How does the tire pressure monitoring system work?
+ Reply to Thread
Page 1 of 2 12 LastLast
Results 1 to 15 of 29
Thread: How does the tire pressure monitoring system work?
  1. #1
    dtf
    dtf is offline
    Join Date
    Mar 2006
    Location
    S.E CT
    Posts
    19
    Liked
    0 times
    Rep Power
    0
    Default How does the tire pressure monitoring system work?
    Here's what happened: I went out to check the tire pressures and the little valve stem caps (toyota logo one's ) are so cranked down that I needed a pair of pliers to get one off. I go to do the other one and snap the valve stem right off and the tire goes flat. After putting the spare on I can't get the pressure warning light ot go off. Is it because I now have no tire in the spare tire holder or is it because of the steel rim?
    BTW the dealer was the last one to touch those caps when they did a rotation at 10,000 miles. They must have cranked them down. I'm going to try and get them to pay to pay for it too.
    Thanks,
    dtf
    2006 Tundra SR5 AC 4X4 (12,987 miles)
  2. Remove Advertisements
    Toyota Tundra Forum
    Advertisements
  3. #2
    Join Date
    Apr 2007
    Location
    Kingman, AZ
    Posts
    1,524
    Liked
    20 times
    Rep Power
    1157
    Default Re: How does the tire pressure monitoring system work?
    Your TPMS light is on because of the flat tire. There is no sensor in the spare tire. The valve stem is part of the TPMS sensor in the tire and will be replaced as a unit. The TPMS sensor in the tire is battery operated, and the battery can not be replaced...a new sensor must be installed. Not sure if a dead sensor battery will be covered under warranty. Each TPMS sensor is pretty expensive. The TPMS system needs to be reset per the Owners Manual anytime the air pressure is changed in a tire.
    '07 Tundra SR5, 2WD DC, 5.7L, Salsa Red Pearl with Running Boards, Delta Toolbox.
  4. #3
    dtf
    dtf is offline
    Join Date
    Mar 2006
    Location
    S.E CT
    Posts
    19
    Liked
    0 times
    Rep Power
    0
    Thread Starter
    Excellent explanantion Lee. Thanks - are they expensive? I think I am going to push for the dealer to cover it due to the cranked down valve cap that I couldn't get off. We'll see.
    Thanks,
    dtf
  5. #4
    Join Date
    Apr 2007
    Location
    Ontario, Canada
    Posts
    1,539
    Liked
    0 times
    Rep Power
    48
    There is a sensor in the tire itself? I thought that it was just the special valve stems that made the system work and that you could put any tire on the truck as long as you have the sensor valve stem installed.
  6. #5
    Join Date
    Apr 2007
    Location
    Kingman, AZ
    Posts
    1,524
    Liked
    20 times
    Rep Power
    1157
    I kind of remember seeing on this forum that to replace a sensor cost about $100.00. That seems pretty high to me, but then to replace it means removing the tire from the rim, remounting the tire and then re-balancing the tire...so maybe that price is correct. When you have it replaced, can you give us a report?? Also, try to find out how long the battery is supposed to last and if it is covered under warranty if it fails early.
  7. #6
    Join Date
    Apr 2007
    Location
    Kingman, AZ
    Posts
    1,524
    Liked
    20 times
    Rep Power
    1157
    The sensor/valve stem are one unit. The bottom of the valve stem goes into the sensor. Switching to different wheels might also involve changing sensors because of different angles in the design of the wheels. I got the following from one of the websites: The valve stem cap is made of aluminum and the valve core is nickel-plated to resist corrosion. The end of the stem serves as the sensor’s antenna.
    TIP: Do not replace either the cap or the valve with standard parts. This will interfere with the sensor’s ability to transmit.
    Here are a couple of websites:
    Schrader-Bridgeport Home - Tire Pressure Monitoring Systems (tpms)
    Tire Pressure Monitoring System Information
    SmarTire patents TPMS sensor installation technology
    Tire Pressure Monitor TPMS
  8. #7
    Veteran Member L R H's Avatar
    Join Date
    May 2002
    Location
    GA, USA
    Posts
    1,108
    Liked
    0 times
    Rep Power
    15
    I would not blame dealer for overtightening the caps, but for the WRONG caps. As said above the caps are unique on TPMS's. There have been posts about the Toyota dealer assessory caps and other aftermarket ones seizeing due to non compatible metals. On my Tacoma the TPMS stems I removed had the plastic caps and were grey in color, and as most Toyota's have for 20+ years, the caps have an O ring. Since the caps on your truck do say Toyota, and if they were a dealer sold part then you should have some expectation of some help from the selling dealer since these were made to be sold on pre-TPSM equipped vehicles.
    EDIT: some TPMS's use metal caps, but these are plated, and compatible. If one insists upon chrome/stainless a VERY THIN application of anti-seize may help. A friend of mine has the nickel plated Schrader-Bridgeport (NAPA tire hardware) bright finish caps on his Tundra with just a touch of anti-seize and has had no problems, but we don/t live in snow country where the seized caps seem to happen sooner.
  9. #8
    Veteran Member zpaul's Avatar
    Join Date
    Jun 2007
    Location
    Baltimore, MD
    Posts
    1,449
    Liked
    2 times
    Images
    43
    Rep Power
    718
    Quote Originally Posted by dtf View Post
    Are they expensive?
    Here is the price!
    42607-35010 - TPMS Required for ALUMINUM WHEELS Parts and Accessories
    2011 F150 Eco-boost Lariat
  10. #9
    Join Date
    May 2002
    Location
    GA, USA
    Posts
    1,108
    Liked
    0 times
    Rep Power
    15
    [QUOTE=LeeinAZ;693972]Your TPMS light is on because of the flat tire. There is no sensor in the spare tire. QUOTE]
    Do Tundra's only use sensors in 4 tires? The Tacoma's use them in all 5. I guess they can be done either way as I don't think the sensors are actually required until 08, (correct me if i'm wrong) we are still in the phase in period.
  11. #10
    Join Date
    Apr 2007
    Location
    Kingman, AZ
    Posts
    1,524
    Liked
    20 times
    Rep Power
    1157
    It says in the Owners Manual that there is no sensor in the spare tire. The Toyota TPMS is just a very basic system, as now required by law. Some more sophisticated systems will give the pressure, and some the temperature, in each tire as you are driving down the road. That works better than just a red light on the dash with no indication of which tire has the problem.
  12. #11
    dtf
    dtf is offline
    Join Date
    Mar 2006
    Location
    S.E CT
    Posts
    19
    Liked
    0 times
    Rep Power
    0
    Thread Starter
    LRH - Good call on the metal incompatability issue so I just checked the caps (That I installed, a week after buying the truck, ) and they are not steel - but aluminum - my magnet doesn't have an attraction to them. These caps are on so tight that removing by hand is impossible. I can't believe TPMS are required by law now.
    Thanks,
    dtf
  13. #12
    Join Date
    Jun 2007
    Location
    Redwood City, CA
    Posts
    135
    Liked
    0 times
    Rep Power
    9
    i believe the sensor just goes off if you get a huge decrease in tire pressure. I'm not sure how may PSI would be considered a huge decrease...but there you are.
  14. #13
    Join Date
    May 2002
    Location
    GA, USA
    Posts
    1,108
    Liked
    0 times
    Rep Power
    15
    Quote Originally Posted by LeeinAZ View Post
    There are still some 2007 vehicles without TPMS, the FJ Cruiser's for one don't have them, and there are a few others as well. It is the law of the land now, but I remember seeing a phase in list a while back and for 05 it was X%, and it increased by a certain % every year untill all vehicles will have them. I do believe 2008 is the first 100% year, with all cars, sport utes, and light trucks up to X? GVWR being equipped.
  15. #14
    Join Date
    Apr 2007
    Location
    Kingman, AZ
    Posts
    1,524
    Liked
    20 times
    Rep Power
    1157
    So, if your TPMS quits and you don't repair it, are you going to be cited buy the TPMS cops? TPMS is another intrusion by the Government into the private sector. When I first started driving, cars did not have seat belts. When they first came out it was the driver's choice to wear them or not and there was no law saying you had to have or wear them. Now every State in the Union will issue you a citation, not that they are really interested in your life...just the money they can generate from "Violators". The idea behind TPMS is a good idea....just wait and see how long it will be before it becomes another money generating offense.
  16. #15
    Join Date
    May 2007
    Location
    monmouth,nj
    Posts
    31
    Liked
    0 times
    Rep Power
    9
    When you have to replace your tires do you have to replace the sensors or can they be reused?
Quick Reply Quick Reply
Register Now
Log-in
Human Verification
  1. Replies: 20
    Last Post: 07-20-2008, 07:03 PM
  2. New Lexus RX 350 Adds Power Plus Technical and Convenience Features for 2007
    By TS Support in forum Toyota, Scion & Lexus News
    Last Post: 09-12-2006, 05:57 AM
  3. Tire Pressure Monitoring Valves
    By Himself in forum 1Gen-Tundra
    Last Post: 04-03-2006, 08:40 PM
  4. tire pressure monitoring system
    By mdaigle in forum 1Gen-Tundra
    Last Post: 02-22-2006, 11:04 AM
  5. INFO: Tundra Tire Pressure Warning System
    By nhparrot in forum Knowledgebase Archive
    Last Post: 11-02-2004, 03:13 AM
Posting Permissions
  • You may post new threads
  • You may post replies
  • You may not edit your posts
