need help on 7-blade RVconnector wiring
Hi, I have a 2005 Tundra DC with a factory 7-blade RV towing connector. I am trying to install a cargo light by tapping into the 12-V power source in the connector. As I started the job, I measured 12V at the corresponding terminal,but after I finished the job the 12V disappeared (witht the ignition switch on). I figure I must tripped the fuse but could not find that fuse location. Does any body know where is that fuse, or where to get a fuse layout, or maybe any other suggestion?
thanks.
