Re: Anyone have Access Vanish?
I have one for my 2005 Access Cab. It is nice. The velcro doesn't allow much air in to make it flap in the wind at high speeds. The tension lock at the tailgate is also nice. You can adjust the tension at the front of the bed, then lay the cover down, and lock it in at the tailgate.
For the "vanish" affect.... it's good stuff. Really is flatter than the OEM button down tonneau cover.
My Truck: 2005 Tundra, 2UZFE. 4WD. AccessCab. Spectra Blue Mica (8M6). TRD. AT. CC. CK. DZ. FE. AW. LD. OF. TO. VP.  Suspension & Tires: 285/75-16 BFG T/A'ko, Fabtech Coils, 1.5" Wheeler's blocks, Toytec Diff Drop, 1.25" Spidertrax [front], 1.5" Goeske Wheel Adapters [rear] Handling: TC Poly Steering Rack Bushings, Downey HD End Links, Wheeler's Anti-Sway Kit, Hellwig 7700 Swaybar, Timbren Rear SES Electrical: URD MAF Sensor Calibrator, Superlift Truspeed Speed Sensor Re-Calibrator, ScangaugeII, Full LED Conversion Stereo: Alpine CDA-9886, Alpine & Phoenix Gold amps, Q-Logic box w/RF subs, eDead Cosmetic: Line-X Bedliner, Custom N-Fab Steps, Rear Diff Breather Extension, F103N Fumoto Oil Drain Valve, Debadged (partially), Bell Truck Trunk, Access Vanish Tonneau
