LinkBack (5) Thread Tools Display Modes
  5 links from elsewhere to this Post. Click to view. #1 (permalink)
Old 09-17-2006, 11:28 PM
Dealer : Magnussen Auburn Toyota
Last Online: 09-29-2007 12:54 AM
Tund-doublecab-4x4 is on a distinguished road.
Tund-doublecab-4x4's Photo Albums
Question Towing over 1K, trailer brakes required???
Okay, I have a 7X10 flat bed trailer. It has a 3500lb single axle w/out brakes.
According to the Tundra manual towing anything over 1000lbs needs to have brakes.
So unless I want to worp rotors and beat my truck up premature I need to get an axle with brakes.
Questions;
What does this intale?
What are "all" the parts will I need to buy?
Where's the cheapest place to buy a trailer axle w/brakes?
Any and all help is appreciated.
1991 4x4 SR5 V6 extra-cab truck 150k in 3 yrs. (sold)
1997 4x4 4runner 150k (traded in)
2006 4x4 Tundra 2x-cab limited
Old 09-19-2006, 09:57 AM
shall36's Avatar
Dealer : Central Florida Toyota Scion
2003 Toyota Tundra
Last Online: Today 07:49 PM
shall36 is on a distinguished road.
shall36's Photo Albums
Default Re: Towing over 1K, trailer brakes required???
Good questions....
With regard to the premise of the post (trailers over 1K need brakes), I have an 8x10 and have loaded it up at times, well over 2K, and didn't have a braking problem. Of course, I'm in Florida. To be sure, you need to be prudent when driving and plan ahead.
As for adding brakes to the trailer, I assume that you are going to go electric? It's more economical. Hydraulic kits are available, but they are very expensive.
On the truck side....
You need to wire up for a brake controller. See my post on this...Adding 7-pin wiring and Brake controller to 03 Tundra w/o TO
If you have the factory tow package, you will have the 7-pin wiring installed and just need to hook up a brake controller to the factory wiring. Most guys seems to favor the Prodigy brake controller....which you can find for about $100 on the internet.
On the trailer side....
You will need new hubs/drums and the brake backing plates with hardware...at a minimum. The magnets on the trailer brakes are wired into the 7-pin RV connector (which you will have to add wiring to the trailer and wire-up a 7-pin connector on the trailer). Some states, like NC, require a break-away setup, which consists of a small battery and break-away trigger. This setup activates the trailer brakes in the event that the trailer, well, breaks-away.
10" brake hardware is about $50 per side.
10" brake drums are $50 each side.
Break away kit- $50.
OR...you could buy a new axle with brakes for $209 + shipping from 3,500 lb. Standard Spring Trailer Axle
Hydraulic disc brake kits are available from the same site for $400. Disc brakes on that small trailer would be way overkill. I wouldn't think that a hydraulic disk brake setup would hold up well on trailers that are rarely used.
OR...you could get the following hydraulic surge drum brake setup for $300....The Trailer Parts Depot - Item Description Page
When you think about it, the last option might be the best option. If you go electric, the most economical deal is the axle for $209, controller for $100, then add shipping and wiring (say $75+). This is all assuming you do your own installation. So, you'll be in for almost $400 when all is said and done. The surge brake setup (and some would argue that surge brakes can be dangerous on heavy setups, but in your case, I think they would be just fine), runs $300 plus shipping, but won't require any additional wiring or controllers. You may find that you will need to have the old coupler cut off and the new one bolted on. You may or may not feel comfortable doing this yourself. The upside of the surge brake setup is that there is no need for the tow vehicle to have a brake controller, so if someone borrows the rig, they will also have brakes.
The surge brake option is tempting for me, but for how little I use my trailer and the loads I haul, it's frankly not worth the money. I've had no problems without brakes...I just adjust my driving accordingly.
Old 09-29-2006, 10:30 PM
willy's Avatar
Dealer : Mic Mac Motors
- Other - '41 Chevy 1/2 ton,
2007 Toyota Tundra DC 4WD LB
Last Online: 11-13-2009 08:06 PM
willy will become famous soon enough.
willy's Photo Albums
Before you go out and spend all that money. Tow the trailer with weight on it for a while. Towing a trailer under maybe 3-4k lbs w/o out brakes, from my experiences, is absolutely no problem at all. When you get a big 20 ft trailer with a truck on it, that's when you definetely need trailer brakes.
Try it out for a while before you go to all that hassle. I'll be you with a small trailer like that you won't even know it's there.
Old 09-30-2006, 08:24 PM
Hickleberry's Avatar
Dealer : Amador Toyota
2004 Toyota Tundra,
- Other - 1969 Mustang
Last Online: Today 08:44 PM
Images: 5
Hickleberry is the One. Hickleberry is the One. Hickleberry is the One. Hickleberry is the One. Hickleberry is the One. Hickleberry is the One. Hickleberry is the One. Hickleberry is the One. Hickleberry is the One. Hickleberry is the One. Hickleberry is the One.
Hickleberry's Photo Albums
I have towed my Mustang on a car trailer and an enclosed trailer with 3500 lbs of garbage inside, no trailer brakes, I never exceeded 60 mph, and I just gave myself lots of room. No problems.
I towed a boat, its in my pics, which weighs 3000 lbs. I can't think of the type of brakes the trailer had, but basically when pressure is detected on the ball, the brakes engage automatically. When you pull forward, they release, its a pretty good system, and I could feel the trailer slowing the truck.
I'm sure electric brakes are the way to go. I've towed with those before as well, and the brake controller is adjustable to increase the amount of braking the trailer does.
Mama's don't let your babies grow up to be Woodrow!
Old 09-30-2006, 10:57 PM
Thanks for the suggestions.
I'm not so much worried about being able to stop. I towed this same trailer with a 97 4runner and didn't have trouble stopping but, I did worp my rotors. I usually tow in the mountains so, I'd rather spend the $300 to $400 on trailer brakes than (that) money on brakes on rotors for my truck.
Old 10-01-2006, 08:13 AM
Moderator
Dealer : Performance Toyota
2008 Toyota Tundra Slate SR5 4x4,
2005 Toyota Sienna XLE
Last Online: 11-21-2009 07:07 AM
Images: 23
tomhole's Photo Albums
That indicates you did have trouble stopping. I did the same thing to my minivan. No trouble stopping, but I kept warping my rotors. I think the system was trying to tell me something.
In my simple world, if the total weight of the truck and trailer exceed the GVWR of the truck, use trailer brakes. Period. I could tow my trailer without brakes and it'll stop just fine (I'm maxed out on weight). I can give myself tons of extra room for stopping. And then some pinhead who didn't know I was towing a heavy trailer without brakes cuts me off and I can't stop because he used up all my safety margin.
It's all about managing risk. I can tow a 15,000 lbs trailer on the bumper. It'll move, it'll stop, it'll turn. I may be able to do that for years and never have any issues. But I am exposing myself to some serious risk while doing it.
I towed a 4,800 lbs 6x12 U-Haul from SC to MD with my minivan. Twice. I was way overweight, I couldn't go faster than 52 mph because I had the hitch weight so light because the minivan was bottomed out. It did it and I thought I was the MAN because I outsmarted the sticker on the door. Nothing bad happened, so it must be ok.
Almost killed my family towing a pop up trailer (3,200 lbs) without trailer brakes (same minivan as above). We almost didn't stop and we split a rear tire.
So, Tund-doublecab-4x4, I think you have chosen very wisely. You will be a much safer towing partner with the brakes installed.
Tom
Old 10-04-2006, 10:43 PM
willy's Avatar
Tund-doublecab-4x4,
I guess when I read your email originally, I incorrectly assumed you'd only be towing about 1,000 lbs. That's why I said trailer brakes were an option and not really necessary. I see now that I interpreted your email wrong.
Yes, if you're towing often (just about any weight) OR towing heavy stuff (like cars or something that heavy) you need trailer brakes on one of the axles of that trailer. When they'll really come in handy is when some vehicle pulls out in front of you, or you come up to a light that has a real short yellow and you're about to run it, etc. If anyone tells you that you don't need trailer brakes if instead you just drive more cautiously, they certainly haven't towed weighted trailers that often.
Old 10-05-2006, 10:25 AM
Dealer : DCH Freehold Toyota Scion
2006 Toyota Camry-Solara convertable,
2000 Toyota Tundra single cab-V-6 8ft b
Last Online: 11-13-2009 09:24 AM
coal miner is on a distinguished road.
coal miner's Photo Albums
There are 2 points to remember with trailer brakes. One, most states have laws requiring brakes on trailers. In the Carolinas its 1000 pounds, in New Jersey its 15oo pounds. Most states are different. Weather or not your vehicle can stop without brakes doesn't matter. There is a legal question if you are involved in an accident in a state that requires trailer brakes you could leave yourself open for a nice fat law suit if you don't have them. Trailer brakes will help you stop better & prevent your rig from jack knifing on a wet slippery road. They'll also save the brakes on your tow vehicle. Quick story here. I was in Pa towing a 17 foot Casita travel trailer that weighed 2500 pounds. I was on a back country road. There was an abandoned railroad crossing in front of us. Suddenly the car in front decided to stop fast for reasons known only to him. It caught me by surprise. I hit the brake pedal with both feet & locked up my brakes including the brakes on my trailer. I stopped exactly 1/2 an inch from his rear bumper! I still get goose bumps thinking about that incident. Had I no brakes on my trailer & would have run into his rear for certain. So regardless of anything, it pays to have brakes on your trailer. KNOW BEFORE YOU TOW! Coal Miner in New Jersey.
Old 10-05-2006, 11:19 AM
shall36's Avatar
2003 Toyota Tundra
Just some more thoughts regarding trailers and legal issues....
Folks, do not underestimate your legal responsibility for trailer safety...regardless of whether the trailer is yours or not....
1. If your trailer brakes loose and it harms/kills someone, you can go to jail for manslaughter. Happened in Orlando...guy was towing a trailer without safety chains, trailer came loose, ran over a kid waiting for the school bus, guy went to jail for 10 years!
2. If you fail to meet minimum legal requirements and you are involved in an accident, your insurance company could refuse to indemnify you by virtue of the fact that you were operating a vehicle not suitable for highway use. That leaves you open to being sued personally and not having your own property covered.
Of course, the fact that Toyota says we are supposed to have trailer brakes on rigs more than 1000# leaves all of us running small utility trailers (which often weigh more than 1000# when loaded) open to personal liability (me included). Gee....now I'm seriously considering upgrading my trailer. $300 is a lot cheaper than getting sued. Hmmm....
Old 10-20-2006, 12:59 PM
Dealer : Arlington Toyota Scion
- Other - 2003 Accord 6MT,
2004 Toyota RAV4 L 2WD,
2006 Toyota Tundra Limited DC 4WD
Last Online: 07-17-2009 10:54 AM
spleck is on a distinguished road.
spleck's Photo Albums
Oh boy. I wonder how close I came to not making it through my youth. My parents used to take us camping with a pop-up behind our 85 Celica.
I don't even have anything to tow yet, and I'm already considering buying a brake controller!
Old 10-20-2006, 01:12 PM
Dealer : Koons Tysons Toyota
2007 Toyota Tundra LIMITED,
- Other - 05 660 GRIZZLY
Last Online: 12-30-2008 06:39 PM
chas3 is on a distinguished road.
chas3's Photo Albums
I have an 05 Tundra d/c I hual a 12x6 trailer with either two 600lb 4 wheelers
or two 500lb sleds up some pretty steep mountains and down. I have 66,000
miles on my truck. I have never had any problems with braking. I just had
my yearly Virginia safety inspection and was told I might get another 30,000
miles out of the pads
Old 11-28-2006, 07:45 PM
M-bird's Avatar
Dealer : Boch Toyota
2004 Toyota Tundra
Last Online: 09-08-2009 01:59 PM
M-bird is on a distinguished road.
M-bird's Photo Albums
Questions;
I've been towing a 2700lb race car on an 1800lb 18' diamondplate trailer with the truck bone stock and it is just fine.
Old 11-28-2006, 08:14 PM
Dealer : Peace Arch Toyota
- Other - 2 92 4runners
Last Online: 03-23-2007 06:19 PM
Slime green cat is on a distinguished road.
Slime green cat's Photo Albums
I have always heard the rule of thumb is ......if the trailers weight exceeds more than half of the tow vehicles weight , then you need trailer brakes .
What does the Tundra weigh ?? around 5000 lbs ???
I wouldn't even consider needing brakes until you start towing more than 2000 lbs
I tow 2500 lbs on a regular basis and sometimes up to 3000 lbs with my 86 4x4 4 cyl pick up , and also with my wifes 92 4runner (both vehicles weigh a little over 4000 lbs) , and my trailer does not have brakes , never had a problem , been doing it for years , and I tow in the mountains too .
Trailer brakes are nice to have , and are safer if your hauling moderate to heavy loads ....especially in bad weather , I should actually have them for my set up but I drive accordingly and stay out of the mountains in bad weather .
With a nice big truck like the Tundra , and only a 1000lb trailer , you have absolutely nothing to worry about
Owner manuals are always very very conservative
Old 11-29-2006, 03:26 PM
Dealer : Toyota of Greenville
2005 Toyota Tacoma
Last Online: 06-21-2009 08:49 PM
mdbrjb is on a distinguished road.
mdbrjb's Photo Albums
I guess everyone is going to say I'm paranoid, but...
Consider the geometry. Part of stopping is to try to stop pointed in the correct direction.
First, it doesn't take a lot of weight to push the back of a vehicle either to the left or right. A 1000 lb. push is plenty to cause a jack-knife.
When you stop weight shifts forward - the back of the truck goes up. Now, the trailer is not only pushing, but it's pushing upward decreasing the weight on the rear wheels. Now it takes even less force to cause a jack-knife.
Can the trucks brakes stop 2000 lbs. Yes, easily, assuming that you aren't going around a turn or the pavement is tipped, or it's wet.
I want to keep everything going in the correct direction. Trailer brakes helps achieve this even when towing a small trailer. I think that folks that say that you don't need trailer brakes for 2000 lbs have never tried stopping fast while towing. Let's hope they don't need to.
Old 11-29-2006, 04:26 PM
Moderator
Images: 23
The rule of thumb I use that I think is bullet proof: if the total weight of the truck, cargo and trailer exceeds the GVWR of the truck, then you should use trailer brakes. Biggest concern is brakes. They were designed to stop the GVWR of the truck, no more. There is margin. Use it at your own risk.
Tom
LinkBack to this Thread: http://www.tundrasolutions.com/forums/towing/72933-towing-over-1k-trailer-brakes-required/
Posted By For Type Date
Woodalls Open Roads Forum: Toy Haulers: Do I Need Electric Brakes.....? This thread Refback 02-07-2007 12:00 PM
Woodalls Open Roads Forum: Toy Haulers: Do I Need Electric Brakes.....? This thread Refback 11-28-2006 10:50 AM
RV.Net Open Roads Forum: Toy Haulers: Do I Need Electric Brakes.....? This thread Refback 11-27-2006 11:36 PM
RV.Net Open Roads Forum: Toy Haulers: Do I Need Electric Brakes.....? This thread Refback 11-27-2006 11:18 PM
RV.Net Open Roads Forum: Toy Haulers: Do I Need Electric Brakes.....? This thread Refback 11-27-2006 10:57 PM
TBDW Towing without trailer brakes cviator Brakes 9 05-03-2009 08:55 PM
7000 mile trip with 3000 mile towing with Tundra and Outback BaseCamp Towing 20 02-25-2008 08:55 PM
Towing car with Uhaul trailer darkday Towing 34 01-26-2007 08:40 PM
brakes on a utility trailer? hillbillym16 Towing 2 04-24-2006 01:18 PM
towing without trailer brakes? covingtontundra Brakes 3 09-29-2004 03:45 PM
