LinkBack (20) Thread Tools Display Modes
  #166 (permalink)
Old 02-25-2008, 10:04 PM
Dealer : Kendall Toyota Scion
Last Online: 03-09-2008 01:18 PM
RuKuS is on a distinguished road.
RuKuS's Photo Albums
Default Re: DIY: Oil Change w/ pics. & Reset Maintenance Required Light
Great How-to!! Thanks mhadden for taking your time and effort to post this helpful tutorial!
Also, thanks to everyone else who posted their experiences and suggestions to make this go that much easier the 1st time around!
Mike
  #167 (permalink)
Old 03-02-2008, 12:24 AM
Gunner Tundra's Avatar
Dealer : Kearny Mesa Toyota Scion
2007 Toyota Tundra LTD 5.7L 2WD Black,
2000 Toyota 4Runner LTD 3.4L 2WD M. Slvr
Last Online: Today 12:08 AM
Images: 133
Gunner Tundra is on a distinguished road.
Gunner Tundra's Photo Albums
This helped a lot. Thanks. I did run in to one problem though. The filter cap would not come off using the "Walmart" 65/67mm 14 flute wrench. It kept slipping from the cap. After refilling the engine with 7 qts of oil, I had to drive it to my local dealer to have them remove and replace the oil filter for me. This time, they allowed me to observe and even tightened my own filter cap after replacing the O-rings so I know exactly how much resistance there is the next time I go to remove it for an oil change. I saw the oil technician tighten the oil cap and he did it really tight. The truck was raised on the stands, so it's very easy to overtighten it, so I made sure it was tight enough, not overtight like what the dealership does. Also, they used an all metal flute wrench that worked a lot better than my plastic one.
I recommend getting the metal one because if you've ever let the dealer change your oil before you, they might have overtightened the cap, and trying to loosen it from a laying position is a lot harder than the standing position.
2007 Tundra CrewMax LTD 8272 Black/Sand Biege - Navigation, Rear Seat Entertainment, 20" Alloys, Sunroof, Mudguards, Sonar, DTR, V2 Alarm w/GBS.
MODS: Line-X, RETRAX, Tech Formula Paint Sealant, Debadged, Clear DRL's, AMP Powerstep Running Boards, 2.4" ReadyLift, Nitto Terra Grapplers 305/55/20's on OEM LTD 20" Alloys, Ravelco Anti-Theft Device, aFe CAI Stage 2 ProDry S, Corsa Performance Touring Exhaust. NEXT MODS: TRD Sway Bar, Auto Tailgate.
2000 4Runner LTD Millenium Silver 2WD - TRD Intake Air Filter, Clear-Corner Parking lenses, partial Debadge. Removed: Poweraid Throttle Body Spacer
1965 Ford Mustang 289 cid Laser Red - 5 spd, McLeod Clutch, Hydraulic Slave Clutch Cylinder, 3:89 Trac-Loc, 9" Lincoln Versialles Differential, 4 Wheel Disc Brakes, SVO Aluminum Master Cylinder, Simmons F90 custom wheels with Front/Rear width off-set, TFS Twisted Wedge heads, Holley 650 Double Pumper, Crower Custom CAM, Hooker Headers, Flowmaster w/H-pipe 2.5", SPAL fan, Weiand Stealth Intake - Mid 13's at 104 MPH street tires!
SOLD: 1993 Toyota Truck Xtra Cab SR5 2WD - E&C Spring UCA 3" lift, ProComp 3" Body lift, ProComp ES3000 Shocks, Rear Add-A-Leafs, 14mm Sway-Away Torsion Bars, Custom Skidplate and Driving light bar w/PIAA 40 Driving lights, Hella H4 Headlights, Optima Battery, Jacobs Omni-Pak w/8.5mm wires, K&N FIPK, FlowMaster 2 Chamber 2.5" CAT-Back Exhaust, 10 deg. Advanced Timing, Western 15x8 wheels, BFG TA KO's 31x10.5x15, 4.11:1 Gears w/Tru-Trac TracLok.
IYAOYAS!
  #168 (permalink)
Old 03-05-2008, 10:57 PM
Dealer : Avondale Toyota Scion
Last Online: 03-05-2008 11:59 PM
skycast is on a distinguished road.
skycast's Photo Albums
This was great help. Thank you. I have been changing oil all the way back to the days that we used leaded gasoline to clean up our spilled oil. I especially liked the write up that states "I’ve been changing my own oil since I’ve been driving and this was the messiest, most pain-in-the-a$$ thing I’ve ever dealt with". I have to second that. Several things I notice. I bought a six pack. If you are a pro at changing oil this one will not be as quick as you thought. You better by a 12 pack. I found out the hard way. I put it back together and put the skid plate back on. Filled it up with oil and turned it on. Well some how I put the large rubber ring on the filter cover wrong. Go figure. It got pinched out side of the filter cover and leaked all over the driveway. Boy I could have used long necks and some leaded gas. I had to clean it up take the skid plate off and redue the ring. I bought my filter from Checker/Shucks/Kragen. It was a Fram filter and it cost me about $6.00. They had to order it and it took a half day to get in. What I would liked to see is the, and I should taken pictures, filter out and where the ring goes in place. When you take yours apart make sure you make note were the large rubber ring is. Do not take it off and start drinking. You will put it on wrong. Second, my truck has had the oil changed by the dealer and I noticed that they put the oil filter cover on as tight as they could. I had to use the rubber strap type wrench to bust it loose. One thing I did notice was the 65/67mm wrench did not work. I bought mine from a Napa store for $4.16. It too took them a half day to get it in. So call first before you go in to Napa. Maybe I do not understand the concept of the wrench but when I put it on and start torking it down all it does is jump loose and spin on the cover. I found myself pushing harder on the wrench against the cover than I was using with the other arm to spin the 3/8" ratchet. I could use some help here and the proper use of the wrench. So get your self a 12 pack of long necks a few limes and have fun. Thanks again for the help.
  #169 (permalink)
Old 03-05-2008, 11:10 PM
Originally Posted by mhadden View Post
I think if you have a 4x2, you won't have the skid. You should've picked up 7 quarts though
I have a 4x2 and it has the skid plate and boy does it have enough hardware holding it to the truck
  #170 (permalink)
Old 03-06-2008, 08:23 PM
Dealer : Bob Rohrman Toyota
2001 Toyota Sienna,
2008 Toyota Tundra 4x2 SR5 5.7L DC SL M
Last Online: 04-12-2009 11:50 AM
dihtn is on a distinguished road.
dihtn's Photo Albums
The $60.00 price from the dealership for a M1 oil change is sounding better and better...
  #171 (permalink)
Old 03-06-2008, 08:48 PM
MOREPOWER's Avatar
Last Online: 09-06-2008 09:56 AM
MOREPOWER will become famous soon enough.
MOREPOWER's Photo Albums
Problem with that is, will they really put in Mobil 1, will they put in the right viscosity oil, will they actually change the filter. Id say give it a try, for about $35 to $40 (for good synthetic) you can do it yourself, and be 100% sure its right.
I would give it a try once or twice before opting for a dealer.
One thing the new gen Tundras have over the old is, the filter dissecting gurus, would love this setup, no filter cutter required.
  #172 (permalink)
Old 03-22-2008, 08:41 PM
2008 Toyota Tundra,
2007 Lexus ES350
Last Online: 11-07-2009 10:03 AM
Images: 10
GMoney749 is on a distinguished road.
GMoney749's Photo Albums
Just changed my oil for the first time. Of the 26 vehicles I've owned, that's the most mess I've EVER made in my driveway changing fluids.
But this tutorial was very helpful (thanks a bunch), and it really wasn't all that bad. Now that I know what I'm doing, the next time will be a snap.
2008 Toyota Tundra SR5 DC 5.7L
2007 Lexus ES350
2003 Infiniti FX35
1971 Datsun 240Z
2005 BMW K1200S
2003 Ducati 749S
This...is....TUNDRA!!
  #173 (permalink)
Old 03-25-2008, 04:51 PM
Dealer : Toyota of Temecula Valley
2007 Toyota Tundra DCSB 4x4
Last Online: 02-08-2009 10:12 PM
Emanon is on a distinguished road.
Emanon's Photo Albums
my dealership will charge $20.00 for labor and filter if I bring in my own oil.
Hmmmm...
  #174 (permalink)
Old 03-27-2008, 03:34 PM
Dealer : Hoy-Fox Toyota
Last Online: 03-31-2008 11:31 AM
arnoldo is on a distinguished road.
arnoldo's Photo Albums
Unhappy Re: DIY: Oil Change w/ pics. & Reset Maintenance Required Light
Sorry guys. It's my first time on this kind of forums and don't know how to use it yet... This is related to transmition oil.
I have a Tundra '06 that drain some of the transmision oil. I couldn't find the gauge tube/pipe to check how much I need to refill.
Someone toll me that transmition is sealled. I'm assuming that should be a way to refill it anyway.
If you have an idea please let me know (I will appreciate it)..
Regards.
Arnoldo
  #175 (permalink)
Old 03-29-2008, 04:48 PM
Last Online: 09-25-2009 04:14 PM
Monkey's Uncle is on a distinguished road.
Monkey's Uncle's Photo Albums
Just completed my first oil change, thanks to your great post. I second the messy part. I read your warning about the oil squirting toward the wheel, so I moved the oil pan that way but it still was coming out so hard it splashed out of the oil pan and on to the wheel. I then watched it until it slowed down and moved the pan directly under it and went for that first beer. When I looked again, the oil had run out of the drain hole and along the bottom of the oil pan and missed the oil pan and onto the driveway. What a mess! The only shortcoming of your post was that you did not list a dozen towels along with the necessary tools. I will try to do better the next time.
  #176 (permalink)
Old 04-04-2008, 04:14 PM
Dealer : Caldwell Toyota
2007 Toyota Tundra,
2008 Toyota Sequoia Limited -Cassis
Last Online: 11-19-2009 04:36 PM
edthefireman is on a distinguished road.
edthefireman's Photo Albums
The next time you get a big card board box, fold it and save it to use underneath when changing your oil. I save all my big boxes, they come in very useful for situation like changing your oil and turkey frying.
  #177 (permalink)
Old 04-05-2008, 06:06 PM
Dealer : Performance Toyota Of Lincoln
Last Online: 04-05-2008 10:58 PM
barthmonster is on a distinguished road.
barthmonster's Photo Albums
I thank you for your thoughtful post (sticky). It was very helpful.
I havn't had time to read all 11 pages, so this may be a re-post.
I think they do this with the skid-plate on at the dealer, after looking at the wrench-hole in the skid-plate, I'm going to do this next time. I'll use a hose on the plastic thingy that drains the filter. I'll reach above the skidplate from the driver side to install the service-tool (oil filter wrench) which I'm going to buy from toyota after having trouble with my plastic-one flexing and slipping alot.
The whole thing was a hassle, but by leaving the skid-plane installed (if it works) I'm thinking it will be much easier.
Hey also, a torque-wrench is a great idea, but not for everything. I've got 280,000 miles on my camry. The oil pan is really thick at the bottom. I'm sure I've 'overtorqued' it about a hundred times, still holds my Mobil 1 though...
Love finding this forum, Love my 5.7 Tundra !! Thanks everyone !!
  #178 (permalink)
Old 04-05-2008, 06:58 PM
Last Online: 11-12-2009 09:07 PM
flypigs is on a distinguished road.
flypigs's Photo Albums
I'll add again that this is in fact the worst vehicle I've ever seen for oil changes. My truck is 8 months old, but only has 3000 miles, so I figured it was time. Took almost 2 hours, and I'm a fairly competent, but admittedly slow mechanic.
I started by driving up on a couple sections of 2x6, just to get a bit more room underneath. Then I cut down a 5 gallon bucket to fit underneath, but I still spilled a 1/2 pint of oil or so because after the initial surge, the drip point keeps moving.. You certainly can't go grab a drink, because you will have a mess.
The skid pan wasn't too bad, but the whole filter drain thing, I don't get it.. When I pushed it up, only a bit came out of the tube, most came around the edges. Some smart guy needs to create a screw-in tool that will activate the drain valve after a few turns, and actually drain down the tube. I'll pay $15 for one.
After too much oil ran down my gloves, and dripped onto my sleeve, I grabbed a 16mm flat wrench, and used it as a lever over the sway bar to push up on the drain tool, and that worked great. Good leverage, and nothing dripping on my arms.
The rest was easy, thanks to this VERY HELPFUL thread. Thanks so much!
All things considered, it's still probably better than letting some uncaring tech at a dealer or jiffy lube do it. If I drove 15k a year, that might change my mind though.
Pete
07 Nautical blue, doublecab, 4x4, 5.7, shortbed, benchseat, SR5
05 Jetta wagon TDI, worth more now then when I bought it
My Dad still drives my old 1986 Hilux 4x4 most days. He has a new car, but he just loves that old truck.
  #179 (permalink)
Old 04-05-2008, 10:58 PM
Pete
I'll admit it was tricky. I had been lucky enough to read your post about the mess PRIOR to my first oil change (today) so I figured there was a 'trick' to the little plastic filter drain device (prior to this known as a 'thingy'). I tried to push it up in the filter and it didn't work, so I got re-centered so that I could push it up into place hard with both thumbs and my head to one side so it wouldn't squirt in my face. That worked, it SNAPS up in there and drains the filter in about a minute, maybe a little more.
I still want to try the drain-hose idea and leaving the skid-plate on...
DON'T EVER TAKE A TRUCK THIS NICE TO JIFFY-LUBE !!!! That place has way too many under-trained, under-paid people to touch something this nice. They ruined my buddy's 10-bolt on his chevelle. Just my opinion...
  #180 (permalink)
Old 04-06-2008, 03:11 AM
Dealer : Le Mieux & Son Toyota
Last Online: 11-12-2008 12:34 PM
Rooster is on a distinguished road.
Rooster's Photo Albums
After reading through this entire thread, nobody had an answer as to why it was designed this way. Why does the 4.7L have a spin-on filter. Is it just because there isn't enough room for the spin-on or is the cartridge type actually better. I've got the old gen Tundra and it is possible to change the filter without pulling the skidplate off, but I take it off anyway, it's just much easier. Plus I can inspect things while it's off and clean the bottom of the radiator.
LinkBack to this Thread: http://www.tundrasolutions.com/forums/tundra/104260-diy-oil-change-w-pics-reset/
Posted By For Type Date
Dumb Tundra question - TTORA Forum This thread Refback 11-13-2009 07:22 AM
DIY (Do-It-Yourself) & User Knowledgebase - Tundra Geeks :: The Toyota Tundra Enthusiast Forum This thread Refback 09-17-2009 03:24 PM
DIY (Do-It-Yourself) & User Knowledgebase - IBTO Toyota Tundra Forum This thread Refback 07-02-2009 12:39 AM
DIY (Do-It-Yourself) & User Knowledgebase - IBTO Official Forums This thread Refback 06-25-2009 11:57 PM
Anyone change there own oil? - IH8MUD Forums This thread Refback 04-28-2009 02:26 PM
Bumper Repair In Jacksonville, Bumper Repair 2000 Hyundai Sonata 4 Dr Gls, Bumper Sticker Motorcycle Safety - Dieselmotorcycle This thread Refback 03-08-2009 11:22 AM
White Stripe Power Wheels Ford Mustang Ride On Toy, White Stripe Power Wheels Ford Mustang, White Van Speakers - Dubswheels This thread Refback 03-06-2009 03:36 AM
08 Sequoia oil filter question - Toyota Forums :: Toyota Nation This thread Refback 11-02-2008 12:37 AM
Yesterday's Tractors :: View topic - Tundra message This thread Refback 08-21-2008 10:13 PM
Yesterday's Tractors - Discussion Forum This thread Refback 08-21-2008 08:37 AM
: Tow Vehicles: Tundra 5.7L Oil Changes This thread Refback 02-14-2008 04:15 PM
Woodalls Open Roads Forum: Tow Vehicles: Tundra 5.7L Oil Changes This thread Refback 10-27-2007 09:33 PM
RV.Net Open Roads Forum: Tow Vehicles: Tundra 5.7L Oil Changes This thread Refback 10-26-2007 01:48 PM
RV.Net Open Roads Forum: Tow Vehicles: Tundra 5.7L Oil Changes This thread Refback 10-24-2007 08:28 PM
RV.Net Open Roads Forum: Tow Vehicles: Tundra 5.7L Oil Changes This thread Refback 10-24-2007 04:16 PM
RV.Net Open Roads Forum: Tow Vehicles: Tundra 5.7L Oil Changes This thread Refback 10-24-2007 12:55 PM
Trailer Life Directory Open Roads Forum: Tow Vehicles: Tundra 5.7L Oil Changes This thread Refback 10-23-2007 09:04 PM
Trailer Life Magazine Open Roads Forum: Tow Vehicles: Tundra 5.7L Oil Changes This thread Refback 10-23-2007 03:26 PM
RV.Net Open Roads Forum: Tow Vehicles: Tundra 5.7L Oil Changes This thread Refback 10-23-2007 02:54 PM
RV.Net Open Roads Forum: Tow Vehicles: Tundra 5.7L Oil Changes This thread Refback 10-23-2007 02:49 PM
Oil Filter Change nhparrot Engine & Drivetrain 10 06-07-2009 07:15 PM
too soon for an oil change? john480 Tundra 24 11-29-2007 01:56 PM
Which BRAND of OIL? nhparrot Engine & Drivetrain 9 10-29-2007 01:43 PM
Alternate Oil Filters for I-Force V8: nhparrot Engine & Drivetrain 0 03-24-2002 10:09 PM
