Old 05-14-2007, 10:01 AM
Dealer : Gray Daniels Toyota
Last Online: 10-23-2007 11:53 AM
TundraMaxxer may have some regrets.
TundraMaxxer's Photo Albums
Default Maintenance light re-set limitations
It would appear that the maintenance light comes on at 5,000 mile intervals. I changed my oil early, well before this light came on but there appears to be no way to re-set it back to zero. According to the manual, it can be re-set when the light comes on. If the light is not on, as with an early oil change, the re-set sequence doesn't seem to work.
Has anyone else tried this?
Old 05-14-2007, 10:52 AM
2007 Toyota Tundra 5.7L TRD Black
Last Online: 03-04-2010 05:31 PM
blackgts2002 may have some regrets.
blackgts2002's Photo Albums
Default Re: Maintenance light re-set limitations
i dont see why you cant reset it whenever.
why would you change it early
Old 05-14-2007, 11:14 AM
mxsjw's Avatar
Jedi Ninja in Training
Dealer : Toyota of Puyallup
- Other - 2003 VW Passat,
Images: 12
mxsjw has much to be proud of. mxsjw has much to be proud of. mxsjw has much to be proud of. mxsjw has much to be proud of. mxsjw has much to be proud of. mxsjw has much to be proud of. mxsjw has much to be proud of. mxsjw has much to be proud of. mxsjw has much to be proud of. mxsjw has much to be proud of. mxsjw has much to be proud of.
mxsjw's Photo Albums
Maybe he drives in what would be considered "severe" conditions.
Beer please!
Old 05-14-2007, 11:47 AM
Stripped Honda's Avatar
Dealer : Wondries Toyota
2007 Scion tC Flint Mica,
2007 Toyota Tundra DC Limited
Last Online: Yesterday 05:19 PM
Stripped Honda is on a distinguished road. Stripped Honda is on a distinguished road. Stripped Honda is on a distinguished road. Stripped Honda is on a distinguished road. Stripped Honda is on a distinguished road.
Stripped Honda's Photo Albums
what does it matter when people change their oil? i changed mine at 700 miles and will be done again at 3K to each is own and i rather have my engine running clean oil over having dark oil that will discolor the inside of my engine
yes you should be able to reset the light early i have done it on all other toyotas when they come in my shop
Old 06-10-2007, 04:28 PM
Big Ern's Avatar
Dealer : Peterson Toyota
Last Online: 02-12-2008 01:24 PM
Big Ern may have some regrets.
Big Ern's Photo Albums
Default reset the Maint Req light
Okay, I must have having another moment here, trying to reset the Maint Req light on the dash. Manual says to have the ODO showing, turn key to ACC or OFF, then back to ON while holding the trip reset for at least 5 seconds. If is doesn't work try again. I tried if 20 f'ing times and it still doesn't work. Anyone gotten this to work? Am I reading something wrong?
Old 06-10-2007, 06:03 PM
jliltd's Avatar
Dealer : Las Cruces Toyota
2007 Toyota Tundra 4WD DCab Longbed 5.7,
2001 Toyota Sequoia (Wife's Broomstick)
Last Online: 02-20-2010 10:48 PM
jliltd may have some regrets.
jliltd's Photo Albums
Default Re: reset the Maint Req light
The manual is terrible for this if you don't have the multi-function display (i.e. SR-5 or lower trim level). I called the Toyota 800 number and they were confused and kept referring to non-existant owner's manual pages. Here is the trick: You have to have the odometer set to "Trip A" before starting the process. So put it on "Trip A". Turn off the key. Hold the reset button and turn the key back on and wait.
"The beauty of the second amendment is that it will not be needed until they try to take it." -- Thomas Jefferson
Old 06-10-2007, 06:10 PM
1998 Toyota Tacoma 4x4 TRD,
- Other - 2004 Dodge Dakota
Last Online: 03-16-2010 10:21 PM
StevJ may have some regrets.
StevJ's Photo Albums
1. Turn the ignition switch to the “IG-ON” position and make sure that the odometer is set to “TRIP A”.
2. Turn the ignition switch to the “ACC” or “LOCK” position.
3. While pushing the “TRIP” meter reset knob, turn the ignition switch to the “IG-ON” position.
4. With the ignition switch in the “IG-ON” position, keep holding the “TRIP” meter reset
knob (for at least 5 seconds) with the LCD counting down as shown in the illustration.
When the reset is complete, the display will show “000000” for 1 second. Then the maintenance light will turn OFF.
5. Release the “TRIP” meter reset knob when the reset is complete.
Old 06-10-2007, 06:16 PM
waynebyrom's Avatar
Dealer : Cavender Toyota
Last Online: 10-22-2008 09:22 AM
waynebyrom may have some regrets.
waynebyrom's Photo Albums
This is how I do it too and it works for when I reset it because it will come on when its time to change your oil. I have to reset it and the instructions mentioned here are correct.
Old 06-10-2007, 06:58 PM
Big Ern's Avatar
Great, I'll give it a try, sounds like TripA is the difference. (My manual says to be in ODO mode, not Trip A or Trip B.)
Old 06-11-2007, 09:04 PM
Dealer : Conicelli Toyota Scion of Springfield
Last Online: 03-07-2010 11:03 AM
kevink may have some regrets.
kevink's Photo Albums
It works, I have been trying for 3 days to follow the owners. manual. The Trip A trick worked like a charm. So much for Toyo proofreading.
The dealer tried to give me the wrong oil filters not once, but twice, and they were quite damn insistent about it as well. Just speak very loud and slowly C-A-R-T-R-I-D-G-E F-I-L-T-E-R.
Old 06-15-2007, 10:44 AM
Default Re-setting the "Maintenance Required" light
At first I had a little confusion, but I think I finally have it figured out. The manual has simple instructions on how to re-set the 'maintenance required' light when it starts coming on. For me, however, I changed my oil in the new truck at about 1,900 miles (I just wanted to get an oil change done with a new filter).
Funny thing was, the maintenance req'd light was not blinking when I changed the oil, so there was no need to re-set it. I even went through the steps outlined in the manual to re-set it but unless it NEEDS to be re-set it will not re-set itself. Sure enough, at the expected mile interval, it came on and started blinking.
By then, of course, I was in the middle of my oil change interval and really didn't need another oil change. So I'm going to allow the light to keep coming on (just for a few seconds after startup) until I change my oil again. Then I can re-set it AT THAT TIME, and then it will be coming on at the right intervals.
Old 06-15-2007, 10:52 AM
Default Re: Re-setting the "Maintenance Required" light
IN 500 miles, it wont just blink, it will be constant.
Old 06-15-2007, 12:54 PM
2007 Toyota Tundra,
- Other - 65 malibu
Last Online: 01-20-2010 03:03 PM
grpweld may have some regrets.
grpweld's Photo Albums
Well I did the infamous oil & filter change @ 4784 MI. the maint. light was blinking for approx. 5 seconds at each startup at that time. I followed the directions in the manual for resetting the maint.light, it would not reset! 25 miles latter it is still blinking at start up (what gives)
2007 tundra sr5 5.7 4x4 slate metalic 18's
Old 06-15-2007, 01:11 PM
Dealer : Avondale Toyota Scion
Last Online: Yesterday 09:07 AM
LeeinAZ will become famous soon enough. LeeinAZ will become famous soon enough. LeeinAZ will become famous soon enough. LeeinAZ will become famous soon enough. LeeinAZ will become famous soon enough. LeeinAZ will become famous soon enough. LeeinAZ will become famous soon enough. LeeinAZ will become famous soon enough.
LeeinAZ's Photo Albums
'07 Tundra SR5, 2WD DC, 5.7L, Salsa Red Pearl with Running Boards, Delta Toolbox.
Old 06-18-2007, 06:14 PM
fivecodys's Avatar
Dealer : Madera Toyota
2007 Toyota Tundra 5.7L DC 4x2
Last Online: 03-20-2010 10:10 PM
fivecodys may have some regrets.
fivecodys's Photo Albums
Thank you very much.
Bill
2004 Sequoia Front Dome Light Mod Ndcent1 Electrical & Computer Systems 25 06-09-2009 08:20 AM
How to Reset the CE (MIL) Light? Pro40Dually 1Gen-Tundra 9 07-05-2008 07:02 AM
Different Fog light mods? nhparrot Electrical & Computer Systems 5 04-17-2007 01:27 AM
