Owners manual states 0W20 preferrred as I recall. Better MPG. Since I have prepaid, I won't settle for anything less!
Just so you understand, you will only get better mpg until the oil is warmed up, then it becomes 20w and is the same as far as viscosity and load on the motor/engine.
In our area, I also stick with the 0w20, it never gets real hot here, so the oil stays cooler and it's better on the motor/engine during start up.
I bought 2 cases of the 0W-20 Toyota Synthetic and 3 filters at the time of my truck purchase back in early February. Paid 3.12 a quart or 37.44 a case and 3.70 for each filter. Yes, I have a great dealer!
That's a good deal! Last week I paid $3.85/qt. for 8 quarts of the Toyota 0W-20 and about $5 for the filter element from my local dealer. Not quite the deal you got but I was more than satisfied....then the Parts guy ruined it for me by quoting me $39.95 for the SST (filter wrench)! No I didn't buy it, I was just curious (I already had the $3.99 Pep Boys model at home).
BTW, for any of you who are wondering whether or not you can change your own oil, go for it! It took me about 1 hour. Next time it should take less than 30 minutes now that I know how the TRD skid plate comes off.
2007 Toyota Tundra CrewMax SR5 5.7L w/ TRD Package, Blue Streak Metallic/Graphite, FormulaOne Pinnacle Ceramic Tint (15%), auto-dimming mirror, Line-X Bedliner (under the rail), RS3200 alarm/GBS/hood switch, brushed stainless steel running boards, bed extender, door sill protectors, TRD rear sway bar, TRD CAI, Corsa Touring exhaust.
"Never underestimate how much people are willing to spend on their kids, their pets or their trucks!"
Could you elaborate on the filter wrench from Pep Boys?
Thanks,
Carl
Go to any auto parts store and look for a straight 65mm/14 flute oil filter wrench. Don't buy a 65/67 or any others that are stepped or they will spin when you try to use them. Another suggestion: invest in a 3 gallon plastic pail to drain the oil into....it's much taller than the standard drain pans and sits much closer to the drain port on your oil pan so it will do a better job of keeping the oil from splashing when you drain it. Good luck.
