Old 06-29-2007, 04:07 PM
Dealer : Reno Toyota
Last Online: 12-28-2008 05:14 PM
TahoeTexan is on a distinguished road.
TahoeTexan's Photo Albums
Default Battery keeps dying after amp install
I had a line-out-converter, amp, and speakers installed a few weeks ago. Since then my battery has drained twice over night.
Last night I took out the line-out-converter and installed an Eclipse HU. Today the battery drained again.
I don't know if it is coincidence with the amp install, or if something was wired incorrectly. I checked the wiring and it appears to be correct, power on is wired to ACC from stereo, main power is straight to battery with inline fuse, ground is straight to floor.
Any body else having charging problems? Any suggestions?
Old 06-29-2007, 04:14 PM
2007 Toyota Tundra 5.7L TRD Black
Last Online: 11-23-2009 09:32 AM
blackgts2002 is on a distinguished road.
blackgts2002's Photo Albums
Default Re: Battery keeps dying after amp install
Yea see if the amp is on when the acc is off. Amp might be bad and drawing power internally.
Old 06-29-2007, 04:52 PM
asianflava's Avatar
Dealer : Classic Toyota Scion of Round Rock
2001 Toyota Highlander,
2007 Toyota Tundra CrewMax
Last Online: Today 03:03 AM
asianflava is on a distinguished road.
asianflava's Photo Albums
Did you connect the "Remote" wire to the radio?
Old 06-29-2007, 05:26 PM
hit_em's Avatar
Dealer : Midland Toyota
2002 Toyota Celica GTS (silver bullet),
2007 Toyota Tundra 5.7 TRD Off-road,
2007 Toyota FJ Cruiser
Last Online: 11-08-2008 12:21 PM
hit_em is on a distinguished road.
hit_em's Photo Albums
my thoughts are either bad amp, or you remote wire is connected to the wrong thing and is on all the time. we'll need some info on where it's connected.
Live Fast. Die Young, Leave a Good Looking Corpse.
Old 06-29-2007, 06:17 PM
Dan Marino's Avatar
Dealer : Gatorland Toyota Scion
2005 Toyota Tundra
Last Online: 11-16-2008 08:45 PM
Dan Marino is on a distinguished road.
Dan Marino's Photo Albums
yep, ats what i'd say. if the amp has lights, see if they're on when car is off. also, unscrew remote wire from amp, stick a meter on it, check for power when car is off to see if it is keeping amp on(i say remove wire from amp b/c if amp is bad internally, it might be feeding back into that terminal and tell you that remote wire is giving power when not.) Well, if amp is bad, its obvious what you gotta do.
On the other hand, if you aren't getting any problems there, just to make sure something extraordinary isnt going on, you might want to unhook it and see if it goes dead again. i'm just a simple guy though, thats about all i know to test also
The only auto I care to list is the only one that matters... Toyota. Tundra DC SR5.. Damn it feels good to be a gangsta... lol
Old 06-29-2007, 06:18 PM
The remote amp turn on wire is connected to the ACC wire from the stereo.
Old 06-29-2007, 08:15 PM
hit_em's Avatar
are you positive?? I'm not questioning your knowlege but these are new trucks and not too many people have wire diagrams as of yet. like the last guy says maybe it's a manufacture defect disconnect the amp for the night and see if it's dead in the morning. get a poacket tester and check your voltage tonight then in the morning do the same test and see what it says. best of luck man, that must suck.!!!
Old 06-30-2007, 02:59 AM
ROZ ROZ is offline
Dealer : Crown Toyota Scion
1996 Toyota 4Runner,
2007 Toyota Tundra Slate 2wd DC longbed
Last Online: 01-18-2009 10:55 PM
ROZ is on a distinguished road.
ROZ's Photo Albums
If you used a harness kit there shouldn't be a problem.
Problem... The acc wire from the stereo is suppose to be connected to a wire that is only hot when the key is in the "on" or "accessory" position. If you aren't using a wiring kit, you need to make sure the vehicle wire you're using is hot only in the acc AND on key positions. Check this with the key in both positions.
The yellow wire is 12 constant to maintain presets and clock
The red wire only gets power once the key is in the acc position or when the ignition has been triggered. Is what turns the deck on.
The Blue wire on your deck's harness is to the power antenna, if you have one.
The BLUE/WHITE wire IS THE AMP TURN ON WIRE. The headunit uses this wire to signal your amp to draw power from the car's battery.
Issues:
whoever hooked up your inverter may have hooked it up to a constant hot and the inverter has been left on.
whoever hooked up the amp to your first deck(factory?) chose the wrong wire to trigger the amp turn on.
You didn't check the wrong wiring from the amp install before you installed the Eclipse deck and the acc is a constant hot.
www.hotboat.com
Do you need stock amp for single or 6 CD install? nhparrot Audio & Stereo 1 08-04-2007 09:53 AM
Weird Problems With My Battery Please Help!! Jeremy Electrical & Computer Systems 3 02-18-2006 03:04 PM
Oops...1st heavy rain after amp install... dunwithdodge Audio & Stereo 3 02-10-2004 05:26 PM
Battery isolator install help!! rizico Electrical & Computer Systems 1 02-02-2004 09:48 AM
I need help with an amp install nhparrot Audio & Stereo 0 03-28-2002 01:56 PM
