Old 09-08-2006, 11:38 PM
Dealer : Longo Toyota
Last Online: Yesterday 11:53 PM
2000LtdKen is on a distinguished road.
2000LtdKen's Photo Albums
Default Emergency Flashers when towing
I have a 2000 Tundra that I use to tow a Weekend Warrior Trailer. When my truck is hooked to the trailer with the 7 pin connector, the emergency flashers won't work. When it is disconnected, it works fine.
Any suggestions?
Thanks,
Ken
JBA Headers, Gibson Muffler, Daystar Front Level Lift, CDT Kama Speakers, Elemental Designs 9.4 Amp, Eclipse CD2000 Head Unit.
Old 09-10-2006, 10:49 AM
rogersja63's Avatar
Dealer : Bayside Toyota
2007 Toyota Tundra 5.7L, 4x4, Limited,
2008 Toyota Prius
Last Online: 03-21-2009 08:57 PM
rogersja63 is on a distinguished road.
rogersja63's Photo Albums
Default Re: Emergency Flashers when towing
Any suggestions?
Thanks,
Ken
I'm having the same problem with my '05 Tacoma. Hopefully someone will chime in with a solution.
2007 Tundra DC Limited, 5.7L, 4x4
2008 Prius (to make up for the Tundra's gas milage)
Click For Jim's Pic's
Old 09-10-2006, 11:14 PM
RockyMtnRay's Avatar
2003 Toyota Tundra
RockyMtnRay's Photo Albums
Any suggestions?
Thanks,
Ken
Do the turn signals work (both left and right) on both truck and trailer when the trailer's 7 pin connector is connected to the truck?
If so, I suspect there may be a problem with the relay for the 4 way flasher or the turn/brake combiner in the truck's wiring harness (there may also be some corrosion in a connector that produces enough resistance that when all turn signals are activated, there's not enough current to illuminate the bulbs.
If not, then you probably have a short in the turn/brake lighting circuit(s) of the trailer (not uncommon).
Ray
Old 09-11-2006, 12:12 AM
Ray,
Turn signals work both left and right on both trailer and truck when connected by 7 pin.
Ken
Old 09-11-2006, 12:30 AM
2003 Toyota Tundra
Ray,
Ken
Had a hunch they would. And that means you'll need to get the truck's wiring schematic from the TS Garage and start troubleshooting with a test lamp and probably also a multimeter (for checking resistance of connections). Likely to be a real PIA to do even after you find all the relays. Good luck.
Ray
7000 mile trip with 3000 mile towing with Tundra and Outback BaseCamp Towing 20 02-25-2008 08:55 PM
Any new info on a Diesel?..... Towing advice? Akita Towing 14 05-27-2006 12:03 AM
Towing Hitch? boody Towing 13 02-28-2005 01:05 AM
overdrive for towing? outragex Towing 7 05-15-2004 04:24 PM
Towing Weight And Overdrive Question ?? ZIGGY454 Engine & Drivetrain 17 01-28-2004 08:35 AM
