  2 links from elsewhere to this Post. Click to view. #1 (permalink)
Old 09-15-2006, 10:05 PM
Moderator
Dealer : Performance Toyota
2008 Toyota Tundra Slate SR5 4x4,
2005 Toyota Sienna XLE
Last Online: Yesterday 06:52 PM
Images: 23
tomhole's Photo Albums
Default UPDATE: Air bags installed
I decided to install some air bags. Wanted to see if they stabalize the truck while towing. Pretty simple install. Took 2 hours. No fancy in cab inflation system (yet). Just put the inflator thingis in the wheel wells for now.
I put 10 psi in them (min recommended) and it lifted the back end about 3/8" with no load. Cursory test drive revealed nothing that I could discern. Real test will come tomorrow with the trailer hooked up.
For those that are curious, I have a well adjusted rig while towing. I use a Reese Dual Cam setup. Rig is level. WD bars are level. Weight is distributed well between all the axles. So I really don't need air bags for any reason. But I wanted to stiffen up the back end as I tow at the GVWR of the Tundra (lots of people and gear in the truck) and at the GCWR. Just felt the back end on my 4x2 non-TRD felt more like a Cadillac than a truck. Thought about TRD shocks but they would have been lots more $$$ than the air bags and would have stiffened up the no load ride so I decided to go with air bags. I'll report back after towing the trailer.
Next step is LT C load rated tires.
Tom
Old 09-16-2006, 12:09 PM
Moderator
Images: 23
Default Re: Air bags installed
Just went out and towed the trailer home. Set it up as usual. Rear sagged 1/2" as expected with the WDH set up. I had the airbags set at 17 psi before hooking up. They were at 29 psi after hooking up with the WDH (I guess that whole PV=nRT actually works). I also had 400 lbs of dirt in the bed of the truck. I aired them up to 40 psi and the rear raised less than 1/4".
Drove home and the ride is definitely improved. The back way home has a challenging part that always gets the rig bouncing along. The bounce was greatly diminished but not eliminated. That means I can keep the airbags on. I might try 50 psi and see what that does. I don't want the airbags to carry any load, per se, just add damping to the system.
I tilted the side mirrors down to watch the rear tires and, as usual, the sidewalls were flexing more than I would like. I think once I change out to light truck tires, I will be happy with my towing ride.
Tom
UPDATE: (I know, I'm talking to myself). Towed the trailer back to the farm. Used the same setup, but it turns out the trailer tires were all at 43 psi. To low. Aired them up to 50 psi and now I'm happy. Ride is where I want it.
I want to make it very clear that I am NOT using the airbags to level anything. Without them, I have everything setup just right. Truck is level, front to back (which actually means the tail is sagging 1" or so from no load). Trailer is level. Weight distribution is good. I only use the airbags to stiffen up the rear suspension while towing. When I have them aired to 40 psi, they provide < 1/4" of additional lift, but make the suspension stiffer. Just what I wanted.
Old 09-29-2006, 02:35 PM
celica's Avatar
Dealer : Charlesglen Toyota
2003 Toyota Sequoia
Last Online: 11-11-2009 10:26 AM
celica is on a distinguished road.
celica's Photo Albums
yup you are talking to yourself - with 114 viewings lol . Good information. When are you changing your tires? You need to let us know what the difference is with the new tires.
Matt
2003 4runner Limited
2003 Sequoia Limited
1989 Supra Turbo
Old 09-29-2006, 02:48 PM
LV4R's Avatar
Dealer : Findlay Toyota Scion
2005 Toyota 4Runner,
2008 Toyota Sequoia
Last Online: Yesterday 07:32 PM
Images: 4
LV4R is on a distinguished road.
LV4R's Photo Albums
Air bags are the bomb! I installed them on my 4R and could not be happier with the added support that they give when towing. Last year I had one of those hitch mounted baskets when I took a ski trip. The basket was loaded with probably 200+ pounds of stuff which made the 4R really nose high. Hopefully the airbags will helps this out as well if I ever do that again!
Old 10-06-2006, 07:18 PM
mustang67408's Avatar
KE7WLF Master of Disaster
2002 Toyota Tundra,
- Other - 1967 Mustang,
2005 Toyota Prius,
2005 Toyota Tundra DC,
2008 Toyota Sienna RAMPVAN
Images: 164
Don't worry we are listening. I always listen to the voices in my head.
I love my air bags too. They work well to dampen the bouciness. As you said I dont use them to carry any load, just to help control bounce and sway. They smoooothed things out alot.
I also have the dual cam reese anti sway device and a WDH with 10k bars.
25 yrs with TOYOTA
Old 10-29-2006, 11:29 PM
chrisc16's Avatar
Dealer : Toyota of Orange
2006 Toyota Tundra,
2005 Toyota Highlander
Last Online: 09-29-2009 06:32 PM
chrisc16 is on a distinguished road.
chrisc16's Photo Albums
I highly recommend an in-cab airbag controller. I love being able to adjust the bags on the fly depending on load and road conditions.
-Chris
2006 Tundra 4x4 Double Cab
ORS manual hub conversion, TC UCAs, Donahoe coilovers, Firestone RideRite airbags, '07 Solara Nav, SAAV backup camera, Flip-Pac camper
Old 10-30-2006, 03:27 PM
Dealer : Longo Toyota
Last Online: 11-21-2009 09:40 PM
2000LtdKen is on a distinguished road.
2000LtdKen's Photo Albums
I also have air bags on my truck and noticed the firmed up ride. Good stuff when towing. I bought a in cab controller to inflate the bags but my dog chewed it up.
Since plan -A- was done at that point, I just mounted my inflation valves in my license plate. Drilled the top 2 holes a little larger and fitted them in there. Easy access and they look good too.
Ken
JBA Headers, Gibson Muffler, Daystar Front Level Lift, CDT Kama Speakers, Elemental Designs 9.4 Amp, Eclipse CD2000 Head Unit.
LinkBack to this Thread: http://www.tundrasolutions.com/forums/towing/72807-air-bags-installed/
Posted By For Type Date
Toyota Corolla Air Bag System, Toyota Corolla Acessories Fog Light Covers, Toyota Corolla All Wheel Drive - Championenergy This thread Refback 03-08-2009 11:16 AM
Img Assist Load Preview 40 This thread Refback 12-01-2007 02:44 AM
Air bags and spacer lift? DeMello OR 1Gen-Sequoia 2 10-04-2006 05:57 PM
Share opinion on new Air bags SnowTruck Suspension & Axle 4 01-14-2006 12:47 PM
Air Bags markbregar Suspension & Axle 4 08-05-2004 01:08 AM
Firestone Air Bags mgw24 Suspension & Axle 7 05-27-2004 12:25 AM
K&N Cold AIR System John J Martinez Engine & Drivetrain 9 12-10-2002 01:23 PM
