Closed Thread
LinkBack (58) Thread Tools Display Modes
  #166 (permalink)
Old 07-17-2007, 08:33 PM
Last Online: 07-08-2008 09:24 AM
bigdave is on a distinguished road.
bigdave's Photo Albums
Default Re: 2007 6 speed transmission failures
Did you ever tow anything usmc jarhead?
Death is the number one killer in the U.S. today
  #167 (permalink)
Old 07-18-2007, 10:15 AM
Dealer : Lake Charles Toyota
Last Online: 12-03-2007 03:00 PM
usmc jarhead is on a distinguished road.
usmc jarhead's Photo Albums
Bigdave no I have never towed anything , broke in motor as book says, I guess I am just lucky, I am at the point where I dont know if I want to keep this truck or not, it has been one thing after another, headliner has been replaced because wrong DVD was ordered and hole cut wrong, dealer has been good but I feel my truck has been a g, pig, you know changing tranny in 07 truck requires taking starter , passenger side exaust manifold off , this will be third tranny how is taking all this stuff off and on going to effect it down the road.
  #168 (permalink)
Old 07-18-2007, 10:34 AM
I agree. Tough decision. Let us know how this saga continues.
  #169 (permalink)
Old 07-18-2007, 05:19 PM
Last Online: 02-11-2008 12:52 PM
smithrob26 is on a distinguished road.
smithrob26's Photo Albums
Sorry you are having so many problems with the trans.
I just got out of an RX8 which was a big piece of shiot, that's why I bought the Tundra. Sure hope it doesn't start happening to the 4.7.
Hopefully they find out the problem and correct it.
  #170 (permalink)
Old 07-18-2007, 07:16 PM
I haven't heard any rumblings about the 4.7 set up. You should be gold, no worries.
  #171 (permalink)
Old 07-19-2007, 12:03 PM
Talked to dealer yesterday, they called Gulf States Toyota and said new tranny will be in no later than friday, so I guess it will be next week before installed, also there are rebuilt trannys out Toyota eng. said rebuilt tranny was not suppose to be sent for my truck, makes you wonder bigdave I might have your old tranny, will keep you posted next week.
  #172 (permalink)
Old 07-19-2007, 12:22 PM
Dealer : Putnam Toyota
Last Online: 10-07-2009 09:28 PM
joshp is on a distinguished road.
joshp's Photo Albums
Well if they didn't replace the manifold gasket you'll get an exhaust leak down the road or immediately.
  #173 (permalink)
Old 07-19-2007, 12:25 PM
Originally Posted by bertram928 View Post
If I was Toyota I would insist that a new trans cooler and lines and trans computer be installed with the new 3rd transmission, all under the supervision of a factory rep (there could be a wiring harness issue)
Sounds like a "perfect storm" scenario to me, till all ancillary systems that the trans depends on are ruled out as failure contributers, it makes no sense to install a 3rd trans unless one is a 100% sure of the root cause.
I wonder if just the obvious symptons are only being treated i.e. burned slipping clutch disks leads to the easy conclusion tran is defective.
In just one example among many; it could be the controller that cuts pressure at the shift points (along with engine power) in order smooth out shifts with the abnormally high friction clutches used in this design is shorted and not putting the trans back into the proper clutch pressure profile.
Yeah I'd define those mechanics or that shop as foolish. The transmission isn't the problem. It's the end result.
  #174 (permalink)
Old 07-19-2007, 01:29 PM
Dude, If you get my old tranny, you will know by all the bubblegum on the torque converter I used to hold it together (unless they removed the gum).
  #175 (permalink)
Old 07-20-2007, 10:07 AM
Spoke to Toyota yesterday, they offered to make a payment for me, but no platinum warranty like the guys who went through camshafts. something is better than nothing.
  #176 (permalink)
Old 07-20-2007, 10:56 AM
Yea I am going to address the gasket issue with them next week, seem like the gasket that came off was copper. Tranny is suppose to be in today, probably installed mon. or tuesday I have got a couple other issues I turning in like a bump or slack noise every time I take off or brake and let off brake, bigdave I didnt see any bubble gum so I guess its not your old tranny, you know they are rebuilding trannys I wander at what point of warranty one will be used or they suppose to be holding them for out of warranty, they said mine was sent by mistake I would have never known if it hadnt been defective also makes you wonder if it was planned from begenning or they just got caught.
  #177 (permalink)
Old 07-20-2007, 11:47 AM
You will probably never know if the new tranny is rebuilt or new. But, in the end, I hope they get you back on the road. You should call TMCA and request they make a car payment for you and also see if they will kick down a platinum warranty for all your troubles. They owe you this.
  #178 (permalink)
Old 07-20-2007, 03:08 PM
Went to dealer this morning tranny is in , a big wooden crate from factory not like the plastic guitar case the other tranny came in, also tech ordered new gasket for exaust manifold, will be installed monday. I will make a call to TMAC after everything is done , also tech said greasing drive shaft will keep clunk noise down he will do this also, I will let you know the outcome next week if my tranny problem was solved, I am thinking about a lift similer to yours bigdave will talk after my truck is well.
  #179 (permalink)
Old 07-20-2007, 06:35 PM
Your Tundra should be Gold. A lot of us have 3" lifts which really make the truck stand out. I can't stand the way the nose always sits down on trucks. Hopefully TMCA will take care of you.
  #180 (permalink)
Old 07-21-2007, 03:32 AM
My03Tundra's Avatar
LOVES TO EDIT POSTS!!
- Other - 2007 Honda Ridgeline
Last Online: Yesterday 11:54 PM
My03Tundra is on a distinguished road.
Send a message via AIM to My03Tundra Send a message via Yahoo to My03Tundra My03Tundra's Photo Albums My eBay
Originally Posted by bigdave View Post
Whoa,
take a xanax dude, I am not a Ford hater, my point is, they should have put me in a nice loaner car, not some bare-bone basic Taurus that is really a crappy car to drive, and is hard to get in and out of (I'm 6'3"). A nicely equipped tundra or Camry would have been nice. I have owned chevys and Fords with hardly any complaints. I am not committed to Toyota, especially now that their truck left me hanging. I can't speak for the other toyota owners, but I'm not hater of any brand.
WHY are you being so immature and angry about an inane rental car? As long as it runs and does what you need it to do (have a bed if its a truck) why be upset as to what damn brand it is? I've had rentals for when I had my S-10 in the shop, and when I've had my Ridgeline in the shop. The rentals for the S-10 repairs were Neons while I had a BASE and crappy Saturn Ion for a rental when I had my new Ridgeline in for three days. The S-10 went through valve assemblies at 3000 mile intervals on the spot. The third one they put in was perfectly timed as not too much later afterwards I sold it and got my Tundra.
Honestly, even though I LOVE to bash on the domestics I don't give a flying poop what they put me for a rental in as long as they get me a rental quickly and it can get me back and forth to work and around town.
For me, all I want in a service department is good to excellent customer service and competent repair and body (where applicable) work. What pisses me off more then getting a "non-Toyota" rental is trying to get them to give me a rental or SOMETHING so I don't have to wait while they "fix it." Or, even worse, having to go back for the SAME issue continuously like I had with my S-10's transmission.
Dude, ease up and calm the hell down.
Is something supposed to be here?
Closed Thread
LinkBack to this Thread: http://www.tundrasolutions.com/forums/tundra/103690-2007-6-speed-transmission-failures/
Posted By For Type Date
More bad news for the Toyota Tundra - Straightline This thread Refback 10-08-2009 06:45 AM
Ford F150 crappy ford This thread Refback 07-23-2009 08:46 PM
Toyota Tundra New Owner Reports - CarSpace Automotive Forums This thread Refback 07-19-2009 05:29 PM
Help Me Choose My Pickup! - CarSpace Automotive Forums This thread Refback 05-19-2009 03:37 AM
Chevrolet Ssr Club, Chevrolet Sprint Alternator, Chevrolet Ssr Trouble - Codenamepanzer This thread Refback 03-08-2009 01:03 PM
Help, What Truck Should I Buy!? - Trapperman.com Forums This thread Refback 02-26-2009 07:15 AM
Yahoo! Message Boards - Ford Motor Company (F) - FORD, GM and CHRYSLER need to learn This thread Refback 12-12-2008 08:08 PM
07 Tundra TRANSMISSION FAILURES - Toyota Forums :: Toyota Nation This thread Refback 09-19-2008 06:02 PM
More bad news for the Toyota Tundra | Straightline Blog on Edmunds' Inside Line This thread Refback 08-03-2008 10:00 AM
Straightline - More bad news for the Toyota Tundra This thread Refback 05-13-2008 01:47 PM
PickupTrucks.com Forums: MORE TOYO RECALLS This thread Refback 05-08-2008 02:05 PM
PickupTruck.Com - Toyota Acknowledges Some Tundra Owners Experiencing Transmission Issues This thread Refback 05-06-2008 01:33 PM
Thinking of purchasing a 2008 Tundra, pro/cons anyone? - Page 3 - SVTPerformance This thread Refback 02-15-2008 07:11 PM
Dodge Diesel - Diesel Truck Resource Forums - View Single Post - 6.7 Lemon....PLEASE HELP /going to FORD This thread Refback 01-25-2008 12:30 PM
6.7 Lemon....PLEASE HELP /going to FORD - Page 8 - Dodge Diesel - Diesel Truck Resource Forums This thread Refback 01-24-2008 07:11 AM
6.7 Lemon....PLEASE HELP /going to FORD - Page 8 - Dodge Diesel - Diesel Truck Resource Forums This thread Refback 01-23-2008 05:54 AM
Tundra Problems Snowballing - Blue Oval Forums This thread Refback 01-21-2008 07:47 PM
2007 Toyota Tundra Review - Page 18 - ADVrider This thread Refback 01-18-2008 09:08 PM
Untitled document This thread Refback 01-14-2008 01:11 PM
So much for Toyota Quality???? - Chevy SSR Forum This thread Refback 12-23-2007 11:29 PM
Tundra Problems Snowballing - Blue Oval Forums This thread Refback 12-19-2007 03:48 PM
Tundra Problems Snowballing - Blue Oval Forums This thread Refback 12-14-2007 08:55 PM
Tundra Problems Snowballing - Blue Oval Forums This thread Refback 12-12-2007 02:59 PM
***Official Truck Smack-Talk thread*** - Page 7 - R1-Forum.Com This thread Refback 12-06-2007 07:50 PM
ski-doo snowmobile forums - DOOTalk.com This thread Refback 12-05-2007 03:47 PM
Tundra Problems Snowballing - Blue Oval Forums This thread Refback 12-04-2007 03:39 AM
Tundra Problems Snowballing - Blue Oval Forums This thread Refback 11-28-2007 10:17 PM
Tundra Problems Snowballing - Blue Oval Forums This thread Refback 11-28-2007 09:04 PM
New so called "tough" tundra isnt so tough... - UsCarMeets.com This thread Refback 11-27-2007 01:59 PM
Tundra Problems Snowballing - Blue Oval Forums This thread Refback 11-27-2007 08:37 AM
New so called "tough" tundra isnt so tough... - UsCarMeets.com This thread Refback 11-26-2007 11:42 PM
Tundra Problems Snowballing - Blue Oval Forums This thread Refback 11-26-2007 11:04 PM
New so called "tough" tundra isnt so tough... - TexasRacers This thread Refback 11-26-2007 06:15 PM
Tailgate Troubles On A Toyota Tundra - Where's The Media Coverage Of Import Car Quality Failures? This thread Refback 11-18-2007 10:04 PM
Ford Retired Engineering Executives Club This thread Refback 11-17-2007 10:38 PM
Toyota Tundra bed failures - RPM Warriors Forums - Powered by FusionBB This thread Refback 11-15-2007 03:07 PM
Toyota Tundra bed failures , Where's the media ? - ClassicBroncos.com Forums This thread Refback 11-11-2007 01:35 PM
24hourcampfire: New Tundra ?? This thread Refback 11-09-2007 10:07 PM
Toyota Tundra bed failures , Where's the media ? - ClassicBroncos.com Forums This thread Refback 11-07-2007 04:41 PM
Realoldspower.com :: View topic - Back with more Toyota quality... This thread Refback 11-07-2007 11:29 AM
Toyota's new take on quality - XceedSpeed This thread Refback 11-05-2007 10:21 PM
TOY ota trucks - Disturbed Riders - Stunt Bike Forum This thread Refback 11-01-2007 11:14 AM
So much for Toyota Quality???? - Chevy SSR Fanatic This thread Refback 10-31-2007 07:01 PM
So much for Toyota Quality???? - Chevy SSR Fanatic This thread Refback 10-31-2007 03:21 PM
Ignorant Toyota Ass - Cheers & Gears Forums This thread Refback 10-30-2007 05:00 PM
Realoldspower.com :: View topic - Back with more Toyota quality... This thread Refback 10-28-2007 05:23 PM
Corvette ZR1: Your exotics are no longer safe. - Page 3 - XmodSource.com This thread Refback 10-26-2007 08:20 AM
Corvette ZR1: Your exotics are no longer safe. - Page 3 - XmodSource.com This thread Refback 10-26-2007 01:57 AM
Toyota taken off the best buy list of Consumer reports - Motor City Marauders This thread Refback 10-24-2007 03:22 PM
Realoldspower.com :: View topic - Back with more Toyota quality... This thread Refback 10-23-2007 11:07 PM
Realoldspower.com :: View topic - Back with more Toyota quality... This thread Refback 10-23-2007 07:35 PM
Realoldspower.com :: View topic - Back with more Toyota quality... This thread Refback 10-23-2007 12:31 PM
Realoldspower.com :: View topic - Back with more Toyota quality... This thread Refback 10-23-2007 10:16 AM
The CRX Community :: View topic - Tundra 1/4 mi ET This thread Refback 10-08-2007 02:59 PM
The CRX Community :: View topic - Guess what truck I bought?... UPDATE This thread Refback 09-24-2007 09:47 PM
The CRX Community :: View topic - Guess what truck I bought?... UPDATE This thread Refback 09-20-2007 08:56 PM
Why the fark can't Honda do anything original? - Page 6 - SRTforums.com This thread Refback 09-20-2007 04:40 AM
24hourcampfire: New Tundra ?? This thread Refback 09-04-2007 04:43 PM
Currently Active Users Viewing This Thread: 3 (0 members and 3 guests)
2007 Avalon Transmission issue, engine surges TedT Avalon 10 10-27-2007 09:46 PM
transmission flush nhparrot Engine & Drivetrain 4 08-26-2007 08:46 PM
2007 Toyota FJ Cruiser: The Result of Art, Technology and Heritage TS Support Toyota, Scion & Lexus News 0 09-20-2006 11:19 PM
Toyota Announces 2007 Prices For Nine Vehicles in Model Lineup TS Support Toyota, Scion & Lexus News 0 08-08-2006 12:36 PM
2007 Toyota Camry Pricing TundraSoul Camry 1 03-01-2006 08:11 PM
