LinkBack (19) Thread Tools Display Modes
  #271 (permalink)
Old 06-07-2009, 07:36 PM
2009 Toyota Tundra
Last Online: Yesterday 09:32 PM
ddklbl is on a distinguished road.
ddklbl's Photo Albums
Default Re: DIY: Oil Change w/ pics.
Originally Posted by Tankerhank View Post
Since Kame-a-part and Sears combined Sears quality sucks big time. Craftsmen tools no longer are lifetime warrantied.
Huh? Craftsman Warranty
  #272 (permalink)
Old 08-15-2009, 07:06 PM
blove's Avatar
2007 Toyota Tundra 5.7 4x4 DC LTD TRD
Last Online: 11-06-2009 03:09 PM
blove is on a distinguished road.
blove's Photo Albums
Default Re: DIY: Oil Change w/ pics. & Reset Maintenance Required Light
Did my oil last night along with engine and cabin air filters. was easy...except for that stupid 65-67mm wrench. a paper towel did not work, i hacksawed the 67mm outer ring off, then the 65 seemed too tight, i couldn't get it on the filter housing without banging it with a rubber mallet a few times...then it stuck on there good....how much for the good tool to remove the housing? i'll pay.
oh, and when i removed my oil filter drain plug, it was on so tight that the whole housing started spinning off...and that is from the dealer....
and i'm missing one of the wood screws that holds the front of the skidplate on...nice wood screws toyota!
but considering that i just bought it on wednesday, it is already in a lot better shape than when i found it!
at least I know I'll never have to endure a burst of fleeting regret long after I've retired
  #273 (permalink)
Old 09-22-2009, 11:41 AM
earlycuyler's Avatar
2009 Toyota Tundra CrewMax 5.7 4x4
Last Online: 09-24-2009 06:45 PM
Images: 2
earlycuyler is on a distinguished road.
earlycuyler's Photo Albums
Does anyone know the part no. (or where to otherwise obtain a suitable replacement) for the plastic holders that the skid plate screws go into?
I was careful with them as suggested by the original post in this thread (excellent DIY BTW) but one was broken when I took the screw out and a couple of others don't look to be long for this world. It looks like they were over-tightened from the factory.
Thanks for any help. Sorry if this has been covered but I wasn't able to find it.
2009 Tundra Grade CrewMax 4x4 5.7
  #274 (permalink)
Old 09-22-2009, 01:13 PM
Mr. Creosote's Avatar
Legendary Contributor
Last Online: Today 03:14 AM
Images: 3
Mr. Creosote has done just about everything. Mr. Creosote has done just about everything. Mr. Creosote has done just about everything. Mr. Creosote has done just about everything. Mr. Creosote has done just about everything. Mr. Creosote has done just about everything. Mr. Creosote has done just about everything. Mr. Creosote has done just about everything. Mr. Creosote has done just about everything. Mr. Creosote has done just about everything. Mr. Creosote has done just about everything.
Mr. Creosote's Photo Albums
I broke down and bought the OEM parts because I found the jobber parts did not fit / accept the screws the same way.
The key to making the OEM plastic bits last is:
1. Do not over tighten. Hand tighten with a nut driver only.
2. When cutting threads in a brand new plastic holder, cut the thread once only. Do not cross thread when reinstalling the screws after the next oil change is done. The key is to get the screw to reuse the originally cut threads without recutting new threads. This is because every time you recut more threads, more of the plastic gets shredded until no plastic remains. To do this, touch the screw loosely into the holder, then turn the screw carefully backward (CCW) until you feel it pop down into the holder. At this instant you have found the original thread. Then tighten (CW).
Attention environmentalists, reduce emissions from this:
  #275 (permalink)
Old 09-22-2009, 01:49 PM
Images: 2
Thanks. Do you happen to have a part number or the official name of these pieces?
  #276 (permalink)
Old 09-27-2009, 02:11 PM
bulwaagh's Avatar
Dealer : Brown's Charlottesville Toyota
2009 Toyota Tundra SR5 DC Radiant Red,
- Other - 03 S10 Blazer
Last Online: Yesterday 04:41 PM
Images: 3
bulwaagh will become famous soon enough.
bulwaagh's Photo Albums
2nd'd I thought I was really careful with the disassembly but as I was putting the plate back up, 2 little dink-dink's later, I had plastic pieces fall in my nose.
Also, the oil-cap tool that I originally bought, 65mmx14 did absolutely not work. I measured with my micrometer and sure enough, the tool was indeed, 65mmx14. Measuring the plastic oil cap, that was 65.4mm (2.575" per the micrometer). Going to autozone, I found "Oil Filter "F" Cap Wrench 25404" @ $5.99 . The autozone part number appears to be #153161. I measured it with the micrometer before I bought it, and it was 2.570" (~65.28mm) and it fit MUUCH better than the 65mm wrench. I dont know what kind of grease toyo used, but I had to paper-towel this cap wrench to break the seal, then the tool worked quite well. If you don't have the Toyo part or other known good cap wrench, this one worked well for me.
  #277 (permalink)
Old 10-12-2009, 05:18 PM
Last Online: 10-12-2009 08:51 PM
wneinast is on a distinguished road.
wneinast's Photo Albums
Attempted first oil change on an '07 Tundra I purchased used today. Was never able to get the filter housing to unscrew. Whoever owned it before had broken off a small section of the housing and it was screwed on so tight nothing I tried would get it off. Went ahead and switched out the oil, and will need to take it to dealer next time to get the filter changed. My question is "WHY?" What possible advantage does this type of oil filter offer over the traditional and much easier screw on canister. Seems like this is nothing more than an attempt to force more and more of us "do it yourselfers" into the dealership. I'd appreciate any insight as to any other reason for using this design as opposed to the screw on Canister that 99% of vehicles manufactured today use.
  #278 (permalink)
Old 10-13-2009, 03:19 PM
bulwaagh's Avatar
Images: 3
I dunno, this was the cleanest oil change I ever performed. It was also one of the easiest when I finally got the proper tool. The little screw-on tool + a length of some aquarium hose, and I didn't spill a drop. When the tools are right, this is a breeze. When you don't have the right tools, or the previous oil changer munged something up, yeah, I can see where it can be a pain.
  #279 (permalink)
Old 10-13-2009, 04:36 PM
wintergreen's Avatar
Dealer : Miller Toyota
Last Online: 11-05-2009 08:31 PM
Images: 9
wintergreen is on a distinguished road.
wintergreen's Photo Albums
Please clarify: Is the screw on plastic tool, the device that comes with the Purolator filter?
2007 Tundra DC 5.7L 4x4 Limited, Timberland Mica, 20" Wheels, NAV, Bed Liner, Run Boards, aFe CAI, Borla Dual-Side Exhaust Craftec Tonneau Cover, Dawn Enterprises Lower Body Side Molding
  #280 (permalink)
Old 10-18-2009, 03:51 AM
Dealer : Power Toyota Irvine
Last Online: Yesterday 02:10 AM
jjrho is on a distinguished road.
jjrho's Photo Albums
Default skid plate mod for oil change
well, i have a 2007 tundra 5.7 and 2010 sequoia and on my first oil change, i cut a 5'x5' square straight underneath the oil filter....
now i don't have to drop the plate for each oil change...
jim R
  #281 (permalink)
Old 10-19-2009, 09:54 AM
bulwaagh's Avatar
Images: 3
yes, the toyo filter comes with a push-on tool that is (IMO) a PITA. The purolator tool is much easier, but I ended up cross-threading mine :\
It still worked, but I'll grab another purolator in 6 months, just for the tool.
  #282 (permalink)
Old 10-19-2009, 10:30 AM
RudyDep's Avatar
Dealer : Universal Toyota
2007 Toyota Tundra,
- Other -,
2008 Toyota Sequoia Slate Metallic Ltd
Last Online: 11-06-2009 03:22 PM
Images: 18
RudyDep is a splendid one to behold. RudyDep is a splendid one to behold.
RudyDep's Photo Albums
I cut a 6x6 square. Re installed it with a hinge and a sheet metal screw. Easy access now! I also used lock tite on the filter drain plug. Now I insert a long extension in the filter housing and it comes right out with minimal mess !
Black 2007 D/C Limited 4x4, seems to have ALL the options, Flowmaster Dual Delta 40's, K&N drop in filter, Rhino Liner', 3" frt 1" rear Daystar leveling kit, BFG Radial All Terrain TA's 305x65x18, Moto Metal M0951's in Chrome 18x9. Fully DeBadged , Stebel horn, C/W grill, TRD Swaybar, Wet O's, Craven Speed Stubby Antenna, 10,000 lb winch, H11 bulbs, Production date 8/07
"CBTMA Member"
all that is remaining is:
Black Mod Headlights
1997 Chevy Tahoe Sport 4x4
2008 Sequoia Ltd. Slate Metallic (purchased on 3/28/09)
"Some people spend an entire lifetime wondering if they made a difference. The MARINES don't have that problem."
President Ronald Reagan 1985
LinkBack to this Thread: http://www.tundrasolutions.com/forums/tundra/104260-diy-oil-change-w-pics-reset/
Posted By For Type Date
DIY (Do-It-Yourself) & User Knowledgebase - Tundra Geeks :: The Toyota Tundra Enthusiast Forum This thread Refback 09-17-2009 03:24 PM
DIY (Do-It-Yourself) & User Knowledgebase - IBTO Toyota Tundra Forum This thread Refback 07-02-2009 12:39 AM
DIY (Do-It-Yourself) & User Knowledgebase - IBTO Official Forums This thread Refback 06-25-2009 11:57 PM
Anyone change there own oil? - IH8MUD Forums This thread Refback 04-28-2009 02:26 PM
Bumper Repair In Jacksonville, Bumper Repair 2000 Hyundai Sonata 4 Dr Gls, Bumper Sticker Motorcycle Safety - Dieselmotorcycle This thread Refback 03-08-2009 11:22 AM
White Stripe Power Wheels Ford Mustang Ride On Toy, White Stripe Power Wheels Ford Mustang, White Van Speakers - Dubswheels This thread Refback 03-06-2009 03:36 AM
08 Sequoia oil filter question - Toyota Forums :: Toyota Nation This thread Refback 11-02-2008 12:37 AM
Yesterday's Tractors :: View topic - Tundra message This thread Refback 08-21-2008 10:13 PM
Yesterday's Tractors - Discussion Forum This thread Refback 08-21-2008 08:37 AM
: Tow Vehicles: Tundra 5.7L Oil Changes This thread Refback 02-14-2008 04:15 PM
Woodalls Open Roads Forum: Tow Vehicles: Tundra 5.7L Oil Changes This thread Refback 10-27-2007 09:33 PM
RV.Net Open Roads Forum: Tow Vehicles: Tundra 5.7L Oil Changes This thread Refback 10-26-2007 01:48 PM
RV.Net Open Roads Forum: Tow Vehicles: Tundra 5.7L Oil Changes This thread Refback 10-24-2007 08:28 PM
RV.Net Open Roads Forum: Tow Vehicles: Tundra 5.7L Oil Changes This thread Refback 10-24-2007 04:16 PM
RV.Net Open Roads Forum: Tow Vehicles: Tundra 5.7L Oil Changes This thread Refback 10-24-2007 12:55 PM
Trailer Life Directory Open Roads Forum: Tow Vehicles: Tundra 5.7L Oil Changes This thread Refback 10-23-2007 09:04 PM
Trailer Life Magazine Open Roads Forum: Tow Vehicles: Tundra 5.7L Oil Changes This thread Refback 10-23-2007 03:26 PM
RV.Net Open Roads Forum: Tow Vehicles: Tundra 5.7L Oil Changes This thread Refback 10-23-2007 02:54 PM
RV.Net Open Roads Forum: Tow Vehicles: Tundra 5.7L Oil Changes This thread Refback 10-23-2007 02:49 PM
Oil Filter Change nhparrot Engine & Drivetrain 10 06-07-2009 07:15 PM
too soon for an oil change? john480 Tundra 24 11-29-2007 01:56 PM
Which BRAND of OIL? nhparrot Engine & Drivetrain 9 10-29-2007 01:43 PM
Alternate Oil Filters for I-Force V8: nhparrot Engine & Drivetrain 0 03-24-2002 10:09 PM
