Re: Max hitch weight
Originally Posted by jbout
I want to buy a Skyline Aljo 250LT. I plan on using an Equal-iz-er brand hitch. (2005 Tundra AC limited)
UVW 5180
GVWR 6440
Tounge weight Dry 675
Skyline certifies these weights from the factory on each trailer, after options are added. My main concern is the tounge weight, after you add propane, battery, and hitch. Tounge weight could come close to 900#. Is this to much for the Tundra? My manual says not to exceed 730# with weight distrubution.
Recheck your manual, carefully. IIRC, the manual for my '03 says I can go up to around 1100 lbs tongue weight with a weight distributing hitch. 730# sounds about the limit when a WDH is not used.
Ray
