Hi GIB187th,
You asked:
"Do Xtreme Flat tonneau covers lock?"
Answer: The new Tundra covers do not have a "lock" (with a key); instead, they "latch" from underneath. Most newer Tundra's are already equipped with a lock on the tailgate. Your truck bed would be secure with the cover latched and the tailgate locked. When closed, ALL you would need to do is open the tailgate in order to gain access to the latches that secure the cover. There is no need to open the cover everytime you need access to your truck bed. The absence of an exterior lock on the cover also eliminates having to carry (or LOSE!) an extra key and makes for a sleeker looking cover.
2nd question:
"Does it need inside bed rails...
Answer: Yes, the installation requires Toyota's "deck-rail' system. I believe this is standard on the Crew Max? The LT Sport cover bolts directly to the deck-rail system and therefore
no drilling is required.
The installation instructions for the 2010 Tundra are
identical to the 07-09's. You can find them on the website mentioned above.
...or any drilling of the bed?"
There is no drilling required to install the LT Sport Cover on your Tundra.
I hope this answers your questions?
