Go Back   Tundra Solutions Forum > Technical & Vehicle Assistance Forums > Truck Bed Tonneau Covers
  #16 (permalink)
Old 06-29-2009, 03:24 PM
Last Online: Yesterday 12:00 PM
e-bear is on a distinguished road.
e-bear's Photo Albums
Default Re: Retrax
I'm also on the verge of buying the Retrax but I'm a little nervous about the "not 100%" waterproof issue. Someone please make me feel better.
  #17 (permalink)
Old 06-29-2009, 10:27 PM
jhip's Avatar
Dealer : Servco Auto Center
Last Online: Today 04:11 AM
Images: 5
jhip is on a distinguished road.
Send a message via AIM to jhip jhip's Photo Albums
Default Re: Retrax
Put the Retrax cover on couple months ago. I washed the truck not too long ago and didn't notice any water leaks in the bed. I wasn't excessively shooting the cover with water to look for leaks so I'm not sure it's 100% waterproof (doubt that it is). It's the cleanest and best looking cover on the market IMO. I don't use my truck for work so I didn't mind sacrificing bed space. I was more concerned with securing what's in it.
If you have long items, just put them in diagonally and in most situations, you should be okay especially with a bed extender.
  #18 (permalink)
Old 07-01-2009, 12:14 AM
Default Re: Retrax
This looks like the gasket you're looking for Spleck. TrailSeal Tailgate Gasket I haven't actually purchased the Retrax yet but darn soon I think. I'll check to see if there is a product code on the gasket they send me.
  #19 (permalink)
Old 07-01-2009, 08:44 AM
Dealer : Arlington Toyota Scion
- Other - 2003 Accord 6MT,
2004 Toyota RAV4 L 2WD,
2006 Toyota Tundra Limited DC 4WD
Last Online: 07-17-2009 10:54 AM
spleck is on a distinguished road.
spleck's Photo Albums
Default Re: Retrax
Thanks for finding that! If my local Retrax/LineX place doesn't have it, I may have to go with that if the 3M product code isn't available. The only difference I see with that TrailSeal is that it has a V-shape for the lower portion--I seem to remember the Retrax stuff being flat. The V-shape might be beneficial for other applications.
  #20 (permalink)
Old 07-01-2009, 11:25 AM
pistolpete's Avatar
Dealer : Crystal Toyota
2004 Toyota Tundra 4X4 SR5 Double Cab
Last Online: Yesterday 12:22 PM
Images: 163
pistolpete is a name known to all. pistolpete is a name known to all. pistolpete is a name known to all. pistolpete is a name known to all. pistolpete is a name known to all. pistolpete is a name known to all. pistolpete is a name known to all.
pistolpete's Photo Albums
Default Re: Retrax
Originally Posted by WRXRacer111 View Post
What I did and what I think the Retrax instructions suggest, is drilling holes in the oval-shaped plastic plugs at the front of the bed. Route the drain tubes through there. I just used a utility knife to cut an "X" through the plastic plug and routed the drain tube through that. That way you're not drilling any metal etc. and it's pretty easy. Worse comes to worse, you can order new plug or, pop them out and spray them with spray-on bedliner to seal them.
or you could drill a hole in the plastic plug the same size as the tubing so as to try and remain as water tight as possible....better yet...I've found the supplied tubes to be too small to let debris (leaves, seeds, pods, bits of mulch) pass thru...one winter I had a huge block of ice in the canister because the tubes were blocked and water didn't drain before it froze....thus I came up with the following mod which increases the tube size, prevents clogging, secures the tube and prevents it from getting knocked loose by sheets of plywood or anything else you throw back there, and makes the fitting attached to the canister water tight (supplied material is simply a compression fitting with a rubber grommet that doesn't stay in place when trying to attach the tube)....
you can check out my Retrax modification in my photo gallery HERE
Pistol Pete
#1 COLTS fan!!!!
2004 Toyota Tundra Double Cab 4X4 (7844A), Phantom Grey Pearl, All weather guard package, fog lamps,keyless entry, 17" AA wheels, towing package, color-keyed overfenders, 4.1mm Limited Slip Diffy, Delux 3-in-1 JBL stereo, privacy glass, floor mats with sill protectors, bed extender
MODS- Line-X, Retrax, Onki nerf boards (part #328078), Wade vent visors (part #88401) , TracRac (rail # OL-21609), Ultimate Fly Fishing Rod transporter, Spin Caster Rod holder in bed, Recon bedlights fully adjustable w/"nightvision", HitchSafe, Weathertech floor liners (part #46030-1&2, grey), debadged, visors destickered, rear window stop disabled, dynolock/PL8500 power tailgate lock, tailgate protector mod with detachable floormat, Stebel Nautilus Compact Truck Air horn (300Hz), quick fist flashlight holder (all in photo gallery).....more custom suprises on the way!!
New members from the MidAtlantic (PA,OH,WV,VA,MD,DE,NY,NJ,DC) don't forget to check into the MidAtlantic Forum and introduce yourself!!!
  #21 (permalink)
Old 07-02-2009, 04:18 PM
jdubh's Avatar
Dealer : Bert Wolfe Toyota
2008 Toyota Tacoma,
2008 Toyota Tundra Limited 4x4 DC BlueS,
- Other - 2005 Accord EX-L
Last Online: Today 02:03 PM
Images: 9
jdubh is on a distinguished road.
jdubh's Photo Albums
Default Re: Retrax
I have the retrax and haven't figured out how to close the gap on mine...does the tailgate gasket go on the cover or on the tailgate? I imagine if it was on the tailgate it would get torn off easy. But even with a small gap in mine, not much water gets in...not like i'm keeping electronics back there, just a couple rubbermaid boxes of tools and a baby stroller.
2008 Blue Streak Metallic Double Cab 4x4 Limited 5.7L
2009 Outback 310BHS Sydney Edition 10,060lbs 35'10"
Prodigy, Retrax, Equal-i-zer, Load Lifter 5000
  #22 (permalink)
Old 07-18-2009, 04:04 AM
Default Re: Retrax
I just installed a Retrax on my CrewMax. I was aprehensive about how the shiney surface would look but I think I kind of like it. They could have made it a little longer in my opinion as I would have liked a longer overlap on the tailgate but the bottom line is that it is adequately long enough and does fit.
I've also decided to let the drain tubes just dangle in the back corners of the bed. (I've got a LineX). I figure that whatever drains in will evaporate. I live in Southern California and rain and freezing are not an issue. In any case, there is little chance of water getting into the canister when the Retrax is fully closed. The only thing you really have to worry about is what's on top of the cover when you close it. If you happen to open up the cover in the pouring rain, well, then you've got a lot more water to worry about than what happens to get into the canister.
I bought my Retrax direct from the manufacturer at RETRAX truck bed cover pickup bed cover tonneau cover roll top cover. I negotiated free shipping and a free tailgate gasket but I also tossed them a bone by buying the Cargo Mate which is two bungee cords and four eyelets made to fit on the clamps. Out the door for under one thousand. They are real easy and friendly to work with. I recommend going direct.
Regarding the tailgate gasket. it is flat and does not have the "V" shape adjacent to the bead like the TrailSeal gasket. It seems like they would both work and they are about the same price. Unfortunately, there was no product code in the bag so I guess the hunt is still on for the ideal third party gasket source.
Generally, I've got a good first impression of the Retrax.
  #23 (permalink)
Old 07-20-2009, 04:57 PM
123Gone's Avatar
Dealer : Toyota Of Fort Worth
2005 Toyota Tundra
Last Online: 11-04-2009 02:19 PM
123Gone will become famous soon enough.
123Gone's Photo Albums
Default Re: Retrax
I would recommend you drill a hole in the plastic caps (see pic). You could easily replace the caps if you ever needed to.
If you have not yet installed the tailgate seal, you might want to wait. It's thick and ugly and most people don't need it. Try driving around without it first.
  #24 (permalink)
Old 07-21-2009, 04:45 PM
jdubh's Avatar
2008 Toyota Tacoma,
Images: 9
Default Re: Retrax
I've had my retrax for six months and haven't installed the gasket yet, but I would like to see a picture of where it goes if anyone has one.
