LinkBack (20) Thread Tools Display Modes
  #226 (permalink)
Old 11-23-2008, 08:59 PM
Last Online: Yesterday 09:51 AM
Sid Post is on a distinguished road.
Sid Post's Photo Albums
Default Re: DIY: Oil Change w/ pics. & Reset Maintenance Required Light
I had to use a 24" break over to get the bolts out of the skid plate. One of them was cross threaded into the bar the skid plate hooks into.
Why don't idiots at the quickie lube places get issued a torque limiting impact gun?
2007 Toyota Tundra Double Cab SR5 with the 5.7L V-8 and Doug Thorley headers
"Trying to tax yourself into prosperity is like standing in a bucket and trying to pick yourself up by the handle." - Winston Churchill?
  #227 (permalink)
Old 11-23-2008, 09:00 PM
Mr. Creosote's Avatar
Legendary Contributor
Last Online: Today 02:07 AM
Images: 4
Mr. Creosote is the One. Mr. Creosote is the One. Mr. Creosote is the One. Mr. Creosote is the One. Mr. Creosote is the One. Mr. Creosote is the One. Mr. Creosote is the One. Mr. Creosote is the One. Mr. Creosote is the One. Mr. Creosote is the One. Mr. Creosote is the One.
Mr. Creosote's Photo Albums
They would probably set it wrong anyway. The only way to be sure it is right is to DIY.
  #228 (permalink)
Old 11-25-2008, 01:37 PM
Dealer : Miller Toyota
2005 Toyota Tundra DC Phantom Gray
Last Online: 11-19-2009 10:28 PM
Images: 11
dibble9012 will become famous soon enough.
dibble9012's Photo Albums
Same thing happened on my last oil change, one of the bolt heads actually sheared off.
  #229 (permalink)
Old 11-28-2008, 04:51 AM
BlueBoy's Avatar
Dealer : South Bay Toyota Scion
2008 Toyota Tundra,
2004 Toyota Sequoia Limited Gray
Last Online: 09-19-2009 01:43 PM
BlueBoy is on a distinguished road.
BlueBoy's Photo Albums
Originally Posted by RichR View Post
I purchased the KD 3253 at ToolSource.com.
Its on the way.
The Penzoil 65/67 cap wrench slipped when I did oil change #1.
So I bought this one for oil change #2.
I went to this site to check on this part and I came across this
Toyota Oil Filter Wrench TOY 640 / 09228-06501 - 64mm - Assenmacher TOY 640
It appears its a OEM Toyo Tool and the size is only 1 mm smaller @64 mm in lieu of 65mm. Should I purchase this one instead? It costs more at $16.00.
Any ideas?
Thanks
  #230 (permalink)
Old 11-28-2008, 10:16 AM
Last Online: 04-07-2009 09:52 PM
ron717 is on a distinguished road.
ron717's Photo Albums
what about the drain plug gasket? How come it isn't mentioned? Is it required with 5.7?
08 Sequoia SR5, nautical blue, 5.7 V8, tow pkg
  #231 (permalink)
Old 11-28-2008, 12:42 PM
jliltd's Avatar
Dealer : Las Cruces Toyota
2007 Toyota Tundra 4WD DCab Longbed 5.7,
2001 Toyota Sequoia (Wife's Broomstick)
Last Online: 11-04-2009 11:46 AM
jliltd is on a distinguished road.
jliltd's Photo Albums
You can reused the gasket half a dozen times. It's a synthetic fiber washer. However, I usually have a dealer throw one in if I buy a filter element from them. I have never had one turn me down but if they do I think they're less than a buck from trdsparks.com, so if you order a filter from them the shipping is free.
"The beauty of the second amendment is that it will not be needed until they try to take it." -- Thomas Jefferson
  #232 (permalink)
Old 11-30-2008, 04:29 PM
dipstick has 2 notches, one side extruded and other side intruded. On the extruded side oil falls between both notches, but on the intruded side its slightly over top notch. Which side is supposed to be used to measure oil fill?
  #233 (permalink)
Old 11-30-2008, 04:32 PM
Images: 4
I would just check based on which side happens to come up when you pull the dipstick. The difference in actual oil level between intruded and extruded sides will be small and not worth worrying about.
  #234 (permalink)
Old 12-01-2008, 01:48 AM
konscience7's Avatar
Dealer : Molle Toyota
Last Online: 09-12-2009 11:19 PM
Images: 8
konscience7 is on a distinguished road.
konscience7's Photo Albums
Great write-up!!!!
2008 Crewmax Limited
OEM:
5.7 Black Onyx w/Redrock interior, 4X4, Xzilon package in/out, Moonroof, JBL system, Bluetooth, Deck rail system, Alarm, SS Steprails, bugshield, all weather mats, tow package, Yota 20's.
Mods: Nitto Terragrappler 305 55/R20's, Magnaflow #16770, Ameriguard bedliner, Autobot decal , stubby antenna, partially debadged, PIAA Fog/Headlights, billet grill combo, 20% tint, Garmin GPS, Volant CAI.
  #235 (permalink)
Old 12-20-2008, 04:35 PM
RONE's Avatar
Dealer : Little Apple Toyota
2008 Toyota Tundra 5.7L SR5 4x4 DC
Last Online: Yesterday 11:00 PM
RONE is a splendid one to behold. RONE is a splendid one to behold.
RONE's Photo Albums
If I ever find the person/people who decided on a cartridge-style filter for this truck, I'll shoot him/her/them.
  #236 (permalink)
Old 12-20-2008, 06:03 PM
Henry T's Avatar
Dealer : St. Charles Toyota
Last Online: Yesterday 09:36 PM
Images: 25
Henry T will become famous soon enough. Henry T will become famous soon enough.
Henry T's Photo Albums
Just changed mine for the 2nd time today at 5,700 miles, in my garage, 25F outside and snowing. Spillied a little more than last time LOL about 1/2 quart.
Otherwise went real well, Used Mobil 1 0-20w, Toyota filter. When removing the bolt for the drain valve on the filter housing, give it a quick jerk with your wrench so it breaks loose and does not just spin the whole housing. I used petrolium jelly to lube up the big O-ring, you dont want that thing to bind up and get stuck, tearing it or deforming it. This is the biggest cause for leaks, that or improper placement of the O-ring.
And yes the skid plate is no fun!! Taking the thing off and putting it on is 1/2 hour right there. If you had a lift and power tools it would be 15 min.
2007 Tundra DC SR5 TRD Nautical Blue, 5.7, 4X4, Toytec 2.5" front lift, 1" rear block, Diff. drop kit, BFG AT KOs 305/65R/18, JVC KW-AVX810 head unit, HD Radio, Sirius, JVC CH X1500 12 disc CD changer, Scosche piano black dash kit, Alpine 550 4 channel amp 90 watts per channel, Focal 165 V1 components front, Cliff Designs CD60-4C Components rear, Modified Pioneer sealed sub box, MTX Audio TT 6510-04 10" shallow sub, Alpine 450 mono amp 220 watts, R/F 1 farad digital capacitor, All 4 doors and rear wall DynaMatt, Hard wired Escort Passport 8500 X50, Boyo VLT 300 rear veiw camera.
  #237 (permalink)
Old 12-20-2008, 08:50 PM
RONE's Avatar
RONE's Photo Albums
I thought the skid plate was a breeze! I had one side jacked up when I removed it, but had the truck completely on the ground when I re-installed it. No probs here. That damn plastic device for draining the oil filter, on the other hand....
  #238 (permalink)
Old 12-20-2008, 09:02 PM
Henry T's Avatar
Images: 25
I got it off and on without trouble just time consuming and laying under the truck is never really fun. Plus with the diff drop I have the 3 rear skid plate bolts have spacers that I have to install, so another step.
Yeah the drain valve device gave me some trouble this time, first time I did it the thing worked perfect, this time I had a hard time getting it in and it did not fully drain the canister.
  #239 (permalink)
Old 12-25-2008, 06:22 PM
Dealer : Manhattan Beach Toyota
2008 Toyota Tundra Crewmax 4x4 SR5 TRD,
2004 Toyota 4Runner SR5 V8 4x4
Last Online: 11-19-2009 07:20 PM
ssxa is on a distinguished road.
ssxa's Photo Albums
Just did my first oil change today at work and I must say it was pretty darn easy. This post definately helped, but was not as hard as I was worried about. I used the 65/67MM wrench from Walmart and cutting a 1/2 inch off the top would help. Also my truck took 8quarts for some reason, and I did double check to make sure, it is not overfull. The skid plate was not hard at all either, took me maybe 15 mins total to get it on and off.
2008 Tundra Crewmax SSM SR5 5.7L TRD 4x4
5" Oval/Chrome Railway nerfbars
Chrome door handles
TRD shifter
Tint
2004 4Runner SR5 4x4 (wifes car)
  #240 (permalink)
Old 12-25-2008, 07:12 PM
Dealer : Toyota South
2006 Toyota Sienna Limited,
- Other - 1993 Toyota MR2,
2008 Toyota Tundra DC
Last Online: Yesterday 09:23 PM
MTeator is on a distinguished road.
MTeator's Photo Albums
That's what I used. Already had that 1/2" cut off from doing the filters on my IS350 which had a very similar setup to the Tundra.
~Michael
2008 Toyota Tundra 5.7 2WD - Toy Hauler / 2006 Toyota Sienna Limited - Kid Hauler / 1993 Toyota MR2 - Autocross Car
Mods: Tekonsha P3; Tow Mirrors; TRD Wheels; TPMS Pipe Bomb
LinkBack to this Thread: http://www.tundrasolutions.com/forums/tundra/104260-diy-oil-change-w-pics-reset/
Posted By For Type Date
Dumb Tundra question - TTORA Forum This thread Refback 11-13-2009 07:22 AM
DIY (Do-It-Yourself) & User Knowledgebase - Tundra Geeks :: The Toyota Tundra Enthusiast Forum This thread Refback 09-17-2009 03:24 PM
DIY (Do-It-Yourself) & User Knowledgebase - IBTO Toyota Tundra Forum This thread Refback 07-02-2009 12:39 AM
DIY (Do-It-Yourself) & User Knowledgebase - IBTO Official Forums This thread Refback 06-25-2009 11:57 PM
Anyone change there own oil? - IH8MUD Forums This thread Refback 04-28-2009 02:26 PM
Bumper Repair In Jacksonville, Bumper Repair 2000 Hyundai Sonata 4 Dr Gls, Bumper Sticker Motorcycle Safety - Dieselmotorcycle This thread Refback 03-08-2009 11:22 AM
White Stripe Power Wheels Ford Mustang Ride On Toy, White Stripe Power Wheels Ford Mustang, White Van Speakers - Dubswheels This thread Refback 03-06-2009 03:36 AM
08 Sequoia oil filter question - Toyota Forums :: Toyota Nation This thread Refback 11-02-2008 12:37 AM
Yesterday's Tractors :: View topic - Tundra message This thread Refback 08-21-2008 10:13 PM
Yesterday's Tractors - Discussion Forum This thread Refback 08-21-2008 08:37 AM
: Tow Vehicles: Tundra 5.7L Oil Changes This thread Refback 02-14-2008 04:15 PM
Woodalls Open Roads Forum: Tow Vehicles: Tundra 5.7L Oil Changes This thread Refback 10-27-2007 09:33 PM
RV.Net Open Roads Forum: Tow Vehicles: Tundra 5.7L Oil Changes This thread Refback 10-26-2007 01:48 PM
RV.Net Open Roads Forum: Tow Vehicles: Tundra 5.7L Oil Changes This thread Refback 10-24-2007 08:28 PM
RV.Net Open Roads Forum: Tow Vehicles: Tundra 5.7L Oil Changes This thread Refback 10-24-2007 04:16 PM
RV.Net Open Roads Forum: Tow Vehicles: Tundra 5.7L Oil Changes This thread Refback 10-24-2007 12:55 PM
Trailer Life Directory Open Roads Forum: Tow Vehicles: Tundra 5.7L Oil Changes This thread Refback 10-23-2007 09:04 PM
Trailer Life Magazine Open Roads Forum: Tow Vehicles: Tundra 5.7L Oil Changes This thread Refback 10-23-2007 03:26 PM
RV.Net Open Roads Forum: Tow Vehicles: Tundra 5.7L Oil Changes This thread Refback 10-23-2007 02:54 PM
RV.Net Open Roads Forum: Tow Vehicles: Tundra 5.7L Oil Changes This thread Refback 10-23-2007 02:49 PM
Oil Filter Change nhparrot Engine & Drivetrain 10 06-07-2009 07:15 PM
too soon for an oil change? john480 Tundra 24 11-29-2007 01:56 PM
Which BRAND of OIL? nhparrot Engine & Drivetrain 9 10-29-2007 01:43 PM
Alternate Oil Filters for I-Force V8: nhparrot Engine & Drivetrain 0 03-24-2002 10:09 PM
