Go Back   Toyota Tundra Forums : Tundra Solutions Forum > News and Events Forums > Toyota, Scion & Lexus News
Closed Thread
Old 09-12-2006, 08:57 AM
Dealer : Michael Toyota
TS Support is on a distinguished road.
TS Support's Photo Albums
Default New Lexus RX 350 Adds Power Plus Technical and Convenience Features for 2007
09/12/2006
September 12, 2006 - Torrance, CA - The new 2007 RX 350, which arrived in dealerships in spring 2006, entered the market as a more powerful version of its best-selling predecessor, the RX 330. The Lexus RX has been the most popular vehicle in the car-based luxury SUV segment that it established in 1998. The 2007 RX 350 introduced a new 270-horsepower, 3.5-liter V6 engine that improves both performance and fuel efficiency over the 2006 RX 330's 223-horsepower, 3.3-liter V6.
The RX 350 delivers all-weather performance in both front- and all-wheel-drive models. The 2007 model also gains new luxury and convenience options and additional refinements for enhanced drivability, such as the available factory-installed rear-seat DVD entertainment system, which gains a nine-inch screen for a substantially larger viewing area over the previous seven-inch screen. Also new for 2007, a direct-type Tire Pressure Monitor (TPM) system replaces the previous indirect system and alerts the driver via a warning light on the instrument panel if a significant drop in tire pressure is detected in any of the tires.
"The RX 350 offers even better performance than the 2006 RX 330, while still delivering Lexus' trademark quiet ride and uncompromising value that have made the RX the undisputed segment leader for eight years in a row," said Bob Carter, Lexus group vice president and general manager. "Other enhancements reflect the renowned attention to detail that continues to make Lexus the overall leader in the luxury-vehicle market."
Engineered at the outset to accommodate a hybrid powertrain, the RX 350 shares its platform with its hybrid counterpart, the RX 400h. The Lexus RX 350 is produced both in Japan at the Kyushu plant and at Toyota Motor Manufacturing, Canada.
Powerful New V6
The 2007 RX 350's new 3.5-liter V6 engine produces 270 horsepower and 251 lb.-ft. of torque, increases of 47 horsepower and 13-lb.-ft. over the previous model. Featuring all-aluminum construction, the V6 harnesses the benefits of advanced technologies to improve performance and fuel efficiency as well as reduce emissions. Dual Variable Valve Timing with Intelligence (VVT-i) helps optimize torque for quick and powerful response at all engine speeds. The Electronic Throttle Control with intelligence (ETC-i) helps to manage idle speed, cruise control, Traction Control (TRAC), and Vehicle Stability Control (VSC).
The FWD RX 350 launches from zero to 60 mph in just 7.3 seconds; the AWD model in only 7.4 seconds. Performance of the 2007 RX models is comparable to the output of some competitive V8 models, while still providing a best-in-class fuel-economy rating.
The RX 350's five-speed electronically controlled automatic transmission receives enhanced tuning for more refined drivability as well as improved fuel efficiency. The EPA-estimated combined fuel economy rating for the RX 350 is 22 mpg (20 mpg city/25 mpg highway) for the FWD model and 21 mpg (19 mpg city/24 mpg highway) for the AWD model. The 2007 RX 350 maintains the previous model's ULEV II emissions certification.
Full-Time All-Wheel Drive with Vehicle Stability Control
To couple with the newly gained additional horsepower and torque of the V6, the all-wheel drive RX 350 uses a viscous limited-slip center differential to enhance drivability in all types of driving conditions. The full-time AWD system works with TRAC to evenly distribute power to both axles with a constant 50/50 front-to-rear power split. If slippage occurs, the viscous coupling differential directs torque to the wheels with the most traction.
Both RX 350 models come standardly equipped with the Vehicle Stability Control (VSC) system, which helps control loss of lateral traction while cornering. VSC helps keep the vehicle going on its intended course by detecting front- and rear-wheel slide during cornering, attempting to control either condition with torque intervention and, if necessary, by applying the necessary brake pressure to the individual wheels.
VSC and Brake Assist work with the standard Anti-lock Braking System (ABS). Brake Assist is designed to determine if the driver is attempting emergency braking. If the driver has not stepped firmly enough on the brake pedal to engage ABS, the system applies increased braking power until the driver releases pedal pressure.
Serene Driving, Agile Handling
Lexus' RX models have set the benchmark for smooth, quiet ride quality in their segment for nearly a decade. A rigid body structure, vibration-canceling engine mounts, sound-absorption materials, and refined aerodynamic details all contribute to maintaining that standing. The 2007 model yields further enhancement to the already exceptionally quiet ride by adding an acoustic glass windshield; supplementary sound insulation in the door panels, instrument panel, and floor mats; and recessed covers for lower front fascia intakes to reduce turbulence near A-pillars and door mirrors.
The high-strength platform, standard 17-inch wheels and tight steering control help optimize handling response in the RX 350. Eighteen-inch wheels are also available.
An optional air-suspension system provides automatic leveling with four height settings to allow the driver to tailor the RX 350 to specific driving conditions or needs. In "normal" mode, the system automatically lowers the RX 350 by 0.3-inch at speeds over 62 mph for better ride quality. Selecting the "low" mode lowers the ride height by 0.6-inch to enhance handling response, while "high" mode raises ground clearance by 1.2 inches for driving over rough surfaces at speeds under 30 mph.
An "access" mode lowers the RX 350 by 1.2 inches to provide easier entry, exit and loading. All RX 350 models with the air suspension system are equipped with a multimode sequential automatic transmission.
Comprehensive Safety Design
A high-strength cabin design and comprehensive Supplemental Restraint System (SRS) are designed to help provide a high level of crash energy management for all occupants. SRS includes advanced driver and front passenger airbags, a driver's knee airbag, and front-seat-mounted side airbags designed to help protect the torso, abdomen, and pelvis. The front-airbag technology takes into account several factors, such as crash severity, passenger weight, and driver-seat position. The standard side-curtain airbags employ a roll sensor and can inflate if a predetermined threshold of vehicle-roll angle is detected.
The RX 350 offers options designed to help improve visibility for night driving and poor weather conditions. While rain-sensing windshield wipers and high-intensity discharge (HID) headlights are expected in this segment, Lexus further offers an Adaptive Front lighting System (AFS) for better illumination in turns and curves.
With AFS, a central controller calculates the optimum lighting direction based on input from vehicle speed and steering angle and then swivels the right and left headlights independently accordingly. The left beam can rotate from zero to 15 degrees in a left turn while the right beam remains in the center position. The right beam can rotate from zero to five degrees in a right turn while the left beam remains in a center position. A self-leveling feature, similar to HID, automatically levels the lights depending on road conditions, and an on/off switch allows the driver to disengage the AFS system at any time.
Versatile Utility and Convenience
The RX 350's 106.9-inch wheelbase and 186.2-inch length result in an easy-to-drive, easy-to-park vehicle that provides roomy comfort for five occupants. The rear seatbacks feature a versatile 40/20/40-split design and offer both sliding and reclining adjustments. The 38.3 cu. ft. rear cargo capacity expands to 84.7 cu. ft. with the rear seatbacks folded down, while an automatic retracting tonneau cover adds security and convenience.
The standard power rear liftgate can be programmed for one-click opening via the keyless remote control for a hands-free cargo-area opening. While a beeper sounds when the door is opening and closing, touch sensor on the door will also sense if something is impeding the hatch and stop it from closing.
An auto-dimming rearview mirror with an integrated digital compass is standard, as are auto-dimming and heated exterior mirrors. The integrated Homelink® transmitter can control a variety of compatible home-security devices and systems. Additionally, the RX 350 offers an available Dynamic Laser Cruise Control system, which measures and maintains a set distance from a vehicle traveling ahead.
Fifth-Generation Navigation System
Lexus' fifth generation DVD Navigation System is optionally available on the RX 350 and includes voice-recognition that allows the driver to input a desired destination by voice command while driving. The updated fifth-generation system is offered in conjunction with a rear back-up camera that provides the driver a view of what its lens can detect behind the vehicle. It automatically projects a color image on the navigation system's seven-inch VGA screen when reverse gear is engaged.
This latest-generation navigation system greatly enhances visual support with a central screen that features a high-resolution 800 x 480 pixel display in 32,000 colors. On-screen details are crisp and clean, and maps and roads include 3-D shadow effects. The new system also adds Spanish to the already available English and French text-display options. Users can select the language preference at system start-up.
The DVD map database contains more than five million Points of Interest (POI). The database for Chicago, Detroit, Los Angeles, and New York includes a "building footprint" display feature that exhibits graphic representations of buildings and structures to help the driver identify surroundings. System functions include multiple route calculations, route preview, simplified highway junction graphics, and a dual-map screen mode.
The navigation system also integrates Bluetooth® wireless technology. When combined with a compatible phone, Bluetooth allows the driver to transfer personal phone books to the navigation system and make hands-free phone calls through its touch-screen control panel.
Lexus Benchmark Luxury
Lexus' craftsmanship and renowned attention to detail provide sumptuous comfort by design. Standard dual-zone automatic climate control, 10-way power front seats with available memory, a sliding center console, adjustable light in the visor vanity mirrors, and wood interior trim set the tone for luxury in the RX 350. Luxury extends to the smallest details, such as illuminated front cup holders and a wood- and leather-trimmed steering wheel with integrated audio-system and trip-computer controls.
Premium options include a power-tilt/telescoping steering wheel with memory, and an illuminated entry system that lights the door handles, scuff plates, and front footwells.
A unique, wide-opening multipanel moonroof is an optional alternative to the optional conventional moonroof. With an open area that is 150 percent larger than a normal moonroof and an illumination area that is 250 percent larger, the multipanel moonroof is made of three separate glass panels. The front small panel is angled to reduce wind noise, the rear panel slides backwards on top of vehicle, while the middle glass panel slides backwards on top of rear panel.
The RX 350's hushed interior provides a superb listening environment for the standard premium, satellite-ready, eight-speaker AM/FM/CD audio player with in-dash six-disc CD changer. The system is compatible with MP3/WMA-formatted CDs and includes an Automatic Sound Levelizer (ASL), Radio Data System (RDS), and a digital signal processor.
An 11-speaker Mark Levinson® Premium Audio System is optionally available. This audiophile-pleasing system features an in-dash six-disc DVD/CD changer, DVD-audio, and DVD-video playback as well as remarkable sound clarity at all volumes, with 210 watts at 0.1% THD, 20-20,000 Hz.
Prevailing Quality
The RX 350 builds upon its history of popularity and reliability. The Lexus RX has proved to be not only the segment sales leader, but the quality leader, as well. In both 2004 and 2005, the previous RX 330 was named the highest ranked entry luxury SUV in J.D. Power and Associates' Initial Quality StudySM (IQS). Additionally, the predecessor RX 300 was the highest-ranked entry luxury SUV in the J.P. Power & Associates 2005 Vehicle Dependability Study SM (VDS), which measures problems experienced by original owners of 2002 model-year vehicles.
Premium Protection
All new Lexus vehicles come with a 48-month/50,000-mile basic limited warranty with roadside assistance for 48-months/unlimited miles. Powertrain and restraint system coverage is provided for 72 months/70,000 miles. Corrosion perforation protection is covered for 72 months, regardless of mileage.
Closed Thread
Lexus SC 430 Offers Ultimate Convertible Luxury TS Support Toyota, Scion & Lexus News 0 09-12-2006 08:55 AM
