Closed Thread
LinkBack (58) Thread Tools Display Modes
  1 links from elsewhere to this Post. Click to view. #316 (permalink)
Old 09-27-2007, 08:44 PM
Dealer : Rice Toyota
2001 Toyota Tundra,
2007 Toyota Tundra Silver Sky DC w/XSP
Last Online: 10-18-2009 01:07 AM
reidsworks is on a distinguished road.
reidsworks's Photo Albums
Default Re: 2007 6 speed transmission failures
Rumble strip effect feels like driving off the edge of the highway onto the wake up strips ground into the pavement. My first event lasted for about 5-7 secs. Scared the hell out of me. Thought I ran over something in the road.
Dependent on road incline, rate of acceleration, and speed determines how long it lasts. I have gotten pretty good and duplicating conditions pretty much at will. Now I am getting a new ka-chunk and thud when the tranny upshifts from 5th to 6th gear.
Hoping the dealer gives me some quick relief tomorrow morning. Just turned 700 miles. It is very irratating.
  #317 (permalink)
Old 09-27-2007, 10:31 PM
Last Online: 07-08-2008 09:24 AM
bigdave is on a distinguished road.
bigdave's Photo Albums
Ditto that feeling.
Death is the number one killer in the U.S. today
  #318 (permalink)
Old 09-27-2007, 11:09 PM
Dealer : Torrance Toyota
- Other -
Last Online: 02-03-2010 02:27 AM
enchantor is on a distinguished road.
enchantor's Photo Albums
Mine was worst around 700 miles too, but now that I'm around 1100 I haven't felt it in a week. Hopefully some of you will have the same results. Although, I'm still unsure if the problem is gone or not. Time shall tell.
SGT, USMC (Ret.)
07 Tundra DC 5.7 4x4 Slate Gray
  #319 (permalink)
Old 09-28-2007, 12:25 AM
Dealer : Midwest Toyota
2007 Toyota Tundra,
- Other - 2007 Honda Odyssey
Last Online: 03-11-2009 12:23 PM
impilot is on a distinguished road.
impilot's Photo Albums
I am not at 2400 miles, and it seems to be happening less and less.....
I am in wait and see mode for now.
2007 5.7L Tundra CrewMax Ltd 4x4 in Radiant Red
  #320 (permalink)
Old 09-28-2007, 05:57 PM
2001 Toyota Tundra,
Ok Gentlemen and woman, I took mine in today and did a test ride with the Service Manager. He had me drive to demonstrate. I have to say it is getting harder to duplicate as the miles pass by but I was able to get the rumble to occur while driving. The service manager immediately noticed and said " that is not good, we need to fix that right away" Through another 30 min. conversation he suggested the Torque converter was likely the problem and explained that Toyota was not going to let this slip by with a rebuilt anything. However, he wanted me to take the truck home and continue driving while he researched Toyota contacts to see what to do about my trouble.
A short hour later Service Manager (SM) calls and says Regional Tech rep instructed him to drive the truck himself and see if he could duplicate rumble. If he is successful, then they need to disconnect or short across(not sure which) the brake light switch and redo the test drive again. Dependent on results of these tests, will determine next step of the process.
My first thought was, I am sure glad the dealer is cooperating and not giving me a run around. Second thought is what does the brake light switch have to do with the transmission? Anyway, it was a good experience today and I look forward to next Tuesday. They are even giving me a loaner car for the day too. I wasn't dealing with shuttle service for the whole day.
Now we wait.
In the mean time, I drove home 23 miles this afternoon and could not get the rumble to occur until just before pulling in my drive. Shame is it occured at a completely different speed and rpm. I am believing more and more it is the Torque Converter too. Feels like the clutch discs slipping even if just for a moment under load.
Finally, I must say I still love my truck and am going ahead with orders for Chromed Billet Grill(stainless) $179 and Chromed front door handle covers $38 off ebay.
  #321 (permalink)
Old 09-29-2007, 07:27 AM
Dealer : Newark Toyotaworld
Last Online: 06-26-2008 09:22 PM
MarylandTundra is on a distinguished road.
MarylandTundra's Photo Albums
The brake light switch is tied into the torque converter clutch inside the torque converter. The clutch activates after you get into the higher gears and allows the engine to be coupled to the transmission like a normal clutch would in a truck with a standard transmission. This takes the stator and the converter action out of the picture to reduce power loss through the fluid in the converter. The clutch is used to give better fuel mileage.
Remember what would happen if you tried to stop a truck with a manual transmission and not push in the clutch? The engine would eventually stall.
This would also happen on a vehicle with a torque converter/converter clutch.
The brake light switch sends a signal to the power train ECU letting it know that your are trying to stop and in turn will disengage the torque converter clutch.
By jumping it he is taking it out of the troubleshooting equation.
Hope that helps.
  #322 (permalink)
Old 09-29-2007, 08:31 AM
xerces's Avatar
Dealer : Autoway Toyota
Last Online: 04-25-2008 08:10 PM
xerces is on a distinguished road.
xerces's Photo Albums
Hope that helps.
Yes, that definitely clears it up. I just learned a few new things about the drive train I didn't know. Thanks!
2007 Salsa Red Tundra DC 5.7L SR5 w/TRD package
2005 Suzuki GSX-R1000
2006 Kawasaki KX450F
  #323 (permalink)
Old 09-29-2007, 11:20 AM
2001 Toyota Tundra,
Wow.... Thanks for the explaination. Makes good sense. It would seem odd to me then that the switch would be causing the problem I am having.
The trouble does only occur under heavy load 1250 rpm and 32-38 mph. I have marked shift points and am sure the transmission rumble is occuring between 5th and 6th gear. So now I understand the tie in with the brake switch.
  #324 (permalink)
Old 10-02-2007, 10:50 AM
2001 Toyota Tundra,
I posted an update on another thread but didn't see some of you there so here is another copy.
Took my truck back for second round of troubleshooting this morning. The service manager called me just an hour later to say the tranny had to be replaced. Toyota is all over this rumble problem. Apparently has to do with a lock up problem associated with the torque converter. Both are being replaced bran new, not remanf. Area rep says they don't have any remanf. units to send. Yeh... for me. My service manager has been great and forthcoming with all kinds of info. Really getting treated right except they put me in a Corrola rental. I can live with that knowing I didn't get the run around on the tranny trouble.
Also, found out that the clunk some folks are feeling on start and stop has to do with the slip yoke on the drive shaft. Toyota is aware of this too and have issued fix to dealers nationwide. No need to swap out differentials or drive shafts. The problem has to do with either too much or too little grease in the slip yoke. I had the problem when I drove off the lot but it resolved on its own over the first couple hundred miles.
That said, I have renewed confidence in Dealer Service and Toyota's quality product support. Gotta love Toyota!!!!
  #325 (permalink)
Old 10-02-2007, 12:28 PM
Last Online: 02-06-2010 09:42 PM
Images: 1
cliff clavin will become famous soon enough.
cliff clavin's Photo Albums
if what you say is true (and I have no reason to think otherwise) then many posters and tundra owners will be thrilled to hear that one widespread problem with the tundra is being resolved.....
  #326 (permalink)
Old 10-04-2007, 10:33 PM
2001 Toyota Tundra,
Well we are two for two.... Just got pm'd by another Tunra owner.... His dealer has him in the same spot as me. New tranny on order for rumble problem(torque converter) and clunk(slip yoke on driveshaft).
Gotta give the credit to Toyota for figuring out the problems and fixing it right without question.
  #327 (permalink)
Old 10-04-2007, 11:20 PM
Images: 1
The bigger question is are the new tundras rolling off the line fixed or are they susceptible to these two problems?
  #328 (permalink)
Old 10-07-2007, 01:51 PM
Dealer : Norm Wagner Toyota
Last Online: 10-04-2009 10:22 AM
rydog31 is on a distinguished road.
rydog31's Photo Albums
I have 1000 miles on my 2007 Tundra (5.7L TRD) and this is my second transmission that vibrates when it down shifts. A week ago the dealer replaced the torque converter and tranny. After a week of driving it started to vibrate again. It doesn't do it often but the bottom line is that it does it! The dealer is getting it back on Monday morning. Any suggestions? This is my third Tundra and the first with issues.
  #329 (permalink)
Old 10-07-2007, 02:57 PM
2007 Toyota Tundra,
I have the same issue...I was offered a new tranny/torque converter. The regional technical rep told me it might fix the problem, might not....that the drive train engineering team is working on the problem, but does not yet have a fix. Some trannys have it, some don't.
I am waiting for a permanent fix. I really don't it replaced on a "maybe it will fix it". I can live with for a while and give Toyota time to come up with a real fix.
  #330 (permalink)
Old 10-07-2007, 07:04 PM
2001 Toyota Tundra,
Sorry to hear of yet another tranny issue. Vibration when down shifting is something new on this thread?
Mine was a rumble when accelerating 32-38mph/1200-1300 rpm usually under load such as slight incline. Easily duplicated under the same conditions. I don't have my truck back from dealer with new tranny yet. Hoping to get it back tomorrow. Service manager called Friday to say the tranny has been replaced but he didn't have time to do quality control test drive. I expect to hear from him early Monday morning.
I am convinced the rumble problems stem from a bad batch of torque converters and I feel comfortable with dealer explaination on drive line clunk. Especially since we now have two dealers with the same area representation making same assessment. We will see. I will post when I get mine back working as it should.
Closed Thread
LinkBack to this Thread: http://www.tundrasolutions.com/forums/tundra/103690-2007-6-speed-transmission-failures/
Posted By For Type Date
More bad news for the Toyota Tundra - Straightline This thread Refback 10-08-2009 06:45 AM
Ford F150 crappy ford This thread Refback 07-23-2009 08:46 PM
Toyota Tundra New Owner Reports - CarSpace Automotive Forums This thread Refback 07-19-2009 05:29 PM
Help Me Choose My Pickup! - CarSpace Automotive Forums This thread Refback 05-19-2009 03:37 AM
Chevrolet Ssr Club, Chevrolet Sprint Alternator, Chevrolet Ssr Trouble - Codenamepanzer This thread Refback 03-08-2009 01:03 PM
Help, What Truck Should I Buy!? - Trapperman.com Forums This thread Refback 02-26-2009 07:15 AM
Yahoo! Message Boards - Ford Motor Company (F) - FORD, GM and CHRYSLER need to learn This thread Refback 12-12-2008 08:08 PM
07 Tundra TRANSMISSION FAILURES - Toyota Forums :: Toyota Nation This thread Refback 09-19-2008 06:02 PM
More bad news for the Toyota Tundra | Straightline Blog on Edmunds' Inside Line This thread Refback 08-03-2008 10:00 AM
Straightline - More bad news for the Toyota Tundra This thread Refback 05-13-2008 01:47 PM
PickupTrucks.com Forums: MORE TOYO RECALLS This thread Refback 05-08-2008 02:05 PM
PickupTruck.Com - Toyota Acknowledges Some Tundra Owners Experiencing Transmission Issues This thread Refback 05-06-2008 01:33 PM
Thinking of purchasing a 2008 Tundra, pro/cons anyone? - Page 3 - SVTPerformance This thread Refback 02-15-2008 07:11 PM
Dodge Diesel - Diesel Truck Resource Forums - View Single Post - 6.7 Lemon....PLEASE HELP /going to FORD This thread Refback 01-25-2008 12:30 PM
6.7 Lemon....PLEASE HELP /going to FORD - Page 8 - Dodge Diesel - Diesel Truck Resource Forums This thread Refback 01-24-2008 07:11 AM
6.7 Lemon....PLEASE HELP /going to FORD - Page 8 - Dodge Diesel - Diesel Truck Resource Forums This thread Refback 01-23-2008 05:54 AM
Tundra Problems Snowballing - Blue Oval Forums This thread Refback 01-21-2008 07:47 PM
2007 Toyota Tundra Review - Page 18 - ADVrider This thread Refback 01-18-2008 09:08 PM
Untitled document This thread Refback 01-14-2008 01:11 PM
So much for Toyota Quality???? - Chevy SSR Forum This thread Refback 12-23-2007 11:29 PM
Tundra Problems Snowballing - Blue Oval Forums This thread Refback 12-19-2007 03:48 PM
Tundra Problems Snowballing - Blue Oval Forums This thread Refback 12-14-2007 08:55 PM
Tundra Problems Snowballing - Blue Oval Forums This thread Refback 12-12-2007 02:59 PM
***Official Truck Smack-Talk thread*** - Page 7 - R1-Forum.Com This thread Refback 12-06-2007 07:50 PM
ski-doo snowmobile forums - DOOTalk.com This thread Refback 12-05-2007 03:47 PM
Tundra Problems Snowballing - Blue Oval Forums This thread Refback 12-04-2007 03:39 AM
Tundra Problems Snowballing - Blue Oval Forums This thread Refback 11-28-2007 10:17 PM
Tundra Problems Snowballing - Blue Oval Forums This thread Refback 11-28-2007 09:04 PM
New so called "tough" tundra isnt so tough... - UsCarMeets.com This thread Refback 11-27-2007 01:59 PM
Tundra Problems Snowballing - Blue Oval Forums This thread Refback 11-27-2007 08:37 AM
New so called "tough" tundra isnt so tough... - UsCarMeets.com This thread Refback 11-26-2007 11:42 PM
Tundra Problems Snowballing - Blue Oval Forums This thread Refback 11-26-2007 11:04 PM
New so called "tough" tundra isnt so tough... - TexasRacers This thread Refback 11-26-2007 06:15 PM
Tailgate Troubles On A Toyota Tundra - Where's The Media Coverage Of Import Car Quality Failures? This thread Refback 11-18-2007 10:04 PM
Ford Retired Engineering Executives Club This thread Refback 11-17-2007 10:38 PM
Toyota Tundra bed failures - RPM Warriors Forums - Powered by FusionBB This thread Refback 11-15-2007 03:07 PM
Toyota Tundra bed failures , Where's the media ? - ClassicBroncos.com Forums This thread Refback 11-11-2007 01:35 PM
24hourcampfire: New Tundra ?? This thread Refback 11-09-2007 10:07 PM
Toyota Tundra bed failures , Where's the media ? - ClassicBroncos.com Forums This thread Refback 11-07-2007 04:41 PM
Realoldspower.com :: View topic - Back with more Toyota quality... This thread Refback 11-07-2007 11:29 AM
Toyota's new take on quality - XceedSpeed This thread Refback 11-05-2007 10:21 PM
TOY ota trucks - Disturbed Riders - Stunt Bike Forum This thread Refback 11-01-2007 11:14 AM
So much for Toyota Quality???? - Chevy SSR Fanatic This thread Refback 10-31-2007 07:01 PM
So much for Toyota Quality???? - Chevy SSR Fanatic This thread Refback 10-31-2007 03:21 PM
Ignorant Toyota Ass - Cheers & Gears Forums This thread Refback 10-30-2007 05:00 PM
Realoldspower.com :: View topic - Back with more Toyota quality... This thread Refback 10-28-2007 05:23 PM
Corvette ZR1: Your exotics are no longer safe. - Page 3 - XmodSource.com This thread Refback 10-26-2007 08:20 AM
Corvette ZR1: Your exotics are no longer safe. - Page 3 - XmodSource.com This thread Refback 10-26-2007 01:57 AM
Toyota taken off the best buy list of Consumer reports - Motor City Marauders This thread Refback 10-24-2007 03:22 PM
Realoldspower.com :: View topic - Back with more Toyota quality... This thread Refback 10-23-2007 11:07 PM
Realoldspower.com :: View topic - Back with more Toyota quality... This thread Refback 10-23-2007 07:35 PM
Realoldspower.com :: View topic - Back with more Toyota quality... This thread Refback 10-23-2007 12:31 PM
Realoldspower.com :: View topic - Back with more Toyota quality... This thread Refback 10-23-2007 10:16 AM
The CRX Community :: View topic - Tundra 1/4 mi ET This thread Refback 10-08-2007 02:59 PM
The CRX Community :: View topic - Guess what truck I bought?... UPDATE This thread Refback 09-24-2007 09:47 PM
The CRX Community :: View topic - Guess what truck I bought?... UPDATE This thread Refback 09-20-2007 08:56 PM
Why the fark can't Honda do anything original? - Page 6 - SRTforums.com This thread Refback 09-20-2007 04:40 AM
24hourcampfire: New Tundra ?? This thread Refback 09-04-2007 04:43 PM
2007 Avalon Transmission issue, engine surges TedT Avalon 10 10-27-2007 09:46 PM
transmission flush nhparrot Engine & Drivetrain 4 08-26-2007 08:46 PM
2007 Toyota FJ Cruiser: The Result of Art, Technology and Heritage TS Support Toyota, Scion & Lexus News 0 09-20-2006 11:19 PM
Toyota Announces 2007 Prices For Nine Vehicles in Model Lineup TS Support Toyota, Scion & Lexus News 0 08-08-2006 12:36 PM
2007 Toyota Camry Pricing TundraSoul Camry 1 03-01-2006 08:11 PM
