LinkBack (19) Thread Tools Display Modes
  #136 (permalink)
Old 11-27-2007, 10:05 PM
mhadden's Avatar
Dealer : Toyota Of Merrillville
2007 Toyota Tundra 5.7 CrewMax
Last Online: 04-08-2008 02:03 PM
mhadden will become famous soon enough.
mhadden's Photo Albums
Default Re: DIY: Oil Change w/ pics. & Reset Maintenance Required Light
Yes if you can get a 65mm only, then you'll be fine. I can't edit my original post to reflect that, though. Time has expired for me to do that.
2008 Honda CR-V EX AWD
2008 Honda Civic LX
  #137 (permalink)
Old 12-01-2007, 01:50 PM
Dealer : Putnam Toyota
Last Online: 10-07-2009 09:28 PM
joshp is on a distinguished road.
joshp's Photo Albums
Anyone else run into issues with their oil filter flute slipping? I have a metal one. I'm going to see what the dealership has. I bought a 65mm.
The dealership didn't sell any special tool. They said try napa. I bought another one at Napa and it slipped as well. I finally grabbed a 1/2" torque wrench drive for leverage (It was the only handled ratchet that I had). THis helped a lot but it still wasn't easy. I had to push hard up against the oil flute wrench with my left hand and pull on the torque wrench with my right hand.
Getting skid plate back on
My skid plate actually went on pretty easy. I rested it on a padded creeper. I put two bolts in the front (just slightly threaded in ) then move to the back and this enabled me to see in between the plate and the mounting holes so that I could more easily line things up.
One last question. I found a metal washer in my oil filter kit box. Does anyone know what this is for? It is to replace whatever washer is on the oil drain plug? Or maybe it was just in the box by mistake? The instructions on the box didn't address what this washer was for. They only spoke of the rubber washers.
  #138 (permalink)
Old 12-01-2007, 10:08 PM
Dealer : McGeorge Toyota
Last Online: 01-03-2009 03:22 PM
one_fast_1000 is on a distinguished road.
one_fast_1000's Photo Albums
Advance Auto is now selling the purolator filter kit part number L25702 it comes with a screw-in "plastic tool" for the filter housing. much easier. Hope this info helps someone
  #139 (permalink)
Old 12-01-2007, 10:14 PM
Mine slips too. I use a shop rag and place it between the filter housing and the flute. Off the subject i put a little notch in one of the tabs on the outside of the housing cap that the little metal prong touches. when i put it back on i just tighten it so that it ends up in the exact same position. Let me know some input if anyone thinks that is a good idea.
  #140 (permalink)
Old 12-03-2007, 05:13 AM
Dealer : Hamer Toyota
Last Online: 06-08-2009 01:49 AM
biaachmonkie is on a distinguished road.
biaachmonkie's Photo Albums
I just completed this, and what a pain. I got a 65mm metal flute wrench and it just slipped couldn't keep it on no matter how much force I applied and it was too late to get a smaller one. I measured the end cap and its 63mm, am I odd man out here with a smaller end cap then everyone else or what?
I ended up getting it off with large channel locks, that was a tight fit, it seems like everything is designed to perfectly get in the way of that.
  #141 (permalink)
Old 12-03-2007, 02:27 PM
Afterimage's Avatar
Dealer : Toyota of Puyallup
2007 Toyota Tundra DC TRD LTD 4x4
Last Online: Today 01:05 AM
Afterimage is on a distinguished road.
Afterimage's Photo Albums
I don't know why you guys are beating yourselves up over the proper filter wrench to use.
GET A KD-TOOLS 3253
It grabs tight and does not slip.
See post #113 above
  #142 (permalink)
Old 12-03-2007, 07:59 PM
Originally Posted by Afterimage View Post
Get a KD Tools model number 3253.
Made of steel and fits great.
Skyhammerz reference post
Where did you buy it?
  #143 (permalink)
Old 12-03-2007, 09:03 PM
Afterimage's Avatar
HERE.
  #144 (permalink)
Old 12-05-2007, 12:34 AM
Thanks I'll think about it. This will be the 3rd wrench I've bought so maybe 3rd times a charm if not I'm up to like $18 in failed tools, lol.
  #145 (permalink)
Old 12-07-2007, 03:08 AM
Dealer : Oakbrook Toyota In Westmont
2002 Toyota Tundra,
1999 Toyota Camry,
2005 Toyota Camry,
2007 Toyota Tundra DC 4x4 1D6/Black Bnh
Last Online: Today 03:32 AM
RichR is on a distinguished road.
RichR's Photo Albums
I purchased the KD 3253 at ToolSource.com.
Its on the way.
The Penzoil 65/67 cap wrench slipped when I did oil change #1.
So I bought this one for oil change #2.
Former Dodge Boy
Now a Toyota Man
Proud to be doing
Life@TS
  #146 (permalink)
Old 12-08-2007, 11:40 PM
Dealer : Royal Moore Toyota
2008 Toyota Tundra Crewmax Limited,
1995 Toyota Supra 6sp. 67mm turbo
Last Online: 10-14-2009 02:47 PM
jsantesson is on a distinguished road.
jsantesson's Photo Albums
I bought a 2 1/2" (65mm) filter wrench from autozone and it kept slipping so I had to use an adj. filter wrench and that was a major pain. It was all I could do to get that part loosened. I think next time I'll buy the KD wrench, the cheap china wrench isn't doing the job. Whoever is tightening that at the factory needs to use a torque wrench. I'm not sure how much 25 nm is but what I removed was at least 150 ft. lbs. John
  #147 (permalink)
Old 12-15-2007, 02:57 AM
Dealer : Toyota Sunnyvale
Last Online: 10-02-2009 05:57 PM
Starwatcher is on a distinguished road.
Starwatcher's Photo Albums
Just finish my first oil change and found out the cheap 65mm oil filter wrence could do the job as previous threads said.
I spent almost one hours to shop around local retail store and finally get a Craftsman univeral oil filter wrench 28 20519 to get the filter cap down. This universal wrench works. But it is really hard to get it off with this tool. After I unscrew about 1/2 turn, it is still very hard to turn by hand.
I just placed an order for KD 3253 wrench from amazon.com and hopefully it will be an easier job next time.
Thank everone who provide those valuable information.
  #148 (permalink)
Old 12-15-2007, 07:59 AM
Dealer : Faulkner Toyota
2007 Toyota Tundra,
1995 Toyota T100,
- Other - 88 4Runner SR-5
Last Online: 11-04-2009 07:22 PM
gobblerman is on a distinguished road.
gobblerman's Photo Albums
Same experience here with the filter housing needing incredible amounts of torque to remove. Some one else posted that they lubed the oring which made removal easier. Perhaps Toyota should prelube this oring or recomend the proper lube to use.
  #149 (permalink)
Old 12-15-2007, 08:37 AM
Dealer : Beechmont Toyota
Last Online: 09-18-2009 07:43 PM
Darrint is on a distinguished road.
Darrint's Photo Albums
Wow what a pain as compared to a typical oil change on anything else! They sure don't want the everyday Joe doing this themselves do they? Any idea what Toyota charges for an oil change on this beast?
  #150 (permalink)
Old 12-15-2007, 08:44 AM
2007 Toyota Tundra,
1995 Toyota T100,
From postings on TS it looks like dealer oil change prices can vary from 20 to 100 dollars. One caution though, dealerships often like to slip 5w30 in the truck and play stupid when told it takes 0w20 or 5w20. I found the DIY oil change to be ok except for the torque required to remove the housing. If I had a better wrench I'm sure my oil change would have taken half the amount of time.
LinkBack to this Thread: http://www.tundrasolutions.com/forums/tundra/104260-diy-oil-change-w-pics-reset/
Posted By For Type Date
DIY (Do-It-Yourself) & User Knowledgebase - Tundra Geeks :: The Toyota Tundra Enthusiast Forum This thread Refback 09-17-2009 03:24 PM
DIY (Do-It-Yourself) & User Knowledgebase - IBTO Toyota Tundra Forum This thread Refback 07-02-2009 12:39 AM
DIY (Do-It-Yourself) & User Knowledgebase - IBTO Official Forums This thread Refback 06-25-2009 11:57 PM
Anyone change there own oil? - IH8MUD Forums This thread Refback 04-28-2009 02:26 PM
Bumper Repair In Jacksonville, Bumper Repair 2000 Hyundai Sonata 4 Dr Gls, Bumper Sticker Motorcycle Safety - Dieselmotorcycle This thread Refback 03-08-2009 11:22 AM
White Stripe Power Wheels Ford Mustang Ride On Toy, White Stripe Power Wheels Ford Mustang, White Van Speakers - Dubswheels This thread Refback 03-06-2009 03:36 AM
08 Sequoia oil filter question - Toyota Forums :: Toyota Nation This thread Refback 11-02-2008 12:37 AM
Yesterday's Tractors :: View topic - Tundra message This thread Refback 08-21-2008 10:13 PM
Yesterday's Tractors - Discussion Forum This thread Refback 08-21-2008 08:37 AM
: Tow Vehicles: Tundra 5.7L Oil Changes This thread Refback 02-14-2008 04:15 PM
Woodalls Open Roads Forum: Tow Vehicles: Tundra 5.7L Oil Changes This thread Refback 10-27-2007 09:33 PM
RV.Net Open Roads Forum: Tow Vehicles: Tundra 5.7L Oil Changes This thread Refback 10-26-2007 01:48 PM
RV.Net Open Roads Forum: Tow Vehicles: Tundra 5.7L Oil Changes This thread Refback 10-24-2007 08:28 PM
RV.Net Open Roads Forum: Tow Vehicles: Tundra 5.7L Oil Changes This thread Refback 10-24-2007 04:16 PM
RV.Net Open Roads Forum: Tow Vehicles: Tundra 5.7L Oil Changes This thread Refback 10-24-2007 12:55 PM
Trailer Life Directory Open Roads Forum: Tow Vehicles: Tundra 5.7L Oil Changes This thread Refback 10-23-2007 09:04 PM
Trailer Life Magazine Open Roads Forum: Tow Vehicles: Tundra 5.7L Oil Changes This thread Refback 10-23-2007 03:26 PM
RV.Net Open Roads Forum: Tow Vehicles: Tundra 5.7L Oil Changes This thread Refback 10-23-2007 02:54 PM
RV.Net Open Roads Forum: Tow Vehicles: Tundra 5.7L Oil Changes This thread Refback 10-23-2007 02:49 PM
Currently Active Users Viewing This Thread: 2 (1 members and 1 guests)
Resqhopper
Oil Filter Change nhparrot Engine & Drivetrain 10 06-07-2009 07:15 PM
too soon for an oil change? john480 Tundra 24 11-29-2007 01:56 PM
Which BRAND of OIL? nhparrot Engine & Drivetrain 9 10-29-2007 01:43 PM
Alternate Oil Filters for I-Force V8: nhparrot Engine & Drivetrain 0 03-24-2002 10:09 PM
