Old 11-28-2006, 02:35 AM
Dealer : Peace Arch Toyota
- Other - 2 92 4runners
Last Online: 03-23-2007 06:19 PM
Slime green cat is on a distinguished road.
Slime green cat's Photo Albums
Default Towing with a 92 4runner with an auto trans
How do the auto trannys in the pre 96 4runner stand up to towing ?
I just bought a 92 4runner V6 auto , and plan to tow my Yamaha Rhino (1200 lbs) on a 5x10 utility trailer (1000 lbs) , throw in some gear and myself , and I figure a total load of about 2500 lbs , maybe up to 3000lbs on occasion .
Is this too much to ask of the auto trans in this rig ?
I have had a few 4runners and several Toyota trucks , but all 5 spds .....never owned an auto
I heard once that the auto's in these were weak ??? anyone hear of this ?
This truck does not have a hitch , so obviously it doesn't have the factory tow pkg , wich I guess is sort of a good thing , so the motor and tranny have never pulled , so they should be in good shape .
Did the tow pkg on these include a tranny cooler ? I might have to add an aftermarket one ....what do you guys think ???
I will only be towing every other weekend , and mostly only an hour or two from home , but will be venturing into the mountains , so there will be some long hills to pull .
So what do you think ?? am I going to be replacing tranny's every 6 months ? or is it up to the task ??
Thanks for any input
Old 11-28-2006, 08:43 PM
Default Re: Towing with a 92 4runner with an auto trans
Anybody ???
Someone must have had one of these at one time , and did some towing with it ??
I want to get a hitch on it asap , but if it is not going to handle the load , I wont waste my money on a hitch I will just swap vehicles with my wife when I am going to tow (hers is the same truck , but with a 5 spd)
I would rather not have to be swapping trucks , switching car seats , cd's for the road you know how it is
So , will my auto tranny do the job ??? should I go ahead and install the hitch ???
Help .........
Old 11-29-2006, 07:27 PM
Moderator
Dealer : Performance Toyota
2008 Toyota Tundra Slate SR5 4x4,
2005 Toyota Sienna XLE
Last Online: 11-21-2009 07:07 AM
Images: 23
tomhole's Photo Albums
Might not be a large 4Runner following on here. At least ones that tow. Might want to try rv.net as there are a lot of folks that tow stuff with all manner of vehicles. Might get lucky. Sure wish I could help, but I must plead ingnernce on your questions.
Tom
Old 11-29-2006, 07:48 PM
Originally Posted by tomhole View Post
Might not be a large Pathy following on here. At least ones that tow. Might want to try rv.net as there are a lot of folks that tow stuff with all manner of vehicles. Might get lucky. Sure wish I could help, but I must plead ingnernce on your questions.
Tom
Pathy ??????
My question is about my 92 4runner ...... not a pathfinder
Thanks anyways
Old 11-29-2006, 07:59 PM
Moderator
Images: 23
Sorry, lost my mind for a moment.
Tom
Old 12-05-2006, 03:05 PM
celica's Avatar
Dealer : Charlesglen Toyota
2003 Toyota Sequoia
Last Online: 11-11-2009 10:26 AM
celica is on a distinguished road.
celica's Photo Albums
I have a 92 4runner with a V6. I tow with mine all the time. Mine is a standard though. Wright shouldn't be an issue as the limit is 3500#. You will want a cooler for the tranny. After the cooler you should be fine. I have towed 5000# in mine before. go to yotatech.com There are a ton of 4runner people there. It is most 4runners actually., I am on there as well.
Matt
2003 4runner Limited
2003 Sequoia Limited
1989 Supra Turbo
Old 12-06-2006, 12:48 AM
Thanks for the reply Celica
After several days with no replys , I happened to stumble on Yota tech .
I posted the question there and got a reply in 5 minutes , and several more in a day or 2 .
I am going to try my luck towing without a tranny cooler , and if I like the way it tows , and decide to keep this 4Runner , then I will put a cooler on before the heat of the summer and my trips in to the mountains
Old 12-08-2006, 01:21 AM
Only Toyota for me's Avatar
Dealer : Karl Malone Toyota
2008 Scion tC Daughter's car
Last Online: 11-21-2009 03:00 AM
Images: 44
Only Toyota for me will become famous soon enough.
I owned a 99 auto 4runner & towed my 22' toyota boat with it.(3000lbs)
I did not put a tranny cooler on it and i burned the transmission oil.
The oil turned brown quite often and it should always be red. I put a tranny cooler on it and it was fine.
So, if you're going to keep it, put a tranny cooler in it. I think i paid about $90 or so for mine installed.
Solid rig though.
Old 12-10-2006, 01:25 PM
Thanks for the reply , sounds like I should get the tranny cooler sooner than later .
I didn't know they were that cheap , for that price I will throw one on right away
Old 12-22-2006, 05:55 PM
Marazzito's Avatar
Dealer : Toyota 101
2007 Toyota Tacoma,
2006 Toyota Highlander HV,
- Other - 1967 TLC FJ40
Last Online: 02-15-2009 12:16 PM
Marazzito is on a distinguished road.
Send a message via AIM to Marazzito Send a message via Yahoo to Marazzito Marazzito's Photo Albums My eBay
I had a 90 4runner 4WD with the tow package and towed several times with it. You can take it all the way to the max 3,500 lb limit with out a problem. I would recomend a slight lift in the rear to correct the natural sag that is very noticable wile towing. I had a 1.5" HD Downey rear springs in mine with Rancho RS9000's, leveled the vehicle and towed much more stable.
Old 12-24-2006, 01:28 AM
Was yours an automatic ?
Old 01-12-2007, 09:10 PM
Marazzito's Avatar
Dealer : Toyota 101
2007 Toyota Tacoma,
Yep, with factory tow package. Sorry for the late responce.
Towing w/ a V6 ace57 Towing 62 09-02-2009 04:00 PM
Fifth Wheel Towing & Hitch Questions/Help/Info yay Towing 300 07-22-2009 11:41 PM
Is there anyway to make the stock auto trans shift any firmer? CAracer Engine & Drivetrain 30 07-13-2009 02:07 PM
durability of A340F auto tranny and related info (long) nhparrot Engine & Drivetrain 0 03-28-2002 04:22 PM
