Old 10-23-2006, 02:04 PM
Herbicidal's Avatar
Just a Herbicidal maniac.
2001 Toyota Tundra,
2008 Toyota Yaris Sedan 'S' Flint Mica,
2009 Toyota Corolla 'S' Barcelona Red
Last Online: 11-20-2009 01:17 PM
Images: 150
Herbicidal's Photo Albums
Smile Doran tire pressure monitoring system.
Web link: Doran tire pressure monitoring system
After my recent experience of having 2 wheels come off (sheared wheel studs) our Outback travel trailer, I decided I needed some type of tire monitoring system. A fellow Tundra owner (thanks RockyMtnRay!) recommended the Doran system. I placed my order and received it last week. I ordered the monitor and 4 sensors since we have a double axle trailer. I followed the instructions closely and the system is very easy to set up. I bought the optional suction cup windshield mounts and found out that I need to bend the metal brackets quite a bit to attach it to the windshield and to tilt the monitor unit out so that it could rest on the dash. Once I was satisfied with the location and angle of the monitor, I attached the mini rubber antenna and the power cord. Then I plugged it in and set it to the program mode, I inflated each tire to the recommended 50 psi. The monitor 'flashed' the position of the tire for the first sensor. Then I took the first sensor and carefully, but quickly screwed it onto the valve stem. Once the sensor was on and sending out a signal, the monitor detected it and then I moved onto the next wheel, repeating the process until all four sensors were on and transmitting.
When the sensor is screwed onto the valve stem the very first time it transmits the tire pressure to the monitor. I had used my trusty analog air pressure gauge (NOT the pencil type) to set the tire pressure at 50 psi per the tire manufacturer. However, when I mounted the first sensor it transmitted a tire pressure of 56 psi. I'm not sure how accurate the sensors are. The other three, showed the pressure between 55 and 56 psi per tire, so at least they are consistent. I have since ordered a digital tire pressure gauge from these folks: Hi-Tec digital tire gauge. My other pressure gauge is rather on the old side and may have lost some of it's accuracy.
This past weekend we traveled about 400 miles while towing the trailer with the monitoring system in place. This time around, I had no problems whatsoever. I did have peace of mind knowing that the tires were monitored and that I would not be caught with a leaking tire or a flat and not knowing about it until it was too late.
Once we were back home, I marked the sensors with fingernail polish identifying their positions relative to the trailer, then unscrewed them and stored them in a plastic zip-lock bag until the next trip. This way I will get them back on in the position that the monitor has recorded for each of them.
So far, so good.
Old 12-13-2006, 11:26 PM
mustang67408's Avatar
KE7WLF Master of Disaster
Dealer : Findlay Toyota Scion
2002 Toyota Tundra,
- Other - 1967 Mustang,
2005 Toyota Prius,
2005 Toyota Tundra DC,
2008 Toyota Sienna RAMPVAN
Images: 164
Default Re: Doran tire pressure monitoring system.
I must agree. I have the same sensors for my trailer and they did as advertised. They alerted me to 2 low tires on the way back home from a roadtrip.
They were easy to install and use.
Herbicidals write-up is dead on the money.
25 yrs with TOYOTA
Old 12-17-2006, 12:38 PM
THarms's Avatar
Dealer : Eddy's Toyota of Wichita
2001 Toyota Sequoia Limited 4x4,
1999 Toyota Camry-Solara SLE,
1995 Toyota T100 DLX,
2009 Toyota Camry HV (wife's car)
Last Online: 10-04-2009 05:29 PM
THarms is on a distinguished road.
THarms's Photo Albums
One thing to remember is just because a tire gauge is digital does not necessarily mean that it is more accurate. Both digital and conventional gauges typically use either springs or diaphragms on the pressure sensor.. just a digital is much easier to read.
2009 Camry Hybrid (wife's car)
2001 Sequoia Limited (family SUV)
1999 Solara SLE (kid's car)
1995 T100 4x4 (my toy)
Old 12-18-2006, 11:12 AM
Herbicidal's Avatar
2001 Toyota Tundra,
Images: 150
In my case, the analog gauge was due for replacement, I just didn't know it until hooking up the tire pressure sensors and seeing a big difference in the indicated pressures.
The new digital gauge reads the same as the tire pressure sensors, so now the readings I get are consistent. I guess the main point is that tire pressure gauges loose accuracy over time and it's a good idea to check against another source.
Tire Pressure Monitor System PagalDesi4Life Aftermarket Products 6 08-18-2008 01:39 PM
where is the tire pressure warning system reset switch on a Highlander? nsx300zx Highlander 2 10-16-2006 12:17 PM
Tire Pressure Monitoring Valves Himself 1Gen-Tundra 0 04-03-2006 11:40 PM
tire pressure monitoring system mdaigle 1Gen-Tundra 18 02-22-2006 02:04 PM
Tire pressure monitoring system question NateF0022 Audio & Stereo 2 01-29-2006 03:39 PM
