Go Back   Toyota Tundra Forums : Tundra Solutions Forum > Technical & Vehicle Assistance Forums > Truck Bed Tonneau Covers
Old 05-20-2009, 10:09 PM
pistolpete's Avatar
Dealer : Crystal Toyota
2004 Toyota Tundra 4X4 SR5 Double Cab
Last Online: Yesterday 11:40 PM
Images: 163
pistolpete is a name known to all. pistolpete is a name known to all. pistolpete is a name known to all. pistolpete is a name known to all. pistolpete is a name known to all. pistolpete is a name known to all. pistolpete is a name known to all.
pistolpete's Photo Albums
Default Retrax Drainage Improvement Modification
I got tired of having the small tubing (7/16" I.D.) on the Retrax get clogged with seeds and mulch that worked its way in as well as the tubes getting knocked off the unsecured fitting so I decided to improve the drainage design with larger tubing (3/4" I.D.) , 3/4" hose barbs and tubing clamps.
Simple install really...just drilled larger holes in the Retrax housing and the back bed wall plug. The only thing not pictured in my album pics is that a rubber gasket was placed between the Retrax housing and the conduit lock nut to prevent any water leaks. Picture of the finished product can be found below and more pics in my photo gallery....another thing I did while I was at it was to replace the screws in the side of the Retrax with allen wrench/hex heads for another mod that will be forth coming. I had to take the Retrax housing off to drill the new hole because I didn't want to go thru the whole trouble of removing the TracRac AND the Retrax and having to realign everything afterwards....it was a (*%(*$ to remove those side screws even with my 90° screwdriver as the screws were "frozen"/rusted into the tension bars.
Pistol Pete
#1 COLTS fan!!!!
2004 Toyota Tundra Double Cab 4X4 (7844A), Phantom Grey Pearl, All weather guard package, fog lamps,keyless entry, 17" AA wheels, towing package, color-keyed overfenders, 4.1mm Limited Slip Diffy, Delux 3-in-1 JBL stereo, privacy glass, floor mats with sill protectors, bed extender
MODS- Line-X, Retrax, Onki nerf boards (part #328078), Wade vent visors (part #88401) , TracRac (rail # OL-21609), Ultimate Fly Fishing Rod transporter, Spin Caster Rod holder in bed, Recon bedlights fully adjustable w/"nightvision", HitchSafe, Weathertech floor liners (part #46030-1&2, grey), debadged, visors destickered, rear window stop disabled, dynolock/PL8500 power tailgate lock, tailgate protector mod with detachable floormat, Stebel Nautilus Compact Truck Air horn (300Hz), quick fist flashlight holder (all in photo gallery).....more custom suprises on the way!!
New members from the MidAtlantic (PA,OH,WV,VA,MD,DE,NY,NJ,DC) don't forget to check into the MidAtlantic Forum and introduce yourself!!!
