break anything) or what load is safe for you and the traveling public.
    On the '02 Tundra, never tow in OD and make sure your trans is serviced regularly.
    On the weight, don't shoot for 100% of max. Aim for 80% - 90%.
    See this thread on how to figure out max combined gross weight
    Towing 7600 GVWR!!!@@??
  4. #3
    Join Date
    Aug 2005
    Loveland, OH
    7 times
    Rep Power
    Dry weights are nearly useless, but not completely useless. The GVWR for that trailer is just over 6,000 lbs. I would guess that when you pull it off the lot, the trailer will weigh around 4,800- 5,000 lbs with a hitch weight of 750 lbs. If you have a stock 2002 with a tow package, that should tow nicely. Add your stuff and you will be towing around 5,500 lbs without water. That should work. Also be careful not to load the truck down as the Tundra's limiting factor when towing is often its own GVWR, not the GCWR.
    So, tow away. Just make sure the brakes and WDH are set up properly.
+ Reply to Thread
Gear in this thread - Powered by O'Reilly Auto Parts
Quick Reply Quick Reply
Register Now
Your postal zip code.
Where you live.
Human Verification
  1. How does the performance of the 4.7L i-force V8 compare to the 5.3L LS1-based Chevy?
    By Threxx in forum Engine, Intake, Exhaust, Induction
    Last Post: 04-22-2009, 08:54 PM
  2. How Good are Tundras Off-Road - Really???
    By taconow in forum Off-Roading
    Last Post: 01-27-2007, 01:26 AM
  3. Tundra DC Parts Compatibility
    By RoundTuit in forum 1Gen-Tundra
    Last Post: 08-25-2006, 10:49 AM
  4. Which truck is faster, Tacoma vs Tundra
    By fslaugts in forum Tacoma
    Last Post: 12-23-2005, 10:13 PM
  5. HID auxiliary lowbeam photos
    By nhparrot in forum Electrical & Computer Systems
    Last Post: 03-28-2002, 07:06 PM
Posting Permissions
  • You may post new threads
  • You may post replies
  • You may not edit your posts
