LinkBack (19) Thread Tools Display Modes
  #151 (permalink)
Old 12-15-2007, 09:00 AM
Dealer : Beechmont Toyota
Last Online: 09-18-2009 07:43 PM
Darrint is on a distinguished road.
Darrint's Photo Albums
Default Re: DIY: Oil Change w/ pics. & Reset Maintenance Required Light
I'm not crazy about takin off the skid plate for every oil change. Might just leave it off since I don't really plan on much off roadin.
  #152 (permalink)
Old 12-15-2007, 08:03 PM
Dealer : Atkinson Toyota
1998 Toyota Tacoma,
2007 Toyota Tundra,
- Other - 1984 Toyota 4Runner
Last Online: 09-07-2009 10:08 PM
Aggietaco is on a distinguished road.
Aggietaco's Photo Albums
After reading all of the complaints on here about the oil change, I was expecting the worse. Now maybe if this was your first oil change, it could be a pain, but this was a fairly typical job. The hardest part for me, was figuring out that the plastic drain plug snaps into the filer housing instead of just holding it up there with warm oil dripping down my arm.
  #153 (permalink)
Old 12-16-2007, 10:12 PM
Dealer : Sun Country Toyota
Last Online: 04-07-2009 11:45 AM
KXcam is on a distinguished road.
KXcam's Photo Albums
Thanks for the excellent writeup and pics. Made the change easy. After reading all the complaints I thought this was going to be hard. Took less than an hour for the first change, so will be much faster next time. I didn't get much oil out of the filter housing so I might skip the drain next time and just remove it full of oil. The only pain was the $5.99 polycarbonate filter tool that slipped. I noticed that it doesn't seat fully - there are 4 vertical tabs on the housing that prevent it. I filed 4 slots with a 3/8" round file to let the housing insert farther into the tool and then no probs. A cast 65mm one would be better- I still may get one since they are cheap. Installed a fumoto drain valve (F103) to make less mess. Next change I might cut a round hole under the filter housing so that I can leave it on. Thanks again.
5.7L 4WD CrewMax, Silver Sky, TRD, Remote Starter, Sill Plates X4, Color Matched LineX.
  #154 (permalink)
Old 12-16-2007, 10:21 PM
TundraBay's Avatar
Dealer : Wayne Toyota
2007 Toyota Tundra,
Last Online: Yesterday 10:00 PM
TundraBay is the One. TundraBay is the One. TundraBay is the One. TundraBay is the One. TundraBay is the One. TundraBay is the One. TundraBay is the One. TundraBay is the One. TundraBay is the One. TundraBay is the One. TundraBay is the One.
TundraBay's Photo Albums
The cost of one tank of gas every 5,000 miles? I'll let the dealer deal with the mess
[Tundra Bay]
Proud Member CBTMA
Radiant Red
  #155 (permalink)
Old 12-21-2007, 06:59 PM
Dealer : Boch Toyota
Last Online: 10-11-2009 02:17 PM
highway74 is on a distinguished road.
highway74's Photo Albums
I completed my first oil change at 3k today and was pleasantly surprised that it was far less painful than anticipated. I got a large 5 gallon oil catch tub with high sides and put a large sheetmetal Blitz drip pan under that (didn't need it though.) After doing all of my service work on my 94 4x4 SR5 with the 3.0, the 5.7 was a far cleaner job with the help of this write up (excellent job!) No oil spilling everywhere like my 3.0 when pulling the filter. I simply put a 10" piece of garden hose over the plastic oil filter cap drain tool and it went right into the catch tub with no mess. I used the KD Tools 65mm metal cap socket 3/8 drive. I used to have to take the skid plate off on my 3.0 and even then you had to be a contortionist to get at the filter. I also pull the skid plate on the wife's 4Runner with 4.7 for oil changes, so I guess for me pulling the skid plate is just the norm. I used the OEM filter and Mobil 1 5w-20 full synthetic. The only time consuming thing was waiting for the oil to drain (jacked up driver side front and got quite a bit more oil out.) Torqued everything to factory spec and good to go. Thanks again for the sticky!
  #156 (permalink)
Old 12-21-2007, 07:04 PM
My total cost for Mobil 1 and OEM filter was about $40.00. Toyota wanted $75.00 with Mobil 1 and I have the piece of mind that it was done right with the right oil.
  #157 (permalink)
Old 01-27-2008, 02:42 PM
Dealer : Jim McNatt Toyota Scion
2008 Toyota Tundra 4WD TRD double cab
Last Online: 11-10-2008 03:33 PM
alexanderblake is on a distinguished road.
alexanderblake's Photo Albums
Originally Posted by flipperstundra View Post
I was wondering is the only place to get an oil filter for an 07 Tundra 5.7L is from Toyota?
You can get a Purolator brand and it comes with a SCREW IN tool so you don't have to pop it on and off. Also comes with two new O-rings.
  #158 (permalink)
Old 01-27-2008, 02:47 PM
Dealer : Durant Toyota
Last Online: 10-29-2009 09:41 PM
SR5NEWBIE is on a distinguished road.
SR5NEWBIE's Photo Albums
I do not enjoy changing the oil on these trucks. It's not hard but it take considerably longer than my chevy.
  #159 (permalink)
Old 01-27-2008, 04:15 PM
2XOverhead's Avatar
Moderator
Dealer : Toyota Scion of Santa Monica
2002 Toyota Tundra V8 SR5 TRD
Last Online: Today 12:42 AM
2XOverhead will become famous soon enough. 2XOverhead will become famous soon enough.
2XOverhead's Photo Albums
Great DIY, esp. the insider tip on resetting the odometer.
MODS: Oversized Drain Plug.
DIY: ATF Flush, w/ Pics.
DIY: Coolant Flush, w/ Pics.
Coming Soon?
  #160 (permalink)
Old 01-27-2008, 04:18 PM
2XOverhead's Avatar
Moderator
Originally Posted by HOGWILD View Post
Craftsman 44595 Torque Wrench, 1/2 in. Drive at Sears.com
They are on sale and can save you a bunch of money if youhave had one too many beers!! Yes they are expensive but A MUST to use unless ya wanta be like the dealer techs!! worth every penny!!
One of my fav. tools.
DIY: Oil Change w/ pics. & Reset Maintenance Required Light-torque-wrench.jpg
Coming Soon?
  #161 (permalink)
Old 02-07-2008, 04:58 PM
Dealer : Janzen Toyota
Last Online: 08-25-2008 08:36 PM
rwblank is on a distinguished road.
rwblank's Photo Albums
Does anyone know if a conversion kit is in the works to get rid of the cartridge filter? I would drop whatever it takes to get back to the spin on filter...
  #162 (permalink)
Old 02-15-2008, 07:43 PM
07White-SR5's Avatar
Dealer : Robbins Toyota
Last Online: 09-28-2009 08:43 PM
07White-SR5 is on a distinguished road.
07White-SR5's Photo Albums
Changed the oil today in about 40min, easy job thanks for the write-up.
"Handle it? Sir...for 2 billion dollars, I'd handle my grandfather's balls."
-Cartman
5.7L DC - TRD CAI+Dual Exhaust, CW Grill, Chrome Handles, tint, 3" Truxxx Lift, HID's, G2 BakFlip, Rhino Lining, 20" Goliaths+33" Toyo's.
  #163 (permalink)
Old 02-16-2008, 04:46 PM
Dealer : Victory Toyota of Plymouth
Last Online: 02-15-2009 12:07 PM
hypersonic is on a distinguished road.
hypersonic's Photo Albums
Can this be made a Stickey?
Good writeup, Thanks!
  #164 (permalink)
Old 02-17-2008, 08:52 PM
Henry T's Avatar
Dealer : St. Charles Toyota
Last Online: Today 03:11 AM
Images: 22
Henry T will become famous soon enough. Henry T will become famous soon enough.
Henry T's Photo Albums
Why? That would complicate the system more. Get used to it, not that hard.
2007 Tundra DC SR5 TRD Nautical Blue, 5.7, 4X4, Toytec 2.5" front lift, 1" rear block, Diff. drop kit, BFG AT KOs 305/65R/18, JVC KW-AVX810 head unit, HD Radio, Sirius, JVC CH X1500 12 disc CD changer, Scosche piano black dash kit, Alpine 550 4 channel amp 90 watts per channel, Focal 165 V1 components front, Cliff Designs CD60-4C Components rear, Modified Pioneer sealed sub box, MTX Audio TT 6510-04 10" shallow sub, Alpine 450 mono amp 220 watts, R/F 1 farad digital capacitor, All 4 doors and rear wall DynaMatt, Hard wired Escort Passport 8500 X50, Boyo VLT 300 rear veiw camera.
  #165 (permalink)
Old 02-19-2008, 03:49 PM
Dealer : Crestmont Toyota
2000 Toyota Celica,
- Other - 1987 FJ-60
Last Online: 11-05-2009 10:21 PM
Zack1978 is on a distinguished road.
Zack1978's Photo Albums
Because it would be better?
Zack
1987 FJ-60
1979 4x4 pick up, 20R
2000 Velica GT-s 6spd
LinkBack to this Thread: http://www.tundrasolutions.com/forums/tundra/104260-diy-oil-change-w-pics-reset/
Posted By For Type Date
DIY (Do-It-Yourself) & User Knowledgebase - Tundra Geeks :: The Toyota Tundra Enthusiast Forum This thread Refback 09-17-2009 03:24 PM
DIY (Do-It-Yourself) & User Knowledgebase - IBTO Toyota Tundra Forum This thread Refback 07-02-2009 12:39 AM
DIY (Do-It-Yourself) & User Knowledgebase - IBTO Official Forums This thread Refback 06-25-2009 11:57 PM
Anyone change there own oil? - IH8MUD Forums This thread Refback 04-28-2009 02:26 PM
Bumper Repair In Jacksonville, Bumper Repair 2000 Hyundai Sonata 4 Dr Gls, Bumper Sticker Motorcycle Safety - Dieselmotorcycle This thread Refback 03-08-2009 11:22 AM
White Stripe Power Wheels Ford Mustang Ride On Toy, White Stripe Power Wheels Ford Mustang, White Van Speakers - Dubswheels This thread Refback 03-06-2009 03:36 AM
08 Sequoia oil filter question - Toyota Forums :: Toyota Nation This thread Refback 11-02-2008 12:37 AM
Yesterday's Tractors :: View topic - Tundra message This thread Refback 08-21-2008 10:13 PM
Yesterday's Tractors - Discussion Forum This thread Refback 08-21-2008 08:37 AM
: Tow Vehicles: Tundra 5.7L Oil Changes This thread Refback 02-14-2008 04:15 PM
Woodalls Open Roads Forum: Tow Vehicles: Tundra 5.7L Oil Changes This thread Refback 10-27-2007 09:33 PM
RV.Net Open Roads Forum: Tow Vehicles: Tundra 5.7L Oil Changes This thread Refback 10-26-2007 01:48 PM
RV.Net Open Roads Forum: Tow Vehicles: Tundra 5.7L Oil Changes This thread Refback 10-24-2007 08:28 PM
RV.Net Open Roads Forum: Tow Vehicles: Tundra 5.7L Oil Changes This thread Refback 10-24-2007 04:16 PM
RV.Net Open Roads Forum: Tow Vehicles: Tundra 5.7L Oil Changes This thread Refback 10-24-2007 12:55 PM
Trailer Life Directory Open Roads Forum: Tow Vehicles: Tundra 5.7L Oil Changes This thread Refback 10-23-2007 09:04 PM
Trailer Life Magazine Open Roads Forum: Tow Vehicles: Tundra 5.7L Oil Changes This thread Refback 10-23-2007 03:26 PM
RV.Net Open Roads Forum: Tow Vehicles: Tundra 5.7L Oil Changes This thread Refback 10-23-2007 02:54 PM
RV.Net Open Roads Forum: Tow Vehicles: Tundra 5.7L Oil Changes This thread Refback 10-23-2007 02:49 PM
Oil Filter Change nhparrot Engine & Drivetrain 10 06-07-2009 07:15 PM
too soon for an oil change? john480 Tundra 24 11-29-2007 01:56 PM
Which BRAND of OIL? nhparrot Engine & Drivetrain 9 10-29-2007 01:43 PM
Alternate Oil Filters for I-Force V8: nhparrot Engine & Drivetrain 0 03-24-2002 10:09 PM
