Closed Thread
LinkBack (58) Thread Tools Display Modes
  #361 (permalink)
Old 10-10-2007, 08:52 PM
Last Online: 07-08-2008 09:24 AM
bigdave is on a distinguished road.
bigdave's Photo Albums
Default Re: 2007 6 speed transmission failures
Just to play Devil's advocate, why would Toyota keep replacing tranny's instead of just replacing tq converters or ECM programming? I was surprised to find my entire tranny needed to be replaced for something that seemed like a programming issue. I don't know, just my two cents. Maybe it's just taking a while for Toyota to figure it out, and in the mean time, they are replacing the entire tranny for lack of better understanding at this point. Failure or not, I am fortunate that I was still able to drive it to the dealer (stuck in 4th as the final gear). Just some first year growing pains.
Death is the number one killer in the U.S. today
  #362 (permalink)
Old 10-10-2007, 08:56 PM
Banned
Dealer : Peterson Toyota
Last Online: 01-04-2008 10:20 PM
excaliber is on a distinguished road.
excaliber's Photo Albums
I'm not understanding the need to shift these auto transmissions at all. Aren't they like an overdrive where you put in D with the OD on and just drive it?
Can someone explain this?
  #363 (permalink)
Old 10-10-2007, 08:59 PM
guntech's Avatar
Benny Hill
Dealer : Prestiqe Toyota
2003 Toyota Camry,
Images: 71
guntech has done just about everything. guntech has done just about everything. guntech has done just about everything. guntech has done just about everything. guntech has done just about everything. guntech has done just about everything. guntech has done just about everything. guntech has done just about everything. guntech has done just about everything. guntech has done just about everything. guntech has done just about everything.
guntech's Photo Albums
I heard that they "replace" instead of "repair", so that TOYOTA, not some dealership, has the tranny in tact and can take time going thru it to not only find out WHAT failed (or misbehaved), but WHY it did it.
I think if the service departments were just swapping parts to make the symptom go away, they would never get to the bottom of it.
I also think that the number of Tundras that are having these problems are no greater than the number of other Makes.
  #364 (permalink)
Old 10-10-2007, 09:02 PM
Dealer : Midwest Toyota
2007 Toyota Tundra,
- Other - 2007 Honda Odyssey
Last Online: 03-11-2009 12:23 PM
impilot is on a distinguished road.
impilot's Photo Albums
I believe it is to try to make it right for their customers...even though they know that the new tranny may be affected too. My regional tech rep as much as said that....he said he would be happy to replace the tranny/torque converter..but, the new one might have the same issue. He said they are working on a permanent fix....
You may well have had some other issue...especially since it got stuck in 4th. It seems to me that MOST, not ALL, of the problems talked about seem to be of the same variety...a rumble at when shifting, especially into/out of overdrive, often when lugging the engine.
All I know is this....based on my previous experience with other manufacturers (who shall remain nameless to protect the guilty), if I had brought either of my two previous vehicles into the dealer with the same issue and with the same severity, I am extremely confident I would have been patted on the head, told it is "Normal", and would have gotten no satisfaction.
I did not take Toyota up on the offer of the replacement, simply because I wanted to give them a chance to come up with a real fix, and mine was not mis-behaving too badly. A few weeks and a couple of thousand miles later, and I can't make it rumble, no matter how hard I try. Say what you will...but I am impressed that they would even offer to replace these big ticket parts....especially without me having to have a major temper tantrum and raise holy hell!
2007 5.7L Tundra CrewMax Ltd 4x4 in Radiant Red
  #365 (permalink)
Old 10-10-2007, 09:36 PM
AlaskaCub's Avatar
Dealer : Auto Service Company
2005 Toyota 4Runner SR5 4x4,
2007 Toyota Tundra TRD 5.7L DC SR5 4x4
Last Online: 11-06-2009 11:12 PM
AlaskaCub is on a distinguished road.
AlaskaCub's Photo Albums
They know that rippping and stripping major components on a brand new vehicle is gonna result in more problems. Same goes for the motor, usually if its really new they longblock it, reduces the chances for you to have continuing problems from the work that was done. My guess is that the trans rumble thing will be fixed whether its electronic or a new valve body or torque converter or whatever they'll figure it out, you got to remember these little glitches didn't surface right away and not all Tundras have these glitches so it takes a while to compile a complaint base before they initiate a team to figure out whats going on. Lots of scattered isolated incidents take time to create a trend, but they'll get it right, that I assure you. I would guess the culprit will likely be one or 2 links in the chain from a given parts supplier that will be the culprit, or they (all Tundras) would all do it if it was a design flaw.
07 Tundra DC TRD 4WD 5.7L Desert Mica
Oh and I dont use spell check!
  #366 (permalink)
Old 10-10-2007, 11:11 PM
I don't have any experience with major mechanical malfunctions with other trucks/cars (oops, I did have a F-150 go through a computer module years ago), but I think it's great Toyota has been replacing the entire tranny. It just kinda sucks for them cost wise, but that is a good sign that Toyota really does try to provide great service. I think some of their dealerships need better training and in some cases, offer better customer service at the local level. (I am referring to a small minority of dealerships, full-well acknowledging the very large majority of Toyo dealers are probably great)
  #367 (permalink)
Old 10-10-2007, 11:48 PM
slimjim2525's Avatar
Dealer : Gale Toyota Scion
2006 Toyota Camry SE Silver,
- Other -
Last Online: 05-22-2009 01:13 PM
slimjim2525 is on a distinguished road.
slimjim2525's Photo Albums
Originally Posted by AlaskaCub View Post
You are spot on and some folks cant seem to understand that. Call 10 Ford dealerships and ask them how many trannys have failed ( I am not talking about rumble strip crap I am talking FAILED, as in towed in not driveable) this year in 07 F-150's.....I bet more than Tundras have. And you can do the same with Dodge, Chevy and GMC. These Tundra concerns in question are small problems affecting a minute number of folks in comparison to the masses and like you said , some are exhibiting a problem that is probably gonna be fixed with a ECM/PCM flash program. Lets get it right theres failure and then theres the need to adjust something. I just find it so funny how fast folks want to jump on the Toyota FAILED bandwagon when its not the case at all. Like I said yesterday I was at my local Toyota Dealership talking to TOYOTA Techs (friends of mine) and the only things they have been working on is the A/C vent, a couple tailgate linkage clips and for the most part the rest is just maintenance (oil changes and such), the facts are skewed on this forum with those searching for help that are internet saavy. Some polls would be very interesting to show how small the numbers are. When was the last time you heard about a camshaft failure??? Or a Tundra actually being towed in for a tranny problem??? Not many out there fellas, look at the big pic for the hottest selling truck on the road right now.(At least in my town!)
Everything you just stated is complete BS. I defy you to call 10 GM dealers right now and ask them how many tranny failures they have had. The fact is the 4l60e is the most reliabletranny ever made in a 1/2 ton truck. I agree that they are not truely tranny failures, but then why would toyota treat them as such, instead of just reflash the pcm as you suggest. Oh, i get it, because toyota goes above and beyond the call of duty. And then to replace some peoples twice or more, OK. And man you have friends everywhere that you talk to. The hottest selling truck out there, you better look again.
  #368 (permalink)
Old 10-11-2007, 12:13 AM
DakineTX's Avatar
Last Online: 11-26-2007 02:02 AM
DakineTX is on a distinguished road.
DakineTX's Photo Albums
Originally Posted by slimjim2525 View Post
Yor're smart to wait. And these ney sayers here that it's a very small problem are wrong. I bet that only 2-3% of tundra owners visit this site, and look how many problems are here. And all your problems were with pre-1991 fords. Just so you know, domestic quality has increased 100 fold in the last ten years, were foreign quality has decreased.
CRAP!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!! !!!!!!!!!!!!!!!!
The phrase Qaulity Control is akin to a swear word to the big 3! They care not but to shift units. They will keep your vehicle forever to 'tinker' with it and try and find a fault before they even call corporate. I had Fords from 1999 on inc. a 100th Anniversary Harley Supercrew which quality wise was a JOKE. Ya would think they might pay attention to such a model huh?
2007 CM Ltd. Nav/Roof,loaded (Nautical Blue)
2007 DC TRD JBL/Camera, TRD Dual Exhaust/TRD CAI (Super White)
  #369 (permalink)
Old 10-11-2007, 12:28 AM
Dealer : Capitol Toyota
2007 Toyota Tacoma
Last Online: 08-12-2008 05:48 PM
bwalky is on a distinguished road.
bwalky's Photo Albums
I have a somewhat unique perspective to lend to the discussion. I purchased a 5.7L Tundra in July and put on about 7,500 miles before tragedy struck. My truck was stolen out of my driveway while loaded with two motorcycles. This is a long story to be told on another thread. Anyway, I towed our 6,000 lb travel trailer home 120 miles the same day I purchased it against the formal "breakin" recommendations. Needless to say, that truck ran without a glitch, no transmission issues, and still would run and drive even after a major police chase across ditches and cane berry fields. That truck was totaled as a result.
I just purchased a new replacement Tundra with the 5.7L 6-speed tranny. On my way home from work today, with 200 miles on the odometer, I felt like I ran over a rumble strip on the side of the road while lightly accelerating up a small hill between 25 and 35 mph. I noticed it again as I was trying to merge into the freeway and proceeded to try and duplicate the issue. It will not shudder/vibrate under moderate to heavy acceleration, but will in 4th gear at the previously mentioned speeds. I seemed with the driveshaft was vibrating or maybe a U-Joint had gone bad.
I called the dealer in Bend, Oregon where I bought the truck and they are unaware of the issue. I have since found, through reading this thread, that this is a known issue likely associated with the torque converter. I tend to have the same feeling as impilot that I would rather wait for Toyota to figure out the exact cause of the problem instead of replacing my whole transmission. I don't entirely trust the competency of the dealer techs. Hopefully a TSB will be released with a repair scheme. Please keep us updated on the fix. I love the truck and want it right!
  #370 (permalink)
Old 10-11-2007, 12:32 AM
DakineTX's Avatar
Sorry to hear about that theft, that sucks!!!!!!!!!
Were the bikes ok at least?
  #371 (permalink)
Old 10-11-2007, 12:35 AM
2007 Toyota Tacoma
Bikes were not recovered and are not covered. At least the bastard that stole the truck got up close and personal with K-9 unit.
  #372 (permalink)
Old 10-11-2007, 12:44 AM
AlaskaCub's Avatar
Dude your BS is so old I almost care not to even respond to you. Get a life and go hang out on a GM forum as its clear thats what you own and love and they are soooo trouble free! I am not even going to get into my opinion of the quality of GM's, Fords, or Dodges again, it will take this thread way off course which is what you desire and seek in almost every thread you turn into combat with a Tundra owner. GET A LIFE!!!!!!!! I'd be willing to bet my paycheck that my local GM dealer has had more 2007 1/2 ton's towed in than Toyota has had 07 Tundras....Seriously....MY PAYCHECK vs yours!
  #373 (permalink)
slackjaw07's Avatar
Last Online: Yesterday 01:09 PM
slackjaw07 will become famous soon enough. slackjaw07 will become famous soon enough.
slackjaw07's Photo Albums
I'm with you on the CRAP call, but then many of us have come to expect this unsubstantiated and highly biased garbage from him. A propagandist through and through...probably has a cult following on the GM forum. I don't pay much attention to his rants since he doesn't own an '07 Tundra or have any first hand knowledge of it as near as I can tell. I will compliment him on his ability to cherry pick and spin information off this forum to try to make his points. To be honest, I think he's made it his mission in life to defend the brand and justify his own choice in trucks (I think an '07 Silverado...nice truck but the vast majority on this forum could care less!).
I'm pretty sure the "ignore him and hope he goes away" approach won't work but it's worth a try.
2007 Toyota Tundra CrewMax SR5 5.7L w/ TRD Package, Blue Streak Metallic/Graphite, FormulaOne Pinnacle Ceramic Tint (15%), auto-dimming mirror, Line-X Bedliner (under the rail), RS3200 alarm/GBS/hood switch, brushed stainless steel running boards, bed extender, door sill protectors, TRD rear sway bar, TRD CAI, Corsa Touring exhaust.
"Never underestimate how much people are willing to spend on their kids, their pets or their trucks!"
  #374 (permalink)
Old 10-11-2007, 12:58 AM
DakineTX's Avatar
Sorry bud.
BUT if the K-9 unit was anything like ours then he got a def. rude awakening
  #375 (permalink)
Old 10-11-2007, 07:47 AM
Dealer : Rice Toyota
2001 Toyota Tundra,
2007 Toyota Tundra Silver Sky DC w/XSP
Last Online: 10-18-2009 01:07 AM
reidsworks is on a distinguished road.
reidsworks's Photo Albums
Gun tech,
My service manager here tells me they replace the whole thing instead of trying to fix the tranny because of the lack of facilities and skilled technicians qualified to do tranny rebuilds. It would cost dealerships(Toyota) more to have the clean facilities and trained technicians for tranny disassembly and repair. Much more cost effective to tear it out and put in a new one.
Closed Thread
LinkBack to this Thread: http://www.tundrasolutions.com/forums/tundra/103690-2007-6-speed-transmission-failures/
Posted By For Type Date
More bad news for the Toyota Tundra - Straightline This thread Refback 10-08-2009 06:45 AM
Ford F150 crappy ford This thread Refback 07-23-2009 08:46 PM
Toyota Tundra New Owner Reports - CarSpace Automotive Forums This thread Refback 07-19-2009 05:29 PM
Help Me Choose My Pickup! - CarSpace Automotive Forums This thread Refback 05-19-2009 03:37 AM
Chevrolet Ssr Club, Chevrolet Sprint Alternator, Chevrolet Ssr Trouble - Codenamepanzer This thread Refback 03-08-2009 01:03 PM
Help, What Truck Should I Buy!? - Trapperman.com Forums This thread Refback 02-26-2009 07:15 AM
Yahoo! Message Boards - Ford Motor Company (F) - FORD, GM and CHRYSLER need to learn This thread Refback 12-12-2008 08:08 PM
07 Tundra TRANSMISSION FAILURES - Toyota Forums :: Toyota Nation This thread Refback 09-19-2008 06:02 PM
More bad news for the Toyota Tundra | Straightline Blog on Edmunds' Inside Line This thread Refback 08-03-2008 10:00 AM
Straightline - More bad news for the Toyota Tundra This thread Refback 05-13-2008 01:47 PM
PickupTrucks.com Forums: MORE TOYO RECALLS This thread Refback 05-08-2008 02:05 PM
PickupTruck.Com - Toyota Acknowledges Some Tundra Owners Experiencing Transmission Issues This thread Refback 05-06-2008 01:33 PM
Thinking of purchasing a 2008 Tundra, pro/cons anyone? - Page 3 - SVTPerformance This thread Refback 02-15-2008 07:11 PM
Dodge Diesel - Diesel Truck Resource Forums - View Single Post - 6.7 Lemon....PLEASE HELP /going to FORD This thread Refback 01-25-2008 12:30 PM
6.7 Lemon....PLEASE HELP /going to FORD - Page 8 - Dodge Diesel - Diesel Truck Resource Forums This thread Refback 01-24-2008 07:11 AM
6.7 Lemon....PLEASE HELP /going to FORD - Page 8 - Dodge Diesel - Diesel Truck Resource Forums This thread Refback 01-23-2008 05:54 AM
Tundra Problems Snowballing - Blue Oval Forums This thread Refback 01-21-2008 07:47 PM
2007 Toyota Tundra Review - Page 18 - ADVrider This thread Refback 01-18-2008 09:08 PM
Untitled document This thread Refback 01-14-2008 01:11 PM
So much for Toyota Quality???? - Chevy SSR Forum This thread Refback 12-23-2007 11:29 PM
Tundra Problems Snowballing - Blue Oval Forums This thread Refback 12-19-2007 03:48 PM
Tundra Problems Snowballing - Blue Oval Forums This thread Refback 12-14-2007 08:55 PM
Tundra Problems Snowballing - Blue Oval Forums This thread Refback 12-12-2007 02:59 PM
***Official Truck Smack-Talk thread*** - Page 7 - R1-Forum.Com This thread Refback 12-06-2007 07:50 PM
ski-doo snowmobile forums - DOOTalk.com This thread Refback 12-05-2007 03:47 PM
Tundra Problems Snowballing - Blue Oval Forums This thread Refback 12-04-2007 03:39 AM
Tundra Problems Snowballing - Blue Oval Forums This thread Refback 11-28-2007 10:17 PM
Tundra Problems Snowballing - Blue Oval Forums This thread Refback 11-28-2007 09:04 PM
New so called "tough" tundra isnt so tough... - UsCarMeets.com This thread Refback 11-27-2007 01:59 PM
Tundra Problems Snowballing - Blue Oval Forums This thread Refback 11-27-2007 08:37 AM
New so called "tough" tundra isnt so tough... - UsCarMeets.com This thread Refback 11-26-2007 11:42 PM
Tundra Problems Snowballing - Blue Oval Forums This thread Refback 11-26-2007 11:04 PM
New so called "tough" tundra isnt so tough... - TexasRacers This thread Refback 11-26-2007 06:15 PM
Tailgate Troubles On A Toyota Tundra - Where's The Media Coverage Of Import Car Quality Failures? This thread Refback 11-18-2007 10:04 PM
Ford Retired Engineering Executives Club This thread Refback 11-17-2007 10:38 PM
Toyota Tundra bed failures - RPM Warriors Forums - Powered by FusionBB This thread Refback 11-15-2007 03:07 PM
Toyota Tundra bed failures , Where's the media ? - ClassicBroncos.com Forums This thread Refback 11-11-2007 01:35 PM
24hourcampfire: New Tundra ?? This thread Refback 11-09-2007 10:07 PM
Toyota Tundra bed failures , Where's the media ? - ClassicBroncos.com Forums This thread Refback 11-07-2007 04:41 PM
Realoldspower.com :: View topic - Back with more Toyota quality... This thread Refback 11-07-2007 11:29 AM
Toyota's new take on quality - XceedSpeed This thread Refback 11-05-2007 10:21 PM
TOY ota trucks - Disturbed Riders - Stunt Bike Forum This thread Refback 11-01-2007 11:14 AM
So much for Toyota Quality???? - Chevy SSR Fanatic This thread Refback 10-31-2007 07:01 PM
So much for Toyota Quality???? - Chevy SSR Fanatic This thread Refback 10-31-2007 03:21 PM
Ignorant Toyota Ass - Cheers & Gears Forums This thread Refback 10-30-2007 05:00 PM
Realoldspower.com :: View topic - Back with more Toyota quality... This thread Refback 10-28-2007 05:23 PM
Corvette ZR1: Your exotics are no longer safe. - Page 3 - XmodSource.com This thread Refback 10-26-2007 08:20 AM
Corvette ZR1: Your exotics are no longer safe. - Page 3 - XmodSource.com This thread Refback 10-26-2007 01:57 AM
Toyota taken off the best buy list of Consumer reports - Motor City Marauders This thread Refback 10-24-2007 03:22 PM
Realoldspower.com :: View topic - Back with more Toyota quality... This thread Refback 10-23-2007 11:07 PM
Realoldspower.com :: View topic - Back with more Toyota quality... This thread Refback 10-23-2007 07:35 PM
Realoldspower.com :: View topic - Back with more Toyota quality... This thread Refback 10-23-2007 12:31 PM
Realoldspower.com :: View topic - Back with more Toyota quality... This thread Refback 10-23-2007 10:16 AM
The CRX Community :: View topic - Tundra 1/4 mi ET This thread Refback 10-08-2007 02:59 PM
The CRX Community :: View topic - Guess what truck I bought?... UPDATE This thread Refback 09-24-2007 09:47 PM
The CRX Community :: View topic - Guess what truck I bought?... UPDATE This thread Refback 09-20-2007 08:56 PM
Why the fark can't Honda do anything original? - Page 6 - SRTforums.com This thread Refback 09-20-2007 04:40 AM
24hourcampfire: New Tundra ?? This thread Refback 09-04-2007 04:43 PM
2007 Avalon Transmission issue, engine surges TedT Avalon 10 10-27-2007 09:46 PM
transmission flush nhparrot Engine & Drivetrain 4 08-26-2007 08:46 PM
2007 Toyota FJ Cruiser: The Result of Art, Technology and Heritage TS Support Toyota, Scion & Lexus News 0 09-20-2006 11:19 PM
Toyota Announces 2007 Prices For Nine Vehicles in Model Lineup TS Support Toyota, Scion & Lexus News 0 08-08-2006 12:36 PM
2007 Toyota Camry Pricing TundraSoul Camry 1 03-01-2006 08:11 PM
